Couldn't even get the wifi connected this time.
The log:
-- Logs begin at Mon 2016-02-22 15:40:15 CET, end at Sun 2016-03-27 08:25:51 CEST. --
Feb 22 15:40:15 runeaudio systemd-journald[134]: Runtime journal (/run/log/journal/) is 5.7M, max 46.1M, 40.3M free.
Feb 22 15:40:15 runeaudio kernel: Booting Linux on physical CPU 0x0
Feb 22 15:40:15 runeaudio kernel: Initializing cgroup subsys cpuset
Feb 22 15:40:15 runeaudio kernel: Initializing cgroup subsys cpuacct
Feb 22 15:40:15 runeaudio kernel: Linux version 4.1.20-1-ARCH (builduser@leming) (gcc version 5.3.0 (GCC) ) #1 SMP Sat Mar 19 20:07:23 MDT 2016
Feb 22 15:40:15 runeaudio kernel: CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
Feb 22 15:40:15 runeaudio kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Feb 22 15:40:15 runeaudio kernel: Machine model: Raspberry Pi 3 Model B Rev 1.2
Feb 22 15:40:15 runeaudio kernel: cma: Reserved 8 MiB at 0x3a400000
Feb 22 15:40:15 runeaudio kernel: Memory policy: Data cache writealloc
Feb 22 15:40:15 runeaudio kernel: On node 0 totalpages: 241664
Feb 22 15:40:15 runeaudio kernel: free_area_init_node: node 0, pgdat 80b88cc0, node_mem_map b9bb4000
Feb 22 15:40:15 runeaudio kernel: Normal zone: 2124 pages used for memmap
Feb 22 15:40:15 runeaudio kernel: Normal zone: 0 pages reserved
Feb 22 15:40:15 runeaudio kernel: Normal zone: 241664 pages, LIFO batch:31
Feb 22 15:40:15 runeaudio kernel: [bcm2709_smp_init_cpus] enter (9380->f3003010)
Feb 22 15:40:15 runeaudio kernel: [bcm2709_smp_init_cpus] ncores=4
Feb 22 15:40:15 runeaudio kernel: PERCPU: Embedded 13 pages/cpu @bafac000 s21132 r8192 d23924 u53248
Feb 22 15:40:15 runeaudio kernel: pcpu-alloc: s21132 r8192 d23924 u53248 alloc=13*4096
Feb 22 15:40:15 runeaudio kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Feb 22 15:40:15 runeaudio kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
Feb 22 15:40:15 runeaudio kernel: Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0x6a188cad smsc95xx.macaddr=B8:27:EB:18:8C:AD bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rw rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 kgdboc=ttyS0,115200 elevator=noop ipv6.disable=1 quiet
Feb 22 15:40:15 runeaudio kernel: PID hash table entries: 4096 (order: 2, 16384 bytes)
Feb 22 15:40:15 runeaudio kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Feb 22 15:40:15 runeaudio kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Feb 22 15:40:15 runeaudio kernel: Memory: 936208K/966656K available (7904K kernel code, 676K rwdata, 2840K rodata, 412K init, 780K bss, 22256K reserved, 8192K cma-reserved)
Feb 22 15:40:15 runeaudio kernel: Virtual kernel memory layout:
vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80a86280 (10745 kB)
.init : 0x80a87000 - 0x80aee000 ( 412 kB)
.data : 0x80aee000 - 0x80b97048 ( 677 kB)
.bss : 0x80b9a000 - 0x80c5d33c ( 781 kB)
Feb 22 15:40:15 runeaudio kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Feb 22 15:40:15 runeaudio kernel: Hierarchical RCU implementation.
Feb 22 15:40:15 runeaudio kernel: NR_IRQS:608
Feb 22 15:40:15 runeaudio kernel: Architected cp15 timer(s) running at 19.20MHz (phys).
Feb 22 15:40:15 runeaudio kernel: clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Feb 22 15:40:15 runeaudio kernel: sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Feb 22 15:40:15 runeaudio kernel: Switching to timer-based delay loop, resolution 52ns
Feb 22 15:40:15 runeaudio kernel: Console: colour dummy device 80x30
Feb 22 15:40:15 runeaudio kernel: console [tty1] enabled
Feb 22 15:40:15 runeaudio kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
Feb 22 15:40:15 runeaudio kernel: pid_max: default: 32768 minimum: 301
Feb 22 15:40:15 runeaudio kernel: Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Feb 22 15:40:15 runeaudio kernel: Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Feb 22 15:40:15 runeaudio kernel: Initializing cgroup subsys blkio
Feb 22 15:40:15 runeaudio kernel: Initializing cgroup subsys memory
Feb 22 15:40:15 runeaudio kernel: Initializing cgroup subsys devices
Feb 22 15:40:15 runeaudio kernel: Initializing cgroup subsys freezer
Feb 22 15:40:15 runeaudio kernel: Initializing cgroup subsys net_cls
Feb 22 15:40:15 runeaudio kernel: Initializing cgroup subsys bfqio
Feb 22 15:40:15 runeaudio kernel: Initializing cgroup subsys perf_event
Feb 22 15:40:15 runeaudio kernel: Initializing cgroup subsys net_prio
Feb 22 15:40:15 runeaudio kernel: CPU: Testing write buffer coherency: ok
Feb 22 15:40:15 runeaudio kernel: CPU0: update cpu_capacity 1024
Feb 22 15:40:15 runeaudio kernel: CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Feb 22 15:40:15 runeaudio kernel: [bcm2709_smp_prepare_cpus] enter
Feb 22 15:40:15 runeaudio kernel: Setting up static identity map for 0x8240 - 0x8274
Feb 22 15:40:15 runeaudio kernel: [bcm2709_boot_secondary] cpu:1 started (0) 18
Feb 22 15:40:15 runeaudio kernel: [bcm2709_secondary_init] enter cpu:1
Feb 22 15:40:15 runeaudio kernel: CPU1: update cpu_capacity 1024
Feb 22 15:40:15 runeaudio kernel: CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Feb 22 15:40:15 runeaudio kernel: [bcm2709_boot_secondary] cpu:2 started (0) 17
Feb 22 15:40:15 runeaudio kernel: [bcm2709_secondary_init] enter cpu:2
Feb 22 15:40:15 runeaudio kernel: CPU2: update cpu_capacity 1024
Feb 22 15:40:15 runeaudio kernel: CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Feb 22 15:40:15 runeaudio kernel: [bcm2709_boot_secondary] cpu:3 started (0) 18
Feb 22 15:40:15 runeaudio kernel: [bcm2709_secondary_init] enter cpu:3
Feb 22 15:40:15 runeaudio kernel: CPU3: update cpu_capacity 1024
Feb 22 15:40:15 runeaudio kernel: CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Feb 22 15:40:15 runeaudio kernel: Brought up 4 CPUs
Feb 22 15:40:15 runeaudio kernel: SMP: Total of 4 processors activated (153.60 BogoMIPS).
Feb 22 15:40:15 runeaudio kernel: CPU: All CPU(s) started in HYP mode.
Feb 22 15:40:15 runeaudio kernel: CPU: Virtualization extensions available.
Feb 22 15:40:15 runeaudio kernel: devtmpfs: initialized
Feb 22 15:40:15 runeaudio kernel: VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
Feb 22 15:40:15 runeaudio kernel: clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Feb 22 15:40:15 runeaudio kernel: xor: measuring software checksum speed
Feb 22 15:40:15 runeaudio kernel: arm4regs : 1845.600 MB/sec
Feb 22 15:40:15 runeaudio kernel: 8regs : 1373.200 MB/sec
Feb 22 15:40:15 runeaudio kernel: 32regs : 1324.000 MB/sec
Feb 22 15:40:15 runeaudio kernel: neon : 2214.400 MB/sec
Feb 22 15:40:15 runeaudio kernel: xor: using function: neon (2214.400 MB/sec)
Feb 22 15:40:15 runeaudio kernel: pinctrl core: initialized pinctrl subsystem
Feb 22 15:40:15 runeaudio kernel: NET: Registered protocol family 16
Feb 22 15:40:15 runeaudio kernel: DMA: preallocated 4096 KiB pool for atomic coherent allocations
Feb 22 15:40:15 runeaudio kernel: bcm2709.uart_clock = 48000000
Feb 22 15:40:15 runeaudio kernel: bcm2709: Mini UART enabled
Feb 22 15:40:15 runeaudio kernel: hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Feb 22 15:40:15 runeaudio kernel: hw-breakpoint: maximum watchpoint size is 8 bytes.
Feb 22 15:40:15 runeaudio kernel: Serial: AMBA PL011 UART driver
Feb 22 15:40:15 runeaudio kernel: uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
Feb 22 15:40:15 runeaudio kernel: bcm2835-mbox 3f00b880.mailbox: mailbox enabled
Feb 22 15:40:15 runeaudio kernel: raid6: int32x1 gen() 209 MB/s
Feb 22 15:40:15 runeaudio kernel: raid6: int32x1 xor() 182 MB/s
Feb 22 15:40:15 runeaudio kernel: raid6: int32x2 gen() 307 MB/s
Feb 22 15:40:15 runeaudio kernel: raid6: int32x2 xor() 210 MB/s
Feb 22 15:40:15 runeaudio kernel: raid6: int32x4 gen() 326 MB/s
Feb 22 15:40:15 runeaudio kernel: raid6: int32x4 xor() 241 MB/s
Feb 22 15:40:15 runeaudio kernel: raid6: int32x8 gen() 333 MB/s
Feb 22 15:40:15 runeaudio kernel: raid6: int32x8 xor() 227 MB/s
Feb 22 15:40:15 runeaudio kernel: raid6: neonx1 gen() 718 MB/s
Feb 22 15:40:15 runeaudio kernel: raid6: neonx2 gen() 1090 MB/s
Feb 22 15:40:15 runeaudio kernel: raid6: neonx4 gen() 1296 MB/s
Feb 22 15:40:15 runeaudio kernel: raid6: neonx8 gen() 1283 MB/s
Feb 22 15:40:15 runeaudio kernel: raid6: using algorithm neonx4 gen() 1296 MB/s
Feb 22 15:40:15 runeaudio kernel: raid6: using intx1 recovery algorithm
Feb 22 15:40:15 runeaudio kernel: bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
Feb 22 15:40:15 runeaudio kernel: bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
Feb 22 15:40:15 runeaudio kernel: bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
Feb 22 15:40:15 runeaudio kernel: bcm2708-dmaengine 3f007000.dma: dma_debug:0
Feb 22 15:40:15 runeaudio kernel: SCSI subsystem initialized
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver usbfs
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver hub
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new device driver usb
Feb 22 15:40:15 runeaudio kernel: raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-19 20:39
Feb 22 15:40:15 runeaudio kernel: Switched to clocksource arch_sys_counter
Feb 22 15:40:15 runeaudio kernel: FS-Cache: Loaded
Feb 22 15:40:15 runeaudio kernel: CacheFiles: Loaded
Feb 22 15:40:15 runeaudio kernel: NET: Registered protocol family 2
Feb 22 15:40:15 runeaudio kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Feb 22 15:40:15 runeaudio kernel: TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Feb 22 15:40:15 runeaudio kernel: TCP: Hash tables configured (established 8192 bind 8192)
Feb 22 15:40:15 runeaudio kernel: UDP hash table entries: 512 (order: 2, 16384 bytes)
Feb 22 15:40:15 runeaudio kernel: UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Feb 22 15:40:15 runeaudio kernel: RPC: Registered named UNIX socket transport module.
Feb 22 15:40:15 runeaudio kernel: RPC: Registered udp transport module.
Feb 22 15:40:15 runeaudio kernel: RPC: Registered tcp transport module.
Feb 22 15:40:15 runeaudio kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Feb 22 15:40:15 runeaudio kernel: hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
Feb 22 15:40:15 runeaudio kernel: futex hash table entries: 1024 (order: 4, 65536 bytes)
Feb 22 15:40:15 runeaudio kernel: VFS: Disk quotas dquot_6.6.0
Feb 22 15:40:15 runeaudio kernel: VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Feb 22 15:40:15 runeaudio kernel: FS-Cache: Netfs 'nfs' registered for caching
Feb 22 15:40:15 runeaudio kernel: NFS: Registering the id_resolver key type
Feb 22 15:40:15 runeaudio kernel: Key type id_resolver registered
Feb 22 15:40:15 runeaudio kernel: Key type id_legacy registered
Feb 22 15:40:15 runeaudio kernel: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Feb 22 15:40:15 runeaudio kernel: JFS: nTxBlock = 7378, nTxLock = 59025
Feb 22 15:40:15 runeaudio kernel: SGI XFS with ACLs, security attributes, realtime, no debug enabled
Feb 22 15:40:15 runeaudio kernel: aufs 4.1-20160301
Feb 22 15:40:15 runeaudio kernel: async_tx: api initialized (async)
Feb 22 15:40:15 runeaudio kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
Feb 22 15:40:15 runeaudio kernel: io scheduler noop registered (default)
Feb 22 15:40:15 runeaudio kernel: io scheduler deadline registered
Feb 22 15:40:15 runeaudio kernel: io scheduler cfq registered
Feb 22 15:40:15 runeaudio kernel: io scheduler bfq registered
Feb 22 15:40:15 runeaudio kernel: BFQ I/O-scheduler: v7r8
Feb 22 15:40:15 runeaudio kernel: BCM2708FB: allocated DMA memory fa800000
Feb 22 15:40:15 runeaudio kernel: BCM2708FB: allocated DMA channel 0 @ f3007000
Feb 22 15:40:15 runeaudio kernel: Console: switching to colour frame buffer device 82x26
Feb 22 15:40:15 runeaudio kernel: Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
Feb 22 15:40:15 runeaudio kernel: console [ttyS0] disabled
Feb 22 15:40:15 runeaudio kernel: 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 29, base_baud = 50000000) is a 16550
Feb 22 15:40:15 runeaudio kernel: console [ttyS0] enabled
Feb 22 15:40:15 runeaudio kernel: KGDB: Registered I/O driver kgdboc
Feb 22 15:40:15 runeaudio kernel: vc-cma: Videocore CMA driver
Feb 22 15:40:15 runeaudio kernel: vc-cma: vc_cma_base = 0x00000000
Feb 22 15:40:15 runeaudio kernel: vc-cma: vc_cma_size = 0x00000000 (0 MiB)
Feb 22 15:40:15 runeaudio kernel: vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
Feb 22 15:40:15 runeaudio kernel: vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
Feb 22 15:40:15 runeaudio kernel: brd: module loaded
Feb 22 15:40:15 runeaudio kernel: loop: module loaded
Feb 22 15:40:15 runeaudio kernel: vchiq: vchiq_init_state: slot_zero = 0xba880000, is_master = 0
Feb 22 15:40:15 runeaudio kernel: Loading iSCSI transport class v2.0-870.
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ax88179_178a
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver smsc95xx
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver cdc_ncm
Feb 22 15:40:15 runeaudio kernel: dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Feb 22 15:40:15 runeaudio kernel: Core Release: 2.80a
Feb 22 15:40:15 runeaudio kernel: Setting default values for core params
Feb 22 15:40:15 runeaudio kernel: Finished setting default values for core params
Feb 22 15:40:15 runeaudio kernel: Using Buffer DMA mode
Feb 22 15:40:15 runeaudio kernel: Periodic Transfer Interrupt Enhancement - disabled
Feb 22 15:40:15 runeaudio kernel: Multiprocessor Interrupt Enhancement - disabled
Feb 22 15:40:15 runeaudio kernel: OTG VER PARAM: 0, OTG VER FLAG: 0
Feb 22 15:40:15 runeaudio kernel: Dedicated Tx FIFOs mode
Feb 22 15:40:15 runeaudio kernel: WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xba814000 dma = 0xfa814000 len=9024
Feb 22 15:40:15 runeaudio kernel: FIQ FSM acceleration enabled for :
Periodic Split Transactions
Feb 22 15:40:15 runeaudio kernel: dwc_otg: Microframe scheduler enabled
Feb 22 15:40:15 runeaudio kernel: WARN::hcd_init_fiq:412: FIQ on core 1 at 0x805cb7e8
Feb 22 15:40:15 runeaudio kernel: WARN::hcd_init_fiq:413: FIQ ASM at 0x805cbb30 length 36
Feb 22 15:40:15 runeaudio kernel: WARN::hcd_init_fiq:438: MPHI regs_base at 0xbbcee000
Feb 22 15:40:15 runeaudio kernel: dwc_otg 3f980000.usb: DWC OTG Controller
Feb 22 15:40:15 runeaudio kernel: dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Feb 22 15:40:15 runeaudio kernel: dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
Feb 22 15:40:15 runeaudio kernel: Init: Port Power? op_state=1
Feb 22 15:40:15 runeaudio kernel: Init: Power Port (0)
Feb 22 15:40:15 runeaudio kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Feb 22 15:40:15 runeaudio kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 22 15:40:15 runeaudio kernel: usb usb1: Product: DWC OTG Controller
Feb 22 15:40:15 runeaudio kernel: usb usb1: Manufacturer: Linux 4.1.20-1-ARCH dwc_otg_hcd
Feb 22 15:40:15 runeaudio kernel: usb usb1: SerialNumber: 3f980000.usb
Feb 22 15:40:15 runeaudio kernel: hub 1-0:1.0: USB hub found
Feb 22 15:40:15 runeaudio kernel: hub 1-0:1.0: 1 port detected
Feb 22 15:40:15 runeaudio kernel: dwc_otg: FIQ enabled
Feb 22 15:40:15 runeaudio kernel: dwc_otg: NAK holdoff enabled
Feb 22 15:40:15 runeaudio kernel: dwc_otg: FIQ split-transaction FSM enabled
Feb 22 15:40:15 runeaudio kernel: Module dwc_common_port init
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver usb-storage
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ums-alauda
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ums-cypress
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ums-datafab
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ums_eneub6250
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ums-freecom
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ums-isd200
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ums-jumpshot
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ums-karma
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ums-onetouch
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ums-realtek
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ums-sddr09
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ums-sddr55
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver ums-usbat
Feb 22 15:40:15 runeaudio kernel: mousedev: PS/2 mouse device common for all mice
Feb 22 15:40:15 runeaudio kernel: md: linear personality registered for level -1
Feb 22 15:40:15 runeaudio kernel: md: raid0 personality registered for level 0
Feb 22 15:40:15 runeaudio kernel: md: raid1 personality registered for level 1
Feb 22 15:40:15 runeaudio kernel: md: raid10 personality registered for level 10
Feb 22 15:40:15 runeaudio kernel: md: raid6 personality registered for level 6
Feb 22 15:40:15 runeaudio kernel: md: raid5 personality registered for level 5
Feb 22 15:40:15 runeaudio kernel: md: raid4 personality registered for level 4
Feb 22 15:40:15 runeaudio kernel: md: multipath personality registered for level -4
Feb 22 15:40:15 runeaudio kernel: md: faulty personality registered for level -5
Feb 22 15:40:15 runeaudio kernel: device-mapper: uevent: version 1.0.3
Feb 22 15:40:15 runeaudio kernel: device-mapper: ioctl: 4.31.0-ioctl (2015-3-12) initialised: dm-devel@redhat.com
Feb 22 15:40:15 runeaudio kernel: device-mapper: multipath: version 1.9.0 loaded
Feb 22 15:40:15 runeaudio kernel: device-mapper: multipath round-robin: version 1.0.0 loaded
Feb 22 15:40:15 runeaudio kernel: device-mapper: multipath queue-length: version 0.1.0 loaded
Feb 22 15:40:15 runeaudio kernel: device-mapper: multipath service-time: version 0.2.0 loaded
Feb 22 15:40:15 runeaudio kernel: device-mapper: raid: Loading target version 1.6.0
Feb 22 15:40:15 runeaudio kernel: bcm2835-cpufreq: min=1200000 max=1200000
Feb 22 15:40:15 runeaudio kernel: sdhci: Secure Digital Host Controller Interface driver
Feb 22 15:40:15 runeaudio kernel: sdhci: Copyright(c) Pierre Ossman
Feb 22 15:40:15 runeaudio kernel: sdhost: log_buf @ ba813000 (fa813000)
Feb 22 15:40:15 runeaudio kernel: mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Feb 22 15:40:15 runeaudio kernel: mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
Feb 22 15:40:15 runeaudio kernel: mmc-bcm2835 3f300000.mmc: DMA channel allocated
Feb 22 15:40:15 runeaudio kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Feb 22 15:40:15 runeaudio kernel: ledtrig-cpu: registered to indicate activity on CPUs
Feb 22 15:40:15 runeaudio kernel: hidraw: raw HID events driver (C) Jiri Kosina
Feb 22 15:40:15 runeaudio kernel: usbcore: registered new interface driver usbhid
Feb 22 15:40:15 runeaudio kernel: usbhid: USB HID core driver
Feb 22 15:40:15 runeaudio kernel: Initializing XFRM netlink socket
Feb 22 15:40:15 runeaudio kernel: NET: Registered protocol family 17
Feb 22 15:40:15 runeaudio kernel: Key type dns_resolver registered
Feb 22 15:40:15 runeaudio kernel: Registering SWP/SWPB emulation handler
Feb 22 15:40:15 runeaudio kernel: registered taskstats version 1
Feb 22 15:40:15 runeaudio kernel: Btrfs loaded
Feb 22 15:40:15 runeaudio kernel: Key type encrypted registered
Feb 22 15:40:15 runeaudio kernel: vc-sm: Videocore shared memory driver
Feb 22 15:40:15 runeaudio kernel: [vc_sm_connected_init]: start
Feb 22 15:40:15 runeaudio kernel: [vc_sm_connected_init]: end - returning 0
Feb 22 15:40:15 runeaudio kernel: 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
Feb 22 15:40:15 runeaudio kernel: md: Waiting for all devices to be available before autodetect
Feb 22 15:40:15 runeaudio kernel: md: If you don't use raid, use raid=noautodetect
Feb 22 15:40:15 runeaudio kernel: md: Autodetecting RAID arrays.
Feb 22 15:40:15 runeaudio kernel: md: Scanned 0 and added 0 devices.
Feb 22 15:40:15 runeaudio kernel: md: autorun ...
Feb 22 15:40:15 runeaudio kernel: md: ... autorun DONE.
Feb 22 15:40:15 runeaudio kernel: Waiting for root device /dev/mmcblk0p2...
Feb 22 15:40:15 runeaudio kernel: mmc0: host does not support reading read-only switch, assuming write-enable
Feb 22 15:40:15 runeaudio kernel: mmc0: new high speed SDHC card at address 0001
Feb 22 15:40:15 runeaudio kernel: mmcblk0: mmc0:0001 SD 7.44 GiB
Feb 22 15:40:15 runeaudio kernel: mmcblk0: p1 p2
Feb 22 15:40:15 runeaudio kernel: mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Feb 22 15:40:15 runeaudio kernel: mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Feb 22 15:40:15 runeaudio kernel: mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Feb 22 15:40:15 runeaudio kernel: Indeed it is in host mode hprt0 = 00021501
Feb 22 15:40:15 runeaudio kernel: mmc1: new high speed SDIO card at address 0001
Feb 22 15:40:15 runeaudio kernel: usb 1-1: new high-speed USB device number 2 using dwc_otg
Feb 22 15:40:15 runeaudio kernel: Indeed it is in host mode hprt0 = 00001101
Feb 22 15:40:15 runeaudio kernel: usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Feb 22 15:40:15 runeaudio kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Feb 22 15:40:15 runeaudio kernel: hub 1-1:1.0: USB hub found
Feb 22 15:40:15 runeaudio kernel: hub 1-1:1.0: 5 ports detected
Feb 22 15:40:15 runeaudio kernel: EXT4-fs (mmcblk0p2): recovery complete
Feb 22 15:40:15 runeaudio kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 22 15:40:15 runeaudio kernel: VFS: Mounted root (ext4 filesystem) on device 179:2.
Feb 22 15:40:15 runeaudio kernel: devtmpfs: mounted
Feb 22 15:40:15 runeaudio kernel: Freeing unused kernel memory: 412K (80a87000 - 80aee000)
Feb 22 15:40:15 runeaudio kernel: usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Feb 22 15:40:15 runeaudio kernel: usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Feb 22 15:40:15 runeaudio kernel: usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Feb 22 15:40:15 runeaudio kernel: smsc95xx v1.0.4
Feb 22 15:40:15 runeaudio kernel: smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:18:8c:ad
Feb 22 15:40:15 runeaudio systemd[1]: System time before build time, advancing clock.
Feb 22 15:40:15 runeaudio kernel: IPv6: Loaded, but administratively disabled, reboot required to enable
Feb 22 15:40:15 runeaudio kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Feb 22 15:40:15 runeaudio kernel: random: systemd urandom read with 75 bits of entropy available
Feb 22 15:40:15 runeaudio systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
Feb 22 15:40:15 runeaudio systemd[1]: Detected architecture arm.
Feb 22 15:40:15 runeaudio systemd[1]: Set hostname to <runeaudio>.
Feb 22 15:40:15 runeaudio systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Feb 22 15:40:15 runeaudio systemd[1]: Reached target Swap.
Feb 22 15:40:15 runeaudio systemd[1]: Listening on udev Control Socket.
Feb 22 15:40:15 runeaudio systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
Feb 22 15:40:15 runeaudio systemd[1]: Listening on udev Kernel Socket.
Feb 22 15:40:15 runeaudio systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Feb 22 15:40:15 runeaudio systemd[1]: Listening on Device-mapper event daemon FIFOs.
Feb 22 15:40:15 runeaudio systemd[1]: Listening on Process Core Dump Socket.
Feb 22 15:40:15 runeaudio systemd[1]: Reached target Encrypted Volumes.
Feb 22 15:40:15 runeaudio systemd[1]: Reached target Remote File Systems.
Feb 22 15:40:15 runeaudio systemd[1]: Reached target System Time Synchronized.
Feb 22 15:40:15 runeaudio systemd[1]: Created slice System Slice.
Feb 22 15:40:15 runeaudio systemd[1]: Created slice system-netctl\x2dauto.slice.
Feb 22 15:40:15 runeaudio systemd[1]: Reached target Slices.
Feb 22 15:40:15 runeaudio systemd[1]: Created slice system-serial\x2dgetty.slice.
Feb 22 15:40:15 runeaudio systemd[1]: Created slice system-getty.slice.
Feb 22 15:40:15 runeaudio systemd[1]: Created slice system-netctl\x2difplugd.slice.
Feb 22 15:40:15 runeaudio systemd[1]: Listening on Journal Socket.
Feb 22 15:40:15 runeaudio systemd[1]: Mounting POSIX Message Queue File System...
Feb 22 15:40:15 runeaudio systemd[1]: Mounting Temporary Directory...
Feb 22 15:40:15 runeaudio systemd[1]: Starting Load Kernel Modules...
Feb 22 15:40:15 runeaudio systemd[1]: Starting Remount Root and Kernel File Systems...
Feb 22 15:40:15 runeaudio systemd[1]: Starting RuneAudio shutdown script...
Feb 22 15:40:15 runeaudio systemd[1]: Mounting Debug File System...
Feb 22 15:40:15 runeaudio systemd[1]: Starting Setup Virtual Console...
Feb 22 15:40:15 runeaudio systemd[1]: Starting Create list of required static device nodes for the current kernel...
Feb 22 15:40:15 runeaudio systemd[1]: Listening on Journal Socket (/dev/log).
Feb 22 15:40:15 runeaudio systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Feb 22 15:40:15 runeaudio systemd[1]: Reached target Paths.
Feb 22 15:40:15 runeaudio systemd[1]: Starting Journal Service...
Feb 22 15:40:15 runeaudio systemd[1]: Started Remount Root and Kernel File Systems.
Feb 22 15:40:15 runeaudio systemd[1]: Started Create list of required static device nodes for the current kernel.
Feb 22 15:40:15 runeaudio kernel: bcm2708_rng_init=bbcfe000
Feb 22 15:40:15 runeaudio systemd[1]: Started RuneAudio shutdown script.
Feb 22 15:40:15 runeaudio systemd[1]: Mounted POSIX Message Queue File System.
Feb 22 15:40:15 runeaudio systemd[1]: Mounted Debug File System.
Feb 22 15:40:15 runeaudio systemd[1]: Mounted Temporary Directory.
Feb 22 15:40:15 runeaudio systemd[1]: Starting Load/Save Random Seed...
Feb 22 15:40:15 runeaudio systemd[1]: Starting udev Coldplug all Devices...
Feb 22 15:40:15 runeaudio systemd[1]: Starting Create Static Device Nodes in /dev...
Feb 22 15:40:15 runeaudio systemd[1]: Started Load/Save Random Seed.
Feb 22 15:40:15 runeaudio systemd-journald[134]: Journal started
Feb 22 15:40:15 runeaudio systemd-modules-load[126]: Module 'nfs' is builtin
Feb 22 15:40:15 runeaudio systemd-modules-load[126]: Inserted module 'bcm2708_rng'
Feb 22 15:40:15 runeaudio systemd[1]: Started Journal Service.
Feb 22 15:40:15 runeaudio systemd-modules-load[126]: Inserted module 'snd_bcm2835'
Feb 22 15:40:15 runeaudio systemd[1]: Started Load Kernel Modules.
Feb 22 15:40:15 runeaudio systemd[1]: Starting Apply Kernel Variables...
Feb 22 15:40:15 runeaudio systemd[1]: Mounting Configuration File System...
Feb 22 15:40:15 runeaudio systemd[1]: Mounted Configuration File System.
Feb 22 15:40:16 runeaudio systemd[1]: Started udev Coldplug all Devices.
Feb 22 15:40:16 runeaudio systemd[1]: Started Apply Kernel Variables.
Feb 22 15:40:16 runeaudio systemd[1]: Started Create Static Device Nodes in /dev.
Feb 22 15:40:16 runeaudio systemd[1]: Reached target Local File Systems (Pre).
Feb 22 15:40:16 runeaudio systemd[1]: var-log.mount: Directory /var/log to mount over is not empty, mounting anyway.
Feb 22 15:40:16 runeaudio systemd[1]: Mounting /var/log...
Feb 22 15:40:16 runeaudio systemd[1]: Starting udev Kernel Device Manager...
Feb 22 15:40:16 runeaudio systemd[1]: Mounted /var/log.
Feb 22 15:40:16 runeaudio systemd[1]: Mounting /var/log/runeaudio...
Feb 22 15:40:16 runeaudio systemd[1]: Mounted /var/log/runeaudio.
Feb 22 15:40:16 runeaudio systemd[1]: Started Setup Virtual Console.
Feb 22 15:40:16 runeaudio systemd[1]: Started udev Kernel Device Manager.
Feb 22 15:40:16 runeaudio kernel: bcm2835-rng 3f104000.rng: hwrng registered
Feb 22 15:40:16 runeaudio systemd[1]: Found device /dev/ttyS0.
Feb 22 15:40:16 runeaudio kernel: gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
Feb 22 15:40:16 runeaudio systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Feb 22 15:40:16 runeaudio kernel: bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
Feb 22 15:40:16 runeaudio kernel: snd-rpi-hifiberry-dacplus sound: ASoC: CODEC DAI pcm512x-hifi not registered
Feb 22 15:40:16 runeaudio kernel: snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
Feb 22 15:40:16 runeaudio kernel: snd-rpi-hifiberry-dacplus sound: pcm512x-hifi <-> 3f203000.i2s mapping ok
Feb 22 15:40:16 runeaudio systemd[1]: Found device SMSC9512/9514 Fast Ethernet Adapter.
Feb 22 15:40:16 runeaudio kernel: cfg80211: Calling CRDA to update world regulatory domain
Feb 22 15:40:16 runeaudio systemd[1]: Found device /dev/mmcblk0p1.
Feb 22 15:40:16 runeaudio systemd[1]: boot.mount: Directory /boot to mount over is not empty, mounting anyway.
Feb 22 15:40:16 runeaudio systemd[1]: Mounting /boot...
Feb 22 15:40:16 runeaudio kernel: brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
Feb 22 15:40:16 runeaudio kernel: usbcore: registered new interface driver brcmfmac
Feb 22 15:40:16 runeaudio kernel: random: nonblocking pool is initialized
Feb 22 15:40:17 runeaudio kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
Feb 22 15:40:17 runeaudio systemd[1]: Starting Load/Save RF Kill Switch Status...
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2412 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: 2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2417 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2422 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2427 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2432 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2437 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2442 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2447 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2452 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2457 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2462 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Ignoring regulatory request set by core since the driver uses its own custom regulatory domain
Feb 22 15:40:17 runeaudio kernel: brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
Feb 22 15:40:17 runeaudio kernel: cfg80211: World regulatory domain updated:
Feb 22 15:40:17 runeaudio kernel: cfg80211: DFS Master region: unset
Feb 22 15:40:17 runeaudio kernel: cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Feb 22 15:40:17 runeaudio kernel: cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Feb 22 15:40:17 runeaudio kernel: cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Feb 22 15:40:17 runeaudio kernel: cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
Feb 22 15:40:17 runeaudio kernel: cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
Feb 22 15:40:17 runeaudio kernel: cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
Feb 22 15:40:17 runeaudio kernel: cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Feb 22 15:40:17 runeaudio kernel: cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
Feb 22 15:40:17 runeaudio kernel: cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Feb 22 15:40:17 runeaudio kernel: cfg80211: Calling CRDA for country: DE
Feb 22 15:40:17 runeaudio systemd[1]: Found device /sys/subsystem/net/devices/wlan0.
Feb 22 15:40:17 runeaudio systemd-udevd[179]: Process '/usr/bin/crda' failed with exit code 249.
Feb 22 15:40:17 runeaudio kernel: cfg80211: 2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
Feb 22 15:40:17 runeaudio systemd[1]: Started Load/Save RF Kill Switch Status.
Feb 22 15:40:17 runeaudio kernel: cfg80211: Regulatory domain changed to country: DE
Feb 22 15:40:17 runeaudio kernel: cfg80211: DFS Master region: ETSI
Feb 22 15:40:17 runeaudio kernel: cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Feb 22 15:40:17 runeaudio kernel: cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (N/A)
Feb 22 15:40:17 runeaudio kernel: cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
Feb 22 15:40:17 runeaudio kernel: cfg80211: (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
Feb 22 15:40:17 runeaudio kernel: cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
Feb 22 15:40:17 runeaudio systemd[1]: Mounted /boot.
Feb 22 15:40:17 runeaudio kernel: FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Feb 22 15:40:17 runeaudio systemd[1]: Reached target Local File Systems.
Feb 22 15:40:17 runeaudio systemd[1]: Starting Create Volatile Files and Directories...
Feb 22 15:40:17 runeaudio systemd[1]: Started Create Volatile Files and Directories.
Feb 22 15:40:17 runeaudio systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Feb 22 15:40:17 runeaudio systemd[1]: Started Update UTMP about System Boot/Shutdown.
Feb 22 15:40:17 runeaudio systemd[1]: Reached target System Initialization.
Feb 22 15:40:17 runeaudio systemd[1]: Started Daily Cleanup of Temporary Directories.
Feb 22 15:40:17 runeaudio systemd[1]: Listening on D-Bus System Message Bus Socket.
Feb 22 15:40:17 runeaudio systemd[1]: Listening on RPCbind Server Activation Socket.
Feb 22 15:40:17 runeaudio systemd[1]: Started Daily rotation of log files.
Feb 22 15:40:17 runeaudio systemd[1]: Started Daily verification of password and group files.
Feb 22 15:40:17 runeaudio systemd[1]: Reached target Timers.
Feb 22 15:40:17 runeaudio systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Feb 22 15:40:17 runeaudio systemd[1]: Reached target Sockets.
Feb 22 15:40:17 runeaudio systemd[1]: Reached target Basic System.
Feb 22 15:40:17 runeaudio systemd[1]: Started Automatic wired network connection using netctl profiles.
Feb 22 15:40:17 runeaudio systemd[1]: Started RuneAudio MPD watchdog.
Feb 22 15:40:17 runeaudio systemd[1]: Starting Automatic wireless network connection using netctl profiles...
Feb 22 15:40:17 runeaudio systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Feb 22 15:40:17 runeaudio systemd[1]: Starting Permit User Sessions...
Feb 22 15:40:17 runeaudio systemd[1]: Started D-Bus System Message Bus.
Feb 22 15:40:17 runeaudio ifplugd[219]: ifplugd 0.28 initializing.
Feb 22 15:40:17 runeaudio ifplugd[219]: Using interface eth0/B8:27:EB:18:8C:AD with driver <smsc95xx> (version: 22-Aug-2005)
Feb 22 15:40:17 runeaudio ifplugd[219]: Using detection mode: SIOCETHTOOL
Feb 22 15:40:17 runeaudio ifplugd[219]: Initialization complete, link beat not detected.
Feb 22 15:40:17 runeaudio sh[220]: /var/www/command/mpd-watchdog: starting...
Feb 22 15:40:17 runeaudio kernel: smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Feb 22 15:40:17 runeaudio avahi-daemon[222]: Found user 'avahi' (UID 84) and group 'avahi' (GID 84).
Feb 22 15:40:17 runeaudio avahi-daemon[222]: Successfully dropped root privileges.
Feb 22 15:40:17 runeaudio avahi-daemon[222]: avahi-daemon 0.6.32 starting up.
Feb 22 15:40:17 runeaudio avahi-daemon[222]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Feb 22 15:40:17 runeaudio netctl-auto[221]: Included profile 'waves'
Feb 22 15:40:17 runeaudio kernel: brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
Feb 22 15:40:17 runeaudio kernel: brcmfmac: brcmf_add_if: ignore IF event
Feb 22 15:40:17 runeaudio kernel: brcmfmac: power management disabled
Feb 22 15:40:18 runeaudio kernel: brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
Feb 22 15:40:18 runeaudio kernel: brcmfmac: brcmf_add_if: ignore IF event
Feb 22 15:40:18 runeaudio avahi-daemon[222]: Successfully called chroot().
Feb 22 15:40:18 runeaudio avahi-daemon[222]: Successfully dropped remaining capabilities.
Feb 22 15:40:18 runeaudio avahi-daemon[222]: Loading service file /services/runeaudio.service.
Feb 22 15:40:18 runeaudio systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Feb 22 15:40:18 runeaudio systemd[1]: Starting Save/Restore Sound Card State...
Feb 22 15:40:18 runeaudio avahi-daemon[222]: Network interface enumeration completed.
Feb 22 15:40:18 runeaudio avahi-daemon[222]: Server startup complete. Host name is runeaudio.local. Local service cookie is 518571152.
Feb 22 15:40:18 runeaudio avahi-daemon[222]: Service "RuneAudio [runeaudio] [b8:27:eb:18:8c:ad]" (/services/runeaudio.service) successfully established.
Feb 22 15:40:18 runeaudio systemd[1]: Started Permit User Sessions.
Feb 22 15:40:18 runeaudio systemd[1]: Started Getty on tty1.
Feb 22 15:40:18 runeaudio systemd[1]: Started Serial Getty on ttyS0.
Feb 22 15:40:18 runeaudio systemd[1]: Reached target Login Prompts.
Feb 22 15:40:18 runeaudio netctl-auto[221]: Could not read interface p2p-dev-wlan0 flags: No such device
Feb 22 15:40:18 runeaudio systemd-udevd[182]: Process '/var/www/command/refresh_ao' failed with exit code 255.
Feb 22 15:40:18 runeaudio systemd-udevd[170]: Process '/var/www/command/refresh_ao' failed with exit code 255.
Feb 22 15:40:18 runeaudio systemd[1]: Reached target Sound Card.
Feb 22 15:40:18 runeaudio wpa_actiond[262]: Starting wpa_actiond session for interface 'wlan0'
Feb 22 15:40:18 runeaudio systemd[1]: Started Automatic wireless network connection using netctl profiles.
Feb 22 15:40:18 runeaudio systemd[1]: Reached target Network.
Feb 22 15:40:18 runeaudio systemd[1]: Started OpenSSH Daemon.
Feb 22 15:40:18 runeaudio systemd[1]: Starting Network Name Resolution...
Feb 22 15:40:18 runeaudio systemd[1]: Starting Network Time Service...
Feb 22 15:40:18 runeaudio systemd[1]: Starting The PHP FastCGI Process Manager...
Feb 22 15:40:18 runeaudio systemd[1]: Starting Advanced key-value store...
Feb 22 15:40:18 runeaudio systemd[1]: Started RuneAudio Playback Worker.
Feb 22 15:40:18 runeaudio systemd[1]: Starting A high performance web server and a reverse proxy server...
Feb 22 15:40:18 runeaudio systemd[1]: Started Advanced key-value store.
Feb 22 15:40:18 runeaudio systemd[1]: Started Save/Restore Sound Card State.
Feb 22 15:40:18 runeaudio ntpd[265]: ntpd 4.2.8p6@1.3265-o Mon Feb 8 01:56:43 UTC 2016 (1): Starting
Feb 22 15:40:18 runeaudio ntpd[265]: Command line: /usr/bin/ntpd -g -u ntp:ntp
Feb 22 15:40:18 runeaudio rune_PL_wrk[268]: Fatal error: Uncaught exception 'RedisException' with message 'Redis server went away' in /srv/http/app/libs/runeaudio.php:1180
Feb 22 15:40:18 runeaudio rune_PL_wrk[268]: Stack trace:
Feb 22 15:40:18 runeaudio rune_PL_wrk[268]: #0 /srv/http/app/libs/runeaudio.php(1180): Redis->get('debug')
Feb 22 15:40:18 runeaudio rune_PL_wrk[268]: #1 /srv/http/app/libs/runeaudio.php(720): runelog('sysCmd($str)', 'echo "---------...')
Feb 22 15:40:18 runeaudio rune_PL_wrk[268]: #2 /srv/http/command/rune_PL_wrk(42): sysCmd('echo "---------...')
Feb 22 15:40:18 runeaudio rune_PL_wrk[268]: #3 {main}
Feb 22 15:40:18 runeaudio rune_PL_wrk[268]: thrown in /srv/http/app/libs/runeaudio.php on line 1180
Feb 22 15:40:18 runeaudio systemd[1]: Started Network Time Service.
Feb 22 15:40:18 runeaudio systemd[1]: rune_PL_wrk.service: Main process exited, code=exited, status=255/n/a
Feb 22 15:40:18 runeaudio systemd[1]: rune_PL_wrk.service: Unit entered failed state.
Feb 22 15:40:18 runeaudio systemd[1]: rune_PL_wrk.service: Failed with result 'exit-code'.
Feb 22 15:40:18 runeaudio systemd-resolved[264]: Positive Trust Anchors:
Feb 22 15:40:18 runeaudio systemd-resolved[264]: . IN DS 19036 8 2 49aac11d7b6f6446702e54a1607371607a1a41855200fd2ce1cdde32f24e8fb5
Feb 22 15:40:18 runeaudio systemd-resolved[264]: Negative trust anchors: 10.in-addr.arpa 16.172.in-addr.arpa 17.172.in-addr.arpa 18.172.in-addr.arpa 19.172.in-addr.arpa 20.172.in-addr.arpa 21.172.in-addr.arpa 22.172.in-addr.arpa 23.172.in-addr.arpa 24.172.in-addr.arpa 25.172.in-addr.arpa 26.172.in-addr.arpa 27.172.in-addr.arpa 28.172.in-addr.arpa 29.172.in-addr.arpa 30.172.in-addr.arpa 31.172.in-addr.arpa 168.192.in-addr.arpa corp home internal intranet lan local private test
Feb 22 15:40:18 runeaudio systemd-resolved[264]: Using system hostname 'runeaudio'.
Feb 22 15:40:18 runeaudio systemd-resolved[264]: Switching to system DNS server 2001:4860:4860::8844.
Feb 22 15:40:18 runeaudio systemd[1]: Started Network Name Resolution.
Feb 22 15:40:18 runeaudio ntpd[278]: proto: precision = 0.677 usec (-20)
Feb 22 15:40:18 runeaudio ntpd[278]: Listen and drop on 0 v4wildcard 0.0.0.0:123
Feb 22 15:40:18 runeaudio ntpd[278]: Listen normally on 1 lo 127.0.0.1:123
Feb 22 15:40:18 runeaudio ntpd[278]: Listening on routing socket on fd #18 for interface updates
Feb 22 15:40:18 runeaudio systemd[1]: Started A high performance web server and a reverse proxy server.
Feb 22 15:40:18 runeaudio sshd[263]: Server listening on 0.0.0.0 port 22.
Feb 22 15:40:18 runeaudio systemd[1]: Started The PHP FastCGI Process Manager.
Feb 22 15:40:18 runeaudio systemd[1]: Reached target Multi-User System.
Feb 22 15:40:18 runeaudio systemd[1]: Reached target Graphical Interface.
Feb 22 15:40:18 runeaudio systemd[1]: Started RuneAudio System Worker.
Feb 22 15:40:18 runeaudio systemd[1]: Startup finished in 4.029s (kernel) + 4.916s (userspace) = 8.945s.
Feb 22 15:40:19 runeaudio systemd[1]: Stopping The PHP FastCGI Process Manager...
Feb 22 15:40:19 runeaudio systemd[1]: Stopped The PHP FastCGI Process Manager.
Feb 22 15:40:19 runeaudio systemd[1]: Started Music Player Daemon.
Feb 22 15:40:19 runeaudio avahi-daemon[222]: Files changed, reloading.
Feb 22 15:40:19 runeaudio systemd[1]: rune_PL_wrk.service: Service hold-off time over, scheduling restart.
Feb 22 15:40:19 runeaudio systemd[1]: Stopped RuneAudio Playback Worker.
Feb 22 15:40:19 runeaudio systemd[1]: Started RuneAudio Playback Worker.
Feb 22 15:40:19 runeaudio systemd[1]: Starting Samba SMB/CIFS server...
Feb 22 15:40:19 runeaudio rune_PL_wrk[353]: Warning: socket_connect(): unable to connect [2]: No such file or directory in /srv/http/app/libs/runeaudio.php on line 72
Feb 22 15:40:20 runeaudio systemd[1]: Stopping Music Player Daemon...
Feb 22 15:40:20 runeaudio systemd[1]: Stopped Music Player Daemon.
Feb 22 15:40:20 runeaudio systemd[1]: Started Samba SMB/CIFS server.
Feb 22 15:40:20 runeaudio systemd[1]: Starting Samba NetBIOS name server...
Feb 22 15:40:20 runeaudio systemd[1]: Started Samba NetBIOS name server.
Feb 22 15:40:21 runeaudio systemd[1]: Started Music Player Daemon.
Feb 22 15:40:21 runeaudio systemd[1]: Stopped Upmpdcli UPnP/dlna receiver.
Feb 22 15:40:21 runeaudio systemd[1]: Started Upmpdcli UPnP/dlna receiver.
Feb 22 15:40:21 runeaudio rune_SY_wrk[297]: Warning: socket_write(): unable to write to socket [32]: Broken pipe in /srv/http/app/libs/runeaudio.php on line 105
Feb 22 15:40:22 runeaudio systemd[1]: mpd.service: Service hold-off time over, scheduling restart.
Feb 22 15:40:22 runeaudio systemd[1]: Stopping Upmpdcli UPnP/dlna receiver...
Feb 22 15:40:22 runeaudio systemd[1]: Stopped Upmpdcli UPnP/dlna receiver.
Feb 22 15:40:22 runeaudio systemd[1]: Stopped Music Player Daemon.
Feb 22 15:40:22 runeaudio systemd[1]: Started Music Player Daemon.
Feb 22 15:40:22 runeaudio systemd[1]: Started Upmpdcli UPnP/dlna receiver.
Feb 22 15:40:22 runeaudio rune_PL_wrk[353]: Warning: socket_connect(): unable to connect [111]: Connection refused in /srv/http/app/libs/runeaudio.php on line 72
Feb 22 15:40:23 runeaudio systemd[1]: Stopped Music Player Daemon.
Feb 22 15:40:23 runeaudio systemd[1]: Started Music Player Daemon.
Feb 22 15:40:23 runeaudio systemd[1]: Stopped Upmpdcli UPnP/dlna receiver.
Feb 22 15:40:23 runeaudio systemd[1]: Started Upmpdcli UPnP/dlna receiver.
Feb 22 15:40:23 runeaudio systemd[1]: Starting Shairport AirTunes receiver...
Feb 22 15:40:23 runeaudio systemd[1]: Started Shairport AirTunes receiver.
Feb 22 15:40:23 runeaudio systemd[1]: Started Usb Automount (udevil).
Feb 22 15:40:24 runeaudio systemd[1]: Starting The PHP FastCGI Process Manager...
Feb 22 15:40:24 runeaudio systemd[1]: Started The PHP FastCGI Process Manager.
Feb 22 15:40:24 runeaudio kernel: brcmfmac: power management disabled
Feb 22 15:40:24 runeaudio sudo[529]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/xinit
Feb 22 15:40:24 runeaudio sudo[529]: pam_unix(sudo:session): session opened for user root by (uid=0)
Feb 22 15:40:24 runeaudio systemd[1]: Started Music Player Daemon.
Feb 22 15:40:24 runeaudio systemd[1]: Stopping Upmpdcli UPnP/dlna receiver...
Feb 22 15:40:24 runeaudio systemd[1]: Stopped Upmpdcli UPnP/dlna receiver.
Feb 22 15:40:24 runeaudio systemd[1]: Started Upmpdcli UPnP/dlna receiver.
Feb 22 15:40:25 runeaudio rune_PL_wrk[353]: Warning: socket_read(): unable to read from socket [104]: Connection reset by peer in /srv/http/app/libs/runeaudio.php on line 218
Feb 22 15:40:25 runeaudio rune_PL_wrk[353]: Warning: socket_write(): unable to write to socket [32]: Broken pipe in /srv/http/app/libs/runeaudio.php on line 105
Feb 22 15:40:25 runeaudio rune_PL_wrk[353]: Warning: socket_connect(): unable to connect [111]: Connection refused in /srv/http/app/libs/runeaudio.php on line 72
Feb 22 15:40:26 runeaudio systemd[1]: mpd.service: Service hold-off time over, scheduling restart.
Feb 22 15:40:26 runeaudio systemd[1]: Stopping Upmpdcli UPnP/dlna receiver...
Feb 22 15:40:26 runeaudio systemd[1]: Stopped Upmpdcli UPnP/dlna receiver.
Feb 22 15:40:26 runeaudio systemd[1]: Stopped Music Player Daemon.
Feb 22 15:40:26 runeaudio systemd[1]: Started Music Player Daemon.
Feb 22 15:40:26 runeaudio systemd[1]: Started Upmpdcli UPnP/dlna receiver.
Feb 22 15:40:26 runeaudio systemd[1]: Stopping Music Player Daemon...
Feb 22 15:40:27 runeaudio systemd[1]: Stopped Music Player Daemon.
Feb 22 15:40:27 runeaudio systemd[1]: Reloading.
Feb 22 15:40:28 runeaudio systemd[1]: Started Music Player Daemon.
Feb 22 15:40:28 runeaudio systemd[1]: Stopped Upmpdcli UPnP/dlna receiver.
Feb 22 15:40:28 runeaudio systemd[1]: Started Upmpdcli UPnP/dlna receiver.
Feb 22 15:40:28 runeaudio org.a11y.Bus[857]: Activating service name='org.a11y.atspi.Registry'
Feb 22 15:40:29 runeaudio org.a11y.Bus[857]: Successfully activated service 'org.a11y.atspi.Registry'
Feb 22 15:40:29 runeaudio org.a11y.atspi.Registry[874]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Feb 22 15:41:17 runeaudio kernel: cfg80211: Verifying active interfaces after reg change
Feb 22 15:46:00 runeaudio kernel: smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
Feb 22 15:46:00 runeaudio ifplugd[219]: Link beat detected.
Feb 22 15:46:01 runeaudio ifplugd[219]: Executing '/etc/ifplugd/netctl.action eth0 up'.
Feb 22 15:46:02 runeaudio ifplugd[219]: client: Starting network profile 'eth0'...
Feb 22 15:46:02 runeaudio dhcpcd[1129]: DUID 00:01:00:01:1c:72:2b:ea:06:92:c5:a0:0d:d6
Feb 22 15:46:02 runeaudio dhcpcd[1129]: eth0: IAID eb:18:8c:ad
Feb 22 15:46:02 runeaudio dhcpcd[1129]: eth0: rebinding lease of 172.16.1.136
Feb 22 15:46:02 runeaudio dhcpcd[1129]: eth0: probing address 172.16.1.136/16
Feb 22 15:46:07 runeaudio dhcpcd[1129]: eth0: leased 172.16.1.136 for 86400 seconds
Feb 22 15:46:07 runeaudio dhcpcd[1129]: eth0: adding route to 172.16.0.0/16
Feb 22 15:46:07 runeaudio dhcpcd[1129]: eth0: adding default route via 172.16.1.10
Feb 22 15:46:07 runeaudio avahi-daemon[222]: Joining mDNS multicast group on interface eth0.IPv4 with address 172.16.1.136.
Feb 22 15:46:07 runeaudio avahi-daemon[222]: New relevant interface eth0.IPv4 for mDNS.
Feb 22 15:46:07 runeaudio avahi-daemon[222]: Registering new address record for 172.16.1.136 on eth0.IPv4.
Feb 22 15:46:07 runeaudio dhcpcd[1129]: forked to background, child pid 1175
Feb 22 15:46:07 runeaudio ifplugd[219]: client: Started network profile 'eth0'
Feb 22 15:46:07 runeaudio ifplugd[219]: Program executed successfully.
Feb 22 15:46:08 runeaudio ntpd[278]: Listen normally on 2 eth0 172.16.1.136:123
Feb 22 15:46:08 runeaudio ntpd[278]: new interface(s) found: waking up resolver
Mar 27 08:24:34 runeaudio systemd[1]: Time has been changed
Mar 27 08:25:51 runeaudio sshd[1242]: Accepted password for root from 172.16.1.124 port 58487 ssh2
Mar 27 08:25:51 runeaudio sshd[1242]: pam_unix(sshd:session): session opened for user root by (uid=0)
Mar 27 08:25:51 runeaudio dbus[224]: [system] Activating via systemd: service name='org.freedesktop.login1' unit='dbus-org.freedesktop.login1.service'
Mar 27 08:25:51 runeaudio dbus[224]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.login1.service': Unit systemd-logind.service is masked.
Mar 27 08:25:51 runeaudio sshd[1242]: pam_systemd(sshd:session): Failed to create session: Unit systemd-logind.service is masked.
