Hi Andre,
sorry i missed your post.
1. need to enter cache to clear http://myip\dev every other period of time?
Because of what? What is the problem?
2.default-encoding=ISO-8859-1 <-- Non English will be garbled.(>_<;)
Not only English will work, but you are right we should change this to UTF-8.
ISO 8859-1 encodes what it refers to as "Latin alphabet no. 1," consisting of 191 characters from the Latin script. This character-encoding scheme is used throughout the Americas, Western Europe, Oceania, and much of Africa. It is also commonly used in most standard romanizations of East-Asian languages. 6.7% of all web pages use ISO 8859-1 in February 2016.[2]
Each character is encoded as a single eight-bit code value. These code values can be used in almost any data interchange system to communicate in the following European languages (with a few exceptions due to missing characters, as noted):
Modern languages with complete coverage
Afrikaans
Albanian
Basque
Breton
Corsican
Danish[a]
English[b]
Faroese
Galician
German
Icelandic
Indonesian
Italian
Kurdish[c]
Leonese
Luxembourgish[d]
Malay[e]
Manx
Norwegian[f]
Occitan
Portuguese[g]
Rhaeto-Romanic
Scottish Gaelic
Spanish
Swahili
Swedish
Walloon
3. Can use 3.5 inches LCD screen MODE PI2B in SPI?
This should work, but i do not think that it will make sense.
The resolution on this small display only is 320px X 240px.
4. this picture. Using the HDMI connection?
This image (RuneAudio version) is made especially for the 7" TFT, but it also works perfect on bigger screens.
The picture you posted here is from an other project. The output (current song, artist, album and cover art)
comes from a python script that i wrote for this project.
5. Can make the LCD screen not show "volume control"? Just like this one on the photo..
and don't stand up
At the moment it is not possible to disable controls on the UI without modifying the code.
6. MPD play a FILE PI WAV will appear on the card dead light... And will not restore
their own, must be forced to re boot to restore,
This is strange and should not happen.
Your memory gets eaten up by something.
Please try to find the relevant process with "top" or "ps aux --sort -rss"
[root@runeaudio ~]# ps aux --sort -rss
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 555 6.7 7.6 195528 72068 ? SNl 16:59 2:06 midori -p -e Fullscreen http://localhost
mpd 375 0.2 2.3 117380 22536 ? Ssl 16:59 0:04 /usr/bin/mpd --no-daemon
root 468 0.0 1.4 33576 14132 tty2 S<s+ 16:59 0:00 /usr/lib/xorg-server/Xorg :0
ntp 255 0.0 1.4 15076 13372 ? SLs 16:59 0:00 /usr/bin/ntpd -g -u ntp:ntp
root 324 0.0 1.3 38120 13008 ? SNs 16:59 0:00 /usr/bin/smbd -D
root 268 0.1 1.3 31208 12740 ? SNs 16:59 0:03 /usr/bin/php /var/www/command/rune_SY_wrk
root 248 0.0 1.3 40396 12600 ? SNs 16:59 0:00 /usr/bin/php /var/www/command/rune_PL_wrk
root 430 0.0 1.2 33404 12156 ? Ss 16:59 0:00 php-fpm: master process (/etc/php/php-fpm.conf)
root 437 0.0 1.2 30936 12136 ? SN 16:59 0:00 /usr/bin/php /var/www/command/cmd_async L3Vzci9iaW4vc3VkbyAvdXNyL2Jpbi94aW5pdA==
http 431 0.0 1.1 33784 10660 ? S 16:59 0:00 php-fpm: pool display
