Hi Simone
Thank you for your continued support on this.
The changes did have some effect but the device is still not available in the dropbox of RuneUI.
The effect of the changes is that my device is enabled in the mpd.conf, but the dropbox still only shows the Null (test output) even though that device is now shown as not enabled in mpd.conf
I did follow your instructions about resetting mpd config and reboot as well, via MPD Configuration hyperlink "reset to default" and menu option turn off/reboot. Also tried powerdown and power up a few times.
Linux version 3.12.6-2-ARCH (nobody@root-chroot-copy) (gcc version 4.7.2 (GCC) ) #1 SMP Mon Jan 6 12:59:03 MST 2014
system load: 0.00 0.01 0.05 1/77 760
HW platform: BeagleBone Black (04)
playerID: 04e982c18599446a162f6ba2f08b9e05a8
Advanced Linux Sound Architecture Driver Version k3.12.6-2-ARCH.
0 [hiFace ]: snd-usb-hiface - hiFace
hiFace at usb-musb-hdrc.1.auto-1
ALSA interface #0: (/proc/asound/card0/pcm0p/info)
card: 0
device: 0
subdevice: 0
stream: PLAYBACK
subname: subdevice #0
class: 0
subclass: 0
subdevices_count: 1
subdevices_avail: 1
ALSA interface #1: (/proc/asound/card1/pcm0p/info)
interface #0 stream status: (/proc/asound/card0/stream0)
no stream present
interface #1 stream status: (/proc/asound/card1/stream0)
no stream present
Module = "snd_usb_audio"
Attributes:
coresize = "112254"
initsize = "0"
initstate = "live"
refcnt = "0"
taint = ""
uevent =
Parameters:
autoclock = "Y"
device_setup = "0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"
enable = "Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y"
id = "(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)"
ignore_ctl_error = "N"
index = "0,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
nrpacks = "3"
pid = "-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
vid = "-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
Sections:
.ARM.exidx.exit.text= "0xbf140e94"
.ARM.exidx.init.text= "0xbf140e8c"
.ARM.exidx = "0xbf143334"
.ARM.extab = "0xbf1432bc"
.ARM.extab.init.text= "0xbf140e80"
.bss = "0xbf1471e4"
.data = "0xbf143898"
.exit.text = "0xbf13f19c"
.gnu.linkonce.this_module= "0xbf147080"
.init.text = "0xbf150000"
.note.gnu.build-id = "0xbf143874"
.rodata = "0xbf13f1a8"
.rodata.str1.1 = "0xbf140f2c"
.strtab = "0xbf155328"
.symtab = "0xbf150048"
.text = "0xbf133000"
__param = "0xbf140e9c"
hardware platform: BeagleBone Black
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 4500000
rootfs / rootfs rw 0 0
devtmpfs /dev devtmpfs rw,relatime,size=253580k,nr_inodes=63395,mode=755 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=27,pgrp=1,timeout=300,minproto=5,maxproto=5,direct 0 0
tmpfs /sys/fs/cgroup tmpfs rw,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpuacct,cpu 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
cgroup /sys/fs/cgroup/net_cls cgroup rw,nosuid,nodev,noexec,relatime,net_cls 0 0
tmpfs /tmp tmpfs rw 0 0
/dev/root /var/tmp ext4 rw,relatime,data=ordered 0 0
//192.168.178.41/Klassiek /mnt/MPD/Klassiek cifs ro,relatime,vers=1.0,sec=ntlm,cache=strict,uid=45,forceuid,gid=45,forcegid,addr=192.168.178.41,file_mode=0755,dir_mode=0755,nounix,serverino,rsize=16384,wsize=16384,actimeo=1 0 0
log_level "default"
zeroconf_name "runeaudio"
audio_buffer_size "512"
buffer_before_play "0%"
auto_update "no"
mixer_type "none"
enabled "no"
name "USB-Audio"
dsd_usb "yes"
enabled "no"
type "null"
name "Null"
###### PHP backend ######
php version: 5.5
debug level: 2
###### SESSION ######
STATUS: 1
SAVE PATH: /run
###### SESSION DATA ######
Array
[orionprofile] => RuneAudio
[cmediafix] => 0
[playmod] => 0
[ramplay] => 0
[sessionid] => 9n9h15f2l563cnoq5r3hd3oc56
[mpdconfhash] => d5085246fb4f61782e3631b036d40529
[lastfm_apikey] => ba8ad00468a50732a3860832eaed0882
[netconfhash] => 643f8967af551f683b3cfd493950c550
[mpdconf_advanced] => 0
[netconf_advanced] => 0
[dev] =>
[sourceconfhash] => d41d8cd98f00b204e9800998ecf8427e
[sourceconf_advanced] => 1
[debug] => 2
[hiddendebug] => 0
[opcache] => 1
[playerid] => 04e982c18599446a162f6ba2f08b9e05a8
[hwplatform] => BeagleBone Black
[hwplatformid] => 04
[airplay] => 0
[scrobbling_lastfm] => 0
[scrobbling_librefm] => 0
[scrobbling_jamendo] => 0
[spotify] => 0
[db_version] => 1.2
[udevil] => 1
[coverart] => 1
[volume] => 0
[ao] => 0
[ntpserver] => ntp.inrim.it
[hostname] => runeaudio
[w_queue] =>
[w_queueargs] =>
[w_lock] => 0
[w_active] => 0
[w_jobID] =>
[debugdata] =>
[netconf] => Array
[eth0] => Array
[ip] => 192.168.178.53
Page created in 0.13233 seconds.
Cheers
Aleg
