Does anybody had issues with AirPlay and external USB DAC?
I had a silence when try to play some music over AirPlay with connected USB DAC.
I notice that when i try to change AirPlay name to OdroidC2Airplay in web-ui it changed only in web-ui. iTunes still sees my C2 as RuneAudioAirplay. I suspect this is because of read only fs, but after reboot - nothing changed.
So i login in SSH and did:
nano /usr/lib/systemd/system/shairport.service
This is what i get:
ExecStart=/usr/bin/shairport -w --name=RuneAudioAirplay --on-start=$ON --on-stop=$OFF --meta-dir=/var/run/shairport -o alsa -- -d plughw:0,0
My DAC is plughw:1,0, but in shairport.service alsa is set to plughw:0,0, even when Audio output interface is set to my USB DAC.
So i changed .service file for my needs, daemon-reload, service restart and now i've got sound over AirPlay.
ExecStart=/usr/bin/shairport -w --name=OdroidC2Airplay --on-start=$ON --on-stop=$OFF --meta-dir=/var/run/shairport -o alsa -- -d plughw:1,0
But I suspect that this should work the other way.
Is this a bug, Frank?
