I know what I hear and my ears are not easily fooled , I build a lot of audio equipment and after soldering , there is a lot of listening
I use a hybrid tube / mosfet amp which takes a while to settle so for me after a few minutes is what it takes
In a switchmode supply , all that is between the mains and their amp etc is the enamel wire insulation and inter-section tape insulation within the flyback transformer . That has got to couple more crud from the mains than a split bobbin EI transformer . probably the reason for better sound . I used a search coil a few years ago and found some cheap Chinese power supplies emitted a lot of nasties
With the choke input supply , far lower peak current so reservoir capacitors are less stressed . Same goes for the mains transformer , I have not powered down the supply since it was built , the transformer is hardly warm at all . Benefits all round...
cheers
Nic
