jonas18z I connected a USB-stick and removed it but can't unmount it. How do I remove it?Attachmentsdaym.png (61.49 KiB) Viewed 4821 times
cmh714 well I've never had trouble unmounting via the command line so you could try that... umount /dev/sda1
jonas18z Nope, still visible in runeaudio [root@runeaudio ~]# umount /dev/sda1 umount: /dev/sda1: mountpoint not found [root@runeaudio ~]#
hondagx35 Hi jonas18z, please try to remove it from the database: redis-cli hdel usbmounts "/dev/sda1" and rm -r /mnt/MPD/USB/sda1-usb....your-folder-name
spikey1973 Sorry I have the same issue but i read this topic and kinda get stuck ate the end.. redis-cli hdel usbmounts "/dev/sda1" -> returns 1 rm -r /mnt/MPD/USB/sda1-usb....your-folder-name -> what folder name, it's about a drive /stick, not a folder.. sorry but i don't get it. i ssh-ed into the rpi, so am at root@runeaudio.. maybe that is wrong as i only have these folders/files returned when i list the root. airplay dev-netsurf shairport.php kind regards Matthieu
wadada I had the same issue on runeaudio 0.4 (build: beta-20141216) and solved as following. First of all Samba Share needs to be enabled (not sure but I think this is the default). Browse via File Manager to Network/runeaudio/music_store/USB (or as shown on Nautilus under Ubuntu 16.04: smb://runeaudio.local/music_store/USB) There I found several folders of USB mounts I removed long time ago. Just delete the folders and the dead links are gone for good.
