foxint wroteI have HiFi Berry Digi+. Since the Digi+ has both RCA and Optical....
It's coax brother, a coaxial cable connector. Not RCA, if you keep saying it's RCA you going to confuse people (and me). Did you try what PeteB told you to try?
foxint wrote...my Digi+ is the transformer version - they told me this was good.
It is very good. Did you try what PeteB told you to try?
foxint wroteWell I am totally confused....
I will restrain myself. Did you try what PeteB told you to try?
foxint wroteDoes this shed any light on the issue?
Nope... not at all. Did you try what PeteB told you to try?
Santa Claus (aka PeteB) wrote...Secondly, you can choose the maximum sampling rate. You can choose between 96 kHz and 192 kHz. Press the FUNC button to choose, then on the INPUT button to save the configuration...
Santa Claus (aka PeteB) wroteSo, user has two options. 1) buy a coax cable 2) use the optical cable and set the maximum manually, in which case the DAC and MPD will play nice and only 96K will be sent over the optical cable to the DAC. In either case, the answer is reading one paragraph, and a few clicks of the front panel buttons away.
PS: Frank.... really... this is a first, for you!
