Webradio stream help
Download (hi-res) albums/tracks for free
Postby boydwilluk » 23 Apr 2016, 15:09
Can anyone help with a web radio station problem.
I am trying to connect to a local UK station called Two Lochs Radio
If I enter the following stream in VLC, or iTunes, it works. But it does not work when I enter it in Runeaudio.
http://149.255.59.164:8020/stream
(I have lots of other stations working, so it is not a connection, hardware or software problem, just some sort of problem with the link.)
Boydwilluk
boydwilluk
Re: Wed radio stream help
Postby hondagx35 » 23 Apr 2016, 17:45
Hi boydwilluk,
your URL works perfect with my setup.
I also added "Two Loch Radio" to the Dirble station list.
Postby rikardo1979 » 23 Apr 2016, 18:04
if your radio does not work when you adding through the web GUI try to add it manually into /mnt/MPD/Webradio
so for this radio unpack this and copy into that folder
Two Lochs Radio.pls.7z
(207 Bytes) Downloaded 861 times
rikardo1979
Re: Webradio stream help
Postby boydwilluk » 24 Apr 2016, 10:37
Hello Frank,
This is very strange!
I checked the entry in /mnt/MPD/Webradio. It is Two Lochs Radio.pls, and the contents are correct. But the station does not play.
I then tried your new entry on Dirble - still won't play.
I tried adding a new entry to the list, with a different title, but same URL - it still won't play.
Boyd.
boydwilluk
Postby hondagx35 » 24 Apr 2016, 13:10
Postby boydwilluk » 26 Apr 2016, 09:38
Hello Frank,
The station name displays correctly, the time circle advances, but there is no sound.
I have attached a screen shot.
Boyd.
boydwilluk
Postby boydwilluk » 21 Sep 2016, 13:48
Hello Frank,
I had another attempt at fixing this problem today.
I discovered that if I use the following URL, Two Lochs Radio works on my Raspbery Pi / HiFiBerry / Runeaudio setup
http:149.255.59.164:8034/stream - this stream is in aacPlus/AAC format
the original stream that I could not get to work - http:149.255.59.164:8020/stream is in mp3 format.
Any suggestions as to why one stream works, but not the other?
Regards
Boydwilluk
boydwilluk
Postby hondagx35 » 21 Sep 2016, 19:43
Postby sangohan » 30 Nov 2016, 14:25
Thx to you it works perfect
Iphone Music Only
sangohan
Postby foster17 » 03 Feb 2019, 16:06
I listened to him, to be honest, I didn't like it very much.
foster17
Return to Free resources
