Due to these observations I reviewed my MPD configuration.
The configuration described previously it seamed that convert
everything (by upsampling or downsampling) to 24/192 - the maximum value of my dac.
In order to have the less possible conversions I modified my audio_output to this :
name "snd_allo_digione"
mixer_type "none"
And kept the :
resampler {
plugin "soxr"
quality "very high"
With these settings alsa is handling the native sample rate up to my Dac capabilities.
Above those, the SoXR make the downsampling to the maximum possible (24/192).
Here part of my log
Nov 12 14:56 : client: [282] process command "play"
Nov 12 14:56 : playlist: play 0:"NAS/Audiophile_Recordings/_Test_Files/Varius Sample Rate Files/original CD 16BIT_44kHz/2L-139_01_stereo_01.cd.flac"
Nov 12 14:56 : client: [282] command returned 0
Nov 12 14:56 : playlist: queue song 1:"NAS/Audiophile_Recordings/_Test_Files/Varius Sample Rate Files/Stereo 24BIT_96kHz/2L-139_stereo_FLAC_88k_24b_01.flac"
Nov 12 14:56 : client: [282] process command list
Nov 12 14:56 : client: process command "status"
Nov 12 14:56 : client: command returned 0
Nov 12 14:56 : client: process command "currentsong"
Nov 12 14:56 : client: [282] process command list returned 0
Nov 12 14:56 : client: [282] closed
Nov 12 14:56 : decoder_thread: probing plugin flac
Nov 12 14:56 : client: [283] opened from 127.0.0.1:45932
Nov 12 14:56 : client: [283] process command list
Nov 12 14:56 : client: [283] process command list returned 0
Nov 12 14:56 : decoder: audio_format=44100:16:2, seekable=true
Nov 12 14:56 : alsa_output: opened hw:0,0 type=HW
Nov 12 14:56 : alsa_output: buffer: size=128..131072 time=2902..2972155
Nov 12 14:56 : alsa_output: period: size=64..65536 time=1451..1486078
Nov 12 14:56 : alsa_output: default period_time = buffer_time/4 = 500000/4 = 125000
Nov 12 14:56 : alsa_output: format=S16_LE (Signed 16 bit Little Endian)
Nov 12 14:56 : alsa_output: buffer_size=22050 period_size=4410
Nov 12 14:56 : output: opened "snd_allo_digione" (alsa) audio_format=44100:16:2
Nov 12 14:56 : client: [283] closed
Nov 12 14:56 : client: [2] process command "status"
Nov 12 14:56 : client: [2] command returned 0
Nov 12 14:56 : client: [8] process command "idle"
Nov 12 14:56 : client: [8] command returned 1
Nov 12 14:56 : client: [273] closed
Nov 12 14:56 : client: [2] process command "currentsong"
Nov 12 14:56 : client: [2] process command "playlistinfo"
Nov 12 14:56 : client: [2] process command "idle"
Nov 12 14:56 : client: [2] command returned 1
Nov 12 14:56 : client: [284] opened from 127.0.0.1:45934
Nov 12 14:56 : client: [284] process command list
Nov 12 14:56 : client: [284] process command list returned 0
Nov 12 14:56 : client: [285] opened from 127.0.0.1:45936
Nov 12 14:56 : client: [285] process command "clearerror"
Nov 12 14:56 : client: [285] command returned 0
Nov 12 14:56 : client: [285] process command "status"
Nov 12 14:56 : client: [285] process command "currentsong"
Nov 12 14:56 : client: [284] closed
Nov 12 14:56 : client: [286] opened from 127.0.0.1:45938
Nov 12 14:56 : client: [286] process command "idle"
Nov 12 14:56 : client: [286] command returned 1
Nov 12 14:56 : client: [285] closed
Nov 12 14:56 : client: [5] process command "status"
Nov 12 14:56 : client: [5] command returned 0
Nov 12 14:56 : client: [287] opened from 127.0.0.1:45942
Nov 12 14:56 : client: [287] process command list
Nov 12 14:56 : client: process command "tagtypes "clear""
Nov 12 14:56 : client: process command "playlistinfo"
Nov 12 14:56 : client: [287] process command list returned 0
Nov 12 14:56 : client: [287] closed
Nov 12 14:56 : client: [5] process command "currentsong"
Nov 12 14:56 : client: [5] process command "playlistinfo "1""
Nov 12 14:57 : client: [5] process command "status"
Nov 12 14:57 : client: [5] command returned 0
Nov 12 14:57 : client: [5] process command "currentsong"
Nov 12 14:57 : client: [5] process command "playlistinfo "1""
Nov 12 14:57 : client: [288] opened from 127.0.0.1:45944
Nov 12 14:57 : client: [288] process command "play "1""
Nov 12 14:57 : playlist: play 1:"NAS/Audiophile_Recordings/_Test_Files/Varius Sample Rate Files/Stereo 24BIT_96kHz/2L-139_stereo_FLAC_88k_24b_01.flac"
Nov 12 14:57 : decoder_thread: probing plugin flac
Nov 12 14:57 : decoder: audio_format=88200:24:2, seekable=true
Nov 12 14:57 : client: [288] command returned 0
Nov 12 14:57 : playlist: queue song 2:"NAS/Audiophile_Recordings/_Test_Files/Varius Sample Rate Files/Stereo 24BIT_192kHz/2L-139_stereo_FLAC_176k_24b_01.flac"
Nov 12 14:57 : alsa_output: opened hw:0,0 type=HW
Nov 12 14:57 : alsa_output: buffer: size=64..65536 time=725..743039
Nov 12 14:57 : alsa_output: period: size=32..32768 time=362..371520
Nov 12 14:57 : alsa_output: default period_time = buffer_time/4 = 500000/4 = 125000
Nov 12 14:57 : alsa_output: format=S24_LE (Signed 24 bit Little Endian)
Nov 12 14:57 : alsa_output: buffer_size=44100 period_size=11025
Nov 12 14:57 : output: opened "snd_allo_digione" (alsa) audio_format=88200:24:2
Nov 12 14:57 : client: [288] process command list
Nov 12 14:57 : client: process command "status"
Nov 12 14:57 : client: command returned 0
Nov 12 14:57 : client: process command "currentsong"
Nov 12 14:57 : client: [288] process command list returned 0
Nov 12 14:57 : client: [286] closed
Nov 12 14:57 : client: [8] process command "idle"
Nov 12 14:57 : client: [8] command returned 1
Nov 12 14:57 : client: [2] process command "status"
Nov 12 14:57 : client: [2] command returned 0
Nov 12 14:57 : client: [2] process command "currentsong"
Nov 12 14:57 : client: [2] process command "playlistinfo"
Nov 12 14:57 : client: [288] closed
Nov 12 14:57 : client: [289] opened from 127.0.0.1:45946
Nov 12 14:57 : client: [289] process command list
Nov 12 14:57 : client: [289] process command list returned 0
Nov 12 14:57 : client: [2] process command "idle"
Nov 12 14:57 : client: [2] command returned 1
Nov 12 14:57 : client: [289] closed
Nov 12 14:57 : client: [290] opened from 127.0.0.1:45948
Nov 12 14:57 : client: [290] process command list
Nov 12 14:57 : client: [290] process command list returned 0
Nov 12 14:57 : client: [290] closed
Nov 12 14:57 : client: [291] opened from 127.0.0.1:45950
Nov 12 14:57 : client: [291] process command "idle"
Nov 12 14:57 : client: [291] command returned 1
Nov 12 14:57 : client: [292] opened from 127.0.0.1:45952
Nov 12 14:57 : client: [292] process command "clearerror"
Nov 12 14:57 : client: [292] command returned 0
Nov 12 14:57 : client: [292] process command "status"
Nov 12 14:57 : client: [292] process command "currentsong"
Nov 12 14:57 : client: [292] closed
Nov 12 14:57 : client: [5] process command "playlistinfo "2""
Nov 12 14:57 : client: [293] opened from 127.0.0.1:45956
Nov 12 14:57 : client: [293] process command "play "2""
Nov 12 14:57 : playlist: play 2:"NAS/Audiophile_Recordings/_Test_Files/Varius Sample Rate Files/Stereo 24BIT_192kHz/2L-139_stereo_FLAC_176k_24b_01.flac"
Nov 12 14:57 : decoder: audio_format=176400:24:2, seekable=true
Nov 12 14:57 : client: [293] command returned 0
Nov 12 14:57 : playlist: queue song 3:"NAS/Audiophile_Recordings/_Test_Files/Varius Sample Rate Files/Stereo 24BIT_352.8kHz/2L-139_stereo_FLAC_352k_24b_01.flac"
Nov 12 14:57 : alsa_output: buffer: size=64..65536 time=362..371520
Nov 12 14:57 : alsa_output: period: size=32..32768 time=181..185760
Nov 12 14:57 : alsa_output: default period_time = buffer_time/4 = 371519/4 = 92879
Nov 12 14:57 : alsa_output: buffer_size=65536 period_size=16384
Nov 12 14:57 : output: opened "snd_allo_digione" (alsa) audio_format=176400:24:2
Nov 12 14:57 : client: [293] process command list
Nov 12 14:57 : client: [293] process command list returned 0
Nov 12 14:57 : client: [291] closed
Nov 12 14:57 : client: [293] closed
Nov 12 14:57 : client: [294] opened from 127.0.0.1:45960
Nov 12 14:57 : client: [294] process command list
Nov 12 14:57 : client: [294] process command list returned 0
Nov 12 14:57 : client: [295] opened from 127.0.0.1:45958
Nov 12 14:57 : client: [295] process command list
Nov 12 14:57 : client: [295] process command list returned 0
Nov 12 14:57 : client: [294] closed
Nov 12 14:57 : client: [5] process command "playlistinfo "3""
Nov 12 14:57 : client: [295] closed
Nov 12 14:57 : client: [296] opened from 127.0.0.1:45962
Nov 12 14:57 : client: [296] process command "idle"
Nov 12 14:57 : client: [296] command returned 1
Nov 12 14:57 : client: [297] opened from 127.0.0.1:45964
Nov 12 14:57 : client: [297] process command "clearerror"
Nov 12 14:57 : client: [297] command returned 0
Nov 12 14:57 : client: [297] process command "status"
Nov 12 14:57 : client: [297] process command "currentsong"
Nov 12 14:57 : client: [297] closed
Nov 12 14:57 : client: [298] opened from 127.0.0.1:45968
Nov 12 14:57 : client: [298] process command "play "3""
Nov 12 14:57 : playlist: play 3:"NAS/Audiophile_Recordings/_Test_Files/Varius Sample Rate Files/Stereo 24BIT_352.8kHz/2L-139_stereo_FLAC_352k_24b_01.flac"
Nov 12 14:57 : decoder: audio_format=352800:24:2, seekable=true
Nov 12 14:57 : client: [298] command returned 0
Nov 12 14:57 : client: [298] process command list
Nov 12 14:57 : alsa_output: buffer: size=64..65536 time=333..341334
Nov 12 14:57 : alsa_output: period: size=32..32768 time=166..170667
Nov 12 14:57 : alsa_output: default period_time = buffer_time/4 = 341333/4 = 85333
Nov 12 14:57 : output: opened "snd_allo_digione" (alsa) audio_format=192000:24:2
Nov 12 14:57 : soxr: soxr engine 'cr64'
Nov 12 14:57 : soxr: soxr precision=28, phase_response=50.00, passband_end=0.91, stopband_begin=1.00
Nov 12 14:57 : soxr: samplerate conversion ratio to 0.54
Nov 12 14:57 : output: converting in=352800:24:2 -> f=352800:24:2 -> out=192000:24:2
Nov 12 14:57 : client: [298] process command list returned 0
Nov 12 14:57 : client: [296] closed
Nov 12 14:57 : client: [298] closed
Nov 12 14:57 : client: [299] opened from 127.0.0.1:45970
Nov 12 14:57 : client: [299] process command list
Nov 12 14:57 : client: [299] process command list returned 0
Nov 12 14:57 : client: [299] closed
Nov 12 14:57 : client: [300] opened from 127.0.0.1:45972
Nov 12 14:57 : client: [300] process command list
Nov 12 14:57 : client: [300] process command list returned 0
Nov 12 14:57 : client: [301] opened from 127.0.0.1:45974
Nov 12 14:57 : client: [301] process command "idle"
Nov 12 14:57 : client: [301] command returned 1
Nov 12 14:57 : client: [300] closed
Nov 12 14:57 : client: [302] opened from 127.0.0.1:45976
Nov 12 14:57 : client: [302] process command "clearerror"
Nov 12 14:57 : client: [302] command returned 0
Nov 12 14:57 : client: [302] process command "status"
Nov 12 14:57 : client: [302] process command "currentsong"
Nov 12 14:57 : client: [302] closed
Nov 12 14:57 : client: [5] process command "playlistinfo "4""
Nov 12 14:57 : client: [303] opened from 127.0.0.1:45980
Nov 12 14:57 : client: [303] process command "stop"
Nov 12 14:57 : playlist: stop
Notice that only when I tried to play a file with sample rate above 192 SoXR made the conversion
In all other cases alsa played the native sample rate.
IMHO if we need to squeeze a little more the system, we have to understand and focus on the SoRX parameters
Stavros
