16bit 44.1kHz problem (solved)
Your personal reference audiophile recording used to test Hi-Fi equipment
Postby hardy » 31 Aug 2016, 20:15
I use a Diy dac with a PCM1794 chip on a raspberry pi3, it works fine with 24 bit mp3-44.1kHz , 24bit flac 96Khz and also 24-192Khz, but with standard 16bit CD 44.1kHz, there is no sound.
When I use openelec on the pi, then I can use all the difference music files with no problem, but I wil use RUNE :D
I use the Hifiberry settings.
My DAC is similar to this one. http://www.tjaekel.com/T-DAC/schematics.html
How can I change any settings to solve this problem?
Hardy
hardy
Re: 16bit 44.1kHz problem
Postby hondagx35 » 31 Aug 2016, 21:39
Postby hardy » 01 Sep 2016, 20:10
Thanks Frank for the quick response , its working perfectly now .
Hardy
hardy
Return to Audiophile test tracks
