Orion wrotechromisdesigns wroteMy understanding is that the Cubox and Cubox-i, while similar, won't run each other's compiled code, so if you intend to support both, there would need to be separate releases for them.
I have the second-generation "original" Cubox, model 3b-300-p, which I hope you will be supporting, as well as the newer I-series.
Hi, I'm building the distro on a CB-300-P CuBox, i think is quite similar to your model.
Simone
Thanks, Simone. Mine is the same one, just had a typo in the original post! Looking forward to trying it.
While I have you on the line...I've had problems getting the Cubox to recognize an external usb disk formatted and populated from my Windows PC, both trying to install a Logitech Media Server distro, as well as with Volumio. I suspect it's a file permission issue, but don't know. Can you check this issue with your new distro for Cubox, before publishing it?
The symptoms are, the software on Cubox will play internet radio just fine, but either doesn't recognize the usb disk is there at all, or else can't read the files. Same thing happens with a usb stick when I copy files to it from the PC, then try to use it on the cubox. My music files are all FLAC, if it makes a difference, but I suspect it does not.
