When the system starts up it works normally, but after a little while the webpage becomes unresponsive and CPU usage for php-fpm goes up to 100%. After a while the CPU usage goes back to normal, but the webui just gives me a blank page.
Earlier i tried to do a "pacman -Syu" to update several components bu after that the system became unusable as well and I had to reinstall..
Tia,
Daf
Linux version 3.6.11-18-ARCH+ (nobody@) (gcc version 4.7.2 (GCC) ) #1 PREEMPT Mon Oct 21 01:15:42 CDT 2013
system load: 0.07 0.17 0.13 2/94 662
HW platform: RaspberryPi (01)
playerID: 01498ab1f026f6b37efa70c101060a99a9
Advanced Linux Sound Architecture Driver Version 1.0.25.
1 [ALSA ]: BRCM bcm2835 ALSbcm2835 ALSA - bcm2835 ALSA
bcm2835 ALSA
ALSA interface #0: (/proc/asound/card0/pcm0p/info)
ALSA interface #1: (/proc/asound/card1/pcm0p/info)
card: 1
device: 0
subdevice: 0
stream: PLAYBACK
subname: subdevice #0
class: 0
subclass: 0
subdevices_count: 8
subdevices_avail: 7
interface #0 stream status: (/proc/asound/card0/stream0)
no stream present
interface #1 stream status: (/proc/asound/card1/stream0)
no stream present
Module = "snd_usb_audio"
Attributes:
coresize = "104025"
initsize = "0"
initstate = "live"
refcnt = "0"
srcversion = "DA9A78F56D873AB02CB47F0"
taint = ""
uevent =
Parameters:
async_unlink = "Y"
device_setup = "0,0,0,0,0,0,0,0"
enable = "Y,Y,Y,Y,Y,Y,Y,Y"
id = "(null),(null),(null),(null),(null),(null),(null),(null)"
ignore_ctl_error = "N"
index = "0,-1,-1,-1,-1,-1,-1,-1"
nrpacks = "3"
pid = "-1,-1,-1,-1,-1,-1,-1,-1"
vid = "-1,-1,-1,-1,-1,-1,-1,-1"
Sections:
.ARM.exidx.exit.text= "0xbf16dd2c"
.ARM.exidx.init.text= "0xbf16dd24"
.ARM.exidx = "0xbf170144"
.ARM.extab = "0xbf1700d8"
.ARM.extab.init.text= "0xbf16dd18"
.bss = "0xbf173b2c"
.data = "0xbf1705f0"
.exit.text = "0xbf16c534"
.gnu.linkonce.this_module= "0xbf1739c4"
.init.text = "0xbf17c000"
.note.gnu.build-id = "0xbf1705cc"
.rodata = "0xbf16c540"
.rodata.str1.4 = "0xbf16ddc4"
.strtab = "0xbf180ec8"
.symtab = "0xbf17c048"
.text = "0xbf161000"
__param = "0xbf16dd34"
hardware platform: RaspberryPi
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 1500000
rootfs / rootfs rw 0 0
/dev/root / ext4 rw,noatime,nouser_xattr,errors=remount-ro,data=ordered 0 0
devtmpfs /dev devtmpfs rw,relatime,size=84748k,nr_inodes=21187,mode=755 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=30,pgrp=1,timeout=300,minproto=5,maxproto=5,direct 0 0
tmpfs /sys/fs/cgroup tmpfs rw,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpuacct,cpu 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
cgroup /sys/fs/cgroup/net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_prio 0 0
Ramdisk /run/shm tmpfs rw,nosuid,nodev,noexec,relatime,size=262144k 0 0
tmpfs /tmp tmpfs rw 0 0
rpc_pipefs /var/lib/nfs/rpc_pipefs rpc_pipefs rw,relatime 0 0
/dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
/dev/root /var/tmp ext4 rw,noatime,nouser_xattr,errors=remount-ro,data=ordered 0 0
//192.168.1.12/Media/media/Music /mnt/MPD/DiskStation cifs ro,relatime,vers=1.0,sec=ntlm,cache=strict,unc=\\192.168.1.12\Media,username=dafart,uid=45,forceuid,gid=45,forcegid,addr=192.168.1.12,unix,posixpaths,serverino,acl,rsize=16384,wsize=16384,actimeo=1 0 0
log_level "default"
zeroconf_name "runeaudio"
audio_buffer_size "512"
buffer_before_play "0%"
auto_update "yes"
mixer_type "disabled"
enabled "no"
enabled "no"
name "USB-Audio"
dsd_usb "yes"
enabled "no"
type "null"
name "Null"
device "hw:1,0"
name "AnalogJack/HDMI"
###### PHP backend ######
php version: 5.5
debug level: 2
###### SESSION ######
STATUS: 1
SAVE PATH: /run
###### SESSION DATA ######
Array
[orionprofile] => RuneAudio
[cmediafix] => 0
[playmod] => 0
[ramplay] => 0
[sessionid] => lhl5fk4ukhpfruqablqsku1bo1
[mpdconfhash] => db7923dc590449bef162b5ebcb72efa1
[lastfm_apikey] => ba8ad00468a50732a3860832eaed0882
[netconfhash] => 643f8967af551f683b3cfd493950c550
[mpdconf_advanced] => 0
[netconf_advanced] => 0
[dev] =>
[sourceconfhash] => d41d8cd98f00b204e9800998ecf8427e
[sourceconf_advanced] => 1
[debug] => 2
[hiddendebug] => 0
[opcache] => 1
[playerid] => 01498ab1f026f6b37efa70c101060a99a9
[hwplatform] => RaspberryPi
[hwplatformid] => 01
[airplay] => 1
[scrobbling_lastfm] => 1
[scrobbling_librefm] => 0
[scrobbling_jamendo] => 0
[spotify] => 0
[db_version] => 1.2
[udevil] => 1
[coverart] => 1
[volume] => 0
[ao] => 3
[ntpserver] => ntp.inrim.it
[hostname] => runeaudio
[w_queue] =>
[w_queueargs] =>
[w_lock] => 0
[w_active] => 0
[w_jobID] =>
[debugdata] =>
[netconf] => Array
[eth0] => Array
[ip] => 192.168.1.30
[state] => play
[notify] =>
Page created in 1.72271 seconds.
