Really like this project. Got it going no problem on my RPi, but really want it on my BBB and having some problems. In short:
Downloaded the image and flashed it to the SD no problem;
Put it in the BBB and start it up, all the indicator lights turn on and then I can't get anything out of it. No IP listed on my network, no connection to the webUI, no IP address to ssh to (tried a few likely candidates, to no avail) and no signal from HDMI to access console directly. Tried typing blindly at the keyboard, hoping I might be able to login and do something, but no response at all.
My setup is:
[list=]
BeagleBone Black
Wired ethernet connection
Powered USB hub
USB DAC and USB keyboard connected to the hub
Power to the board from a different powered USB hub
Monitor via micro HDMI adaptor cable
[/list]
Also tried with a cut back setup with only USB DAC and ethernet connected (directly, no hub) but that behaved exactly the same.
Also tried downloading the image again and writing it fresh, but still the same. I'm using a 16Gb SanDisk Ultra microSD and writing it on MacOSX with:
sudo dd bs=1m if=/path/to.img of=/dev/rdisk2
Card is erased and formatted as FAT32 first. MBR partition scheme.
Any help much appreciated, love RuneAudio from playing around on the Pi, but I'd love to have it on the BBB.
Jack
