Probably a stupid question but I'll ask anyway
Re: Probably a stupid question but I'll ask anyway
Postby matt » 16 Oct 2014, 19:37
So the case arrived yesterday, and I am feeling a little silly. Even though its still pretty compact it just seems way too empty with the pi and my pretend power supply (still waiting for the real one) in it.
I think I"ll go with the 0905 case skrodahl has used but I really want a power switch on it somehwere.
skrodahl - do you think I could squeeze on of these in on the front panel?
matt
Postby skrodahl » 16 Oct 2014, 22:57
-skrodahl
skrodahl
Moderator
Postby matt » 17 Oct 2014, 02:18
matt
Postby matt » 17 Oct 2014, 02:44
I picked up a couple of panel mount RCA sockets and asked for some shielded wire with which to hook them up. I was given some that has 7x0.12 printed on it.
I believe the 7 refers to the number of strands of wire and the 0.12 is the diameter. It seems very thin. Will it be ok?, it will be going between hifiberry dac+ and the RCA sockets.
matt
Postby skrodahl » 17 Oct 2014, 05:53
My shielded signal cable is so thin that my wire stripper can't remove its insulation. It works great though. You'll run a signal of 2-3 volts at a few milliamperes through them. No problem at all.
-skrodahl
skrodahl
Moderator
Return to DIY and tweaks
