Hi fuddyduddy,
You seem to have gone back several steps and you have not explained what you have done. What is described below in this post has been previously described in this thread. Just to manage your expectations, I will not explain it a third time.
Log in via SSH, and run the following command (
the command is one line):
echo '//192.168.1.102/My\040Music /mnt/MPD/NAS cifs ro,vers=3.0,cache=none,username=rober,password=secret 0 0' >> /etc/fstab
Modify your username and password
before executing the command!
To check that is has worked run this command:
grep -i cifs /etc/fstab
The output should be one line and look like this:
Then reboot and check that the mount is listed with this command:
grep -i cifs /proc/mounts
The output should look like this:
If it is there, then go to the Sources UI and click on ‘Rebuild MPD Library’ to load your music.
If you screw up, please restore the /etc/fstab from the copy which you made. Use this command:
cp /home/fstab /etc/fstab
Then start again.
If you get stuck, post the output of this command (
first remove your password from the output):
cat /etc/fstab
