hondagx35 wroteHi unameme,
your wifi dongle needs the rtl8188 driver.
This driver is not installed by default on runeaudio.
You can do this by executing:
pacman -S dkms-8188eu
It would be best to install a fresh copy of the actual image, because you already changed some things.
frank
That helped! For now, the connection is very stable(not many hours of testing yet), and transfer rates are very good, over 1Mb/s
hondagx35 wroteHi all,
I'm experiencing extremely heavy static when playing back MP3s
Someone else with sound problems on Raspberry Pi 2?
No problems, I'm using IQaudio DAC+, quality is superb, no other sounds, noises or crackle.
I have a standard 2,5" 160GB disc connected to the usb - single usb cable - works!
Tested radios from dirble, SMB server, and the hdd, mp3s, flacs no problem at all
Now what's wrong:
- my SD card is 8GB and df -h shows 2GB
- i cannot add radio stream, tried many formats, pls, m3u, asx, just ip+port nr. no luck or I don't know how to do it
- no airplay/dlna, I turned it on in UI, but I cannot stream music from my phone using nokia play to(it works on volumio) and my computer using foobar2000(with UPnP media renderer output - this worked with android phone &bubble UPnP, I could play music directly from foobar to phone). In foobar and Nokia play to RuneAudio is not visible at all as an output.
