Igor wrote@[deleted]
Thanks for your effort, but I guess my knowledge is too poor to understand what you're saying.
I also read Honda's guide, but it was too complicated for me.
Anyway, thanks, I guess new version of Rune will be out soon.
Hi Igor, I faced the same situation, at least try this:
You need only two things:
Get into you rasperry operation system / to see you your ssd card, simply said what is physically accessible /file loaded onto your card as windows system...:
1. download application WinScp, run, fill your IP device adress, fill your username: root, password: rune
and enter, you should get access to you rapsberry root file system (similar as into total commander...), you need this for file access/edit (boot/config.txt, and other files if necessary)
2. download application Putty, load and again fill your IP device adress (same as above) , fill/mark off SSH and enter, you shoul get access
into console of your device under RuneAudio program/sytem, fill again username: root, password: rune, and now you can type necessary commands as in DOS system if you understand me.
Try this and let me know if it will work. If yes you can try step by step procedure for updating firmware and kernel which is mentioned in this topic and elsewhere on rune forum. But also find your mirrolist file (after WinScp and you can see root files/directory of your device...) to avoid any future problems with downloading datas...
then resize your card if necessary before any downloading (kernel and others files), mentioned steps here on RuneForum work for me...
Regards
Vita
