thanhvo31 wrote
Still no luck with hires file, try to double buffer size and before play.
Hi Thanh,
you are using the HRT streamer right? Which will do up to 96Khz, correct?
Now this needs to be checked, but I suppose that when you wish to play HiRes, mpd would resample and maybe this is were your trouble starts. Resampling can be controlled by the samplerate_converter setting in mpd.conf, which is missing. I think it should be
samplerate_converter "Fastest Sinc Interpolator"
Perhaps resampling now defaults to a resource-hungry value.
@[deleted]: will adding the parameter manually work, just to test it?
EDIT: I will test this tomorrow with a FIIO E18, it also has 96Khz as an upper limit
EDIT 2: Quick test and no pops, clicks, but hickups every couple of seconds, rest will follow tomorrow as promised
Gé
