paulg05 wrote1 - My PiFi Digi + card is not giving any audio Output ( I've been told it needs to be turned on - so to speak )
You have to load the correct I2S module to make it work. We included the most common I2S modules to be easily selected and loaded in the Settings section. This is the first time I see that card, so my advice is to try to load the HiFiBerry Digi module and see if it works with that.
paulg05 wrote2 - For some reason Runeaudio isn't saving my login details on my Edimax EW-7711UAn wireless USB Adaptor. ( It see's the home network but wont save the wireless password
Could you test the same on a fresh install after switching to the "dev" branch,
following these instructions?
paulg05 wrote3 - My Raspberry Pi Isn't recognising my powered HDD ( the unit is powered by a seperate powered USB hub )
Usually I would bet on a power issue, so double check the USB hub. Which filesystem does the HDD use?
