skrodahl wroteHope you're recovering from the soldering iron accident..... If you keep on soldering, you will realize that it happens quite too often...
Yes thanks ..... "it's just a flesh wound"
Well I built the second JFET Pre-Amp and while the sound is just great again I still get the POP, but building this has been a great exercise and have really enjoyed it, Skrodahl you are so correct.
Funnily this cheap little preamp has created quite an associated expense trail of it own...... soldering iron, soldering iron holder, brass tip cleaner, pcb holder with magnifying glass, multimeter, Dremel type tool, small suction vice ....... is there no end to the great gadgets .....
skrodahl wroteI have another omg, omg, omg, omg, OMG!!!! moment going here. The P88 preamp is installed, and it works beautifully
Sensational, congratulations....... you do sound reasonably happy about this !!!
skrodahl wroteI thought the Audiobah TPA2116 amp delivered a very detailed and clear sound. Playing vinyl was even better than the sound from RuneAudio, which made me suspect that a preamp would be nice.
My suspicions were absolutely correct. The level of details, the highs, the lows, the mids, the "blackness" of the silence, the positioning of every possible sound and instruments. It is just unbelievable. There might come a day when I find something better, but I seriously doubt that right now.
Ok .... I'm convinced a Rob Elliot Project 88 is the next bit of fun, thanks Skrodahl for all the ideas, hope you don't mind me copying your path
but, it's great to learn from someone who knows about this stuff !
I really wasn't looking for a balance control, could this be excluded ? .... but suppose I could use a small pot so as not to be too intrusive.
