pduerden wroteHi there
I hope you can help. I'm a Linux newbie but have managed to get 0.3beta for Raspberry PI installed and working. I can use the web interface and also MPDroid to control the PI remotely.
I've got to say it was all pretty straight forward and easy, thank you to all involved.
I'm having an issue with Album art in the Rune UI and MPDroid. I would like to use my local covers. I have read this thread and set MPDroid as follows
Download local cover art = <checked>
Path to music = coverart
Cover filename = <whatever you want> (I have set this to cover.jpg as per my naming convention)
My guess is the path is incorrect but I'm not sure what to set it to. My library structure is
<IP Address>/My Music/Artist Name/Album Name
It also mentions that I may need to use git pull to update PHP settings. I'm not sure if this is required or if it was included in the beta.
Are there other steps I am missing and should be following?
With regard to the RuneUI I'm not sure why it is not picking up the covers or if there is a setting I should use. It is getting some covers but they appear to be downloaded over the web.
Cheers
Phil
Im using /covers for the path and it works for me. Have you tried with the /?
Regards,
