This evening I upgraded my new BBB to the latest Angstrom distro and installed RuneAudio.
Just like the original poster my USB-SPDIF converter doesn't show up in the list of audio devices in RuneGUI.
Just Null (test output) is shown.
aplay -l does show my device and also the generated mpd.conf shows my device, but it is not enabled according to mpd.conf.
Do I need to enable my device manually or is it turned off for a reason?
If to be done manually where does it need to be changed becaue the mpd.conf says it is an auto generated file.
Thank you for your assistance
Cheers
Aleg
Debug info:
Linux version 3.12.6-2-ARCH (nobody@root-chroot-copy) (gcc version 4.7.2 (GCC) ) #1 SMP Mon Jan 6 12:59:03 MST 2014
system load: 0.16 0.05 0.06 1/84 1323
HW platform: BeagleBone Black (04)
playerID: 04e982c18599446a162f6ba2f08b9e05a8
Advanced Linux Sound Architecture Driver Version k3.12.6-2-ARCH.
0 [hiFace ]: snd-usb-hiface - hiFace
hiFace at usb-musb-hdrc.1.auto-1
ALSA interface #0: (/proc/asound/card0/pcm0p/info)
card: 0
device: 0
subdevice: 0
stream: PLAYBACK
subname: subdevice #0
class: 0
subclass: 0
subdevices_count: 1
subdevices_avail: 1
ALSA interface #1: (/proc/asound/card1/pcm0p/info)
interface #0 stream status: (/proc/asound/card0/stream0)
no stream present
interface #1 stream status: (/proc/asound/card1/stream0)
no stream present
Module = "snd_usb_audio"
Attributes:
coresize = "112254"
initsize = "0"
initstate = "live"
refcnt = "0"
taint = ""
uevent =
Parameters:
autoclock = "Y"
device_setup = "0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"
enable = "Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y"
id = "(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)"
ignore_ctl_error = "N"
index = "0,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
nrpacks = "3"
pid = "-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
vid = "-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
Sections:
.ARM.exidx.exit.text= "0xbf140e94"
.ARM.exidx.init.text= "0xbf140e8c"
.ARM.exidx = "0xbf143334"
.ARM.extab = "0xbf1432bc"
.ARM.extab.init.text= "0xbf140e80"
.bss = "0xbf1471e4"
.data = "0xbf143898"
.exit.text = "0xbf13f19c"
.gnu.linkonce.this_module= "0xbf147080"
.init.text = "0xbf150000"
.note.gnu.build-id = "0xbf143874"
.rodata = "0xbf13f1a8"
.rodata.str1.1 = "0xbf140f2c"
.strtab = "0xbf155328"
.symtab = "0xbf150048"
.text = "0xbf133000"
__param = "0xbf140e9c"
hardware platform: BeagleBone Black
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 4500000
rootfs / rootfs rw 0 0
devtmpfs /dev devtmpfs rw,relatime,size=253580k,nr_inodes=63395,mode=755 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=27,pgrp=1,timeout=300,minproto=5,maxproto=5,direct 0 0
tmpfs /sys/fs/cgroup tmpfs rw,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpuacct,cpu 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
cgroup /sys/fs/cgroup/net_cls cgroup rw,nosuid,nodev,noexec,relatime,net_cls 0 0
tmpfs /tmp tmpfs rw 0 0
/dev/root /var/tmp ext4 rw,relatime,data=ordered 0 0
//192.168.178.41/Klassiek /mnt/MPD/Klassiek cifs ro,relatime,vers=1.0,sec=ntlm,cache=strict,uid=45,forceuid,gid=45,forcegid,addr=192.168.178.41,file_mode=0755,dir_mode=0755,nounix,serverino,rsize=16384,wsize=16384,actimeo=1 0 0
log_level "default"
zeroconf_name "runeaudio"
audio_buffer_size "512"
buffer_before_play "0%"
auto_update "no"
mixer_type "none"
enabled "no"
enabled "no"
name "USB-Audio"
dsd_usb "yes"
type "null"
name "Null"
