Here is my report (I'm using a RPi B+ with Hifiberry DAC+) :
- It's sad that we can't navigate through albums and artists with RuneAudio, but I read somewhere that you already know that and can't do better by now because of Spotify
#6351
- I'm using a Hifiberry Dacplus and after each reboot, I gotta go to the options to set it back to default. Isn't there any way to fix it by ourselves before the next patch gets out ?
Try the other HiFiBerry setting, the one without plus sign.
I use Audiophonics saber and that setting works OK, the other one switches itself off after reboot.
- I just can't use usb-key. When I plug it on, it gets recognized on web interface, but when I click on it under Libraby, nothing happens. I tried to format it with Gparted as Fat32, tried to put FLAC and MP3 aswell, even on the root, nothing used to work.
Rebuild your library in sources and set Auto update option in MPD settings...
- I can't set a static ip adress, but this issue was already reported ; I used the MAC adress thing to have the same IP at each boot.
Install Bonjour on your machine, you also get it by installing iTunes, and then you can use runeaudio.local instead of IP address
