Please post outputs:
/srv/http/bash/system-data.sh
/srv/http/bash/system-data.sh | jq .
root@RuneAudioII:~ # . /srv/http/bash/system-data.sh|jq
"cpuload": "0.34 0.45 2.66",
"cputemp": 44,
"startup": "10.867s <gr class=\"wide\">(kernel)</gr> + 50.110s <gr class=\"wide\">(userspa
ce)</gr>",
"time": "19:56:12<gr> • </gr>2020-10-26 <grw>UTC</grw>",
"uptime": "2h 33m<span class='wide'> <gr>since 2020-10-26 • 17:22</gr></span>",
"undervoltage": false,
"undervdetected": false,
"audioaplayname": "bcm2835 Headphones",
"audiooutput": "On-board - Headphone",
"hardware": " Raspberry Pi 2 Model B Rev 1.2",
"hostname": "RuneAudioII",
"ip": "eth0 b8:27:eb:c5:be:2c ,wlan0 192.168.7.196 e0:ca:94:8d:5b:08,eth0 b8:27:eb:c5:be:2c ,wlan0 192.168.7.196 e0:ca:94:8d:5b:08",
"kernel": "5.4.71-1-ARCH",
"mpd": "0.22-1",
"mpdstats": "8258 1453 2037",
"ntp": "pool.ntp.org",
"onboardaudio": false,
"reboot": "",
"regdom": "00",
"soc": "<span class='wide'>BCM2835<gr> • </gr></span> 4 Cortex-A53 @ 900MHz<gr> &bull
; </gr>1GB",
"soundprofile": "RuneAudio",
"soundprofileval": "1500 1000 0 4500000",
"soundprofilecus": "",
"sources": [
"icon": "microsd",
"mountpoint": "/",
"mounted": true,
"source": "/dev/sda1",
"size": "3.9GB/7.8GB"
"icon": "usbdrive",
"mountpoint": "/mnt/MPD/USB/ROOTSSD",
"mounted": true,
"source": "/dev/sda2",
"size": "3.9GB/6.9GB"
"icon": "network",
"mountpoint": "/mnt/MPD/NAS/Music",
"mounted": true,
"source": "192.168.7.8:/volume1/Music",
"size": "1.4TB/1.8TB"
"timezone": "UTC",
"version": "e6",
"versionui": 202010261,
"bluetooth": false,
"bluetoothon": false,
"btdiscoverable": false
yet...
root@RuneAudioII:~ # aplay -l
card 0: sndrpirpidac [snd_rpi_rpi_dac], device 0: RPi-DAC HiFi pcm1794a-codec-0 [RPi-DAC HiFi pcm1794a-codec-0]
Subdevices: 0/1
Subdevice #0: subdevice #0
I can't set persistent setting of I2S and time zone. If I return to system page, it returns to the wrong settings for i2s and won't change the time zone...
Even though my boot config seems correct, the system page reports it wrong.
I have
root@RuneAudioII:~ # cat /boot/config.txt
force_turbo=1
gpu_mem=32
initramfs initramfs-linux.img followkernel
max_usb_current=1
disable_splash=1
disable_overscan=1
dtparam=audio=off
dtparam=i2s=on
dtoverlay=rpi-dac
dtparam=pwr_led_trigger=mmc0
dtparam=act_led_trigger=cpu
an old bug that I had long time ago...
Didn't see that on stock re6 or 201020 update..
Luckily a minor one though
A8
