Hi there,
As the title said, I couldn't load any m4a files created with nero AAC on runeaudio 0.2 beta with my raspberry, my mp3 and vorbis work fine. Any idea?
OT: other than the problem above, this is the most audio glitch free experience I have had with my rPi. You guys did a runetastic job. My own raspbian build with mpd couldn't work as well.
EDIT: So looking at the log myself, enabling ffmpeg decoder fixed the problem. Any reason you keep it off?
Linux version 3.6.11-18-ARCH+ (nobody@) (gcc version 4.7.2 (GCC) ) #1 PREEMPT Mon Oct 21 01:15:42 CDT 2013
system load: 0.31 0.35 0.42 2/96 2012
HW platform: RaspberryPi (01)
playerID: 01bfda27b240a58b82fc9d153f3e637311
Advanced Linux Sound Architecture Driver Version 1.0.25.
0 [C20 ]: USB-Audio - Cambridge Audio USB Audio 2.0
Cambridge Audio Cambridge Audio USB Audio 2.0 at usb-bcm2708_usb-1.2, high spee
1 [ALSA ]: BRCM bcm2835 ALSbcm2835 ALSA - bcm2835 ALSA
bcm2835 ALSA
ALSA interface #0: (/proc/asound/card0/pcm0p/info)
card: 0
device: 0
subdevice: 0
stream: PLAYBACK
subname: subdevice #0
class: 0
subclass: 0
subdevices_count: 1
subdevices_avail: 0
ALSA interface #1: (/proc/asound/card1/pcm0p/info)
card: 1
device: 0
subdevice: 0
stream: PLAYBACK
class: 0
subclass: 0
subdevices_count: 8
subdevices_avail: 8
interface #0 stream status: (/proc/asound/card0/stream0)
Cambridge Audio Cambridge Audio USB Audio 2.0 at usb-bcm2708_usb-1.2, high spee : USB Audio
Playback:
Status: Running
Interface = 1
Altset = 1
Packet Size = 1024
Momentary freq = 44104 Hz (0x5.8350)
Feedback Format = 8.16
Packet Size = 0
Momentary freq = 44100 Hz (0x5.8333)
Interface 1
Altset 1
Format: S32_LE
Channels: 2
Endpoint: 1 OUT (ASYNC)
Rates: 44100, 48000, 88200, 96000, 192000
Data packet interval: 125 us
interface #1 stream status: (/proc/asound/card1/stream0)
no stream present
Module = "snd_usb_audio"
Attributes:
coresize = "104025"
initsize = "0"
initstate = "live"
refcnt = "1"
srcversion = "DA9A78F56D873AB02CB47F0"
taint = ""
uevent =
Parameters:
async_unlink = "Y"
device_setup = "0,0,0,0,0,0,0,0"
enable = "Y,Y,Y,Y,Y,Y,Y,Y"
id = "(null),(null),(null),(null),(null),(null),(null),(null)"
ignore_ctl_error = "N"
index = "0,-1,-1,-1,-1,-1,-1,-1"
nrpacks = "3"
pid = "-1,-1,-1,-1,-1,-1,-1,-1"
vid = "-1,-1,-1,-1,-1,-1,-1,-1"
Sections:
.ARM.exidx.exit.text= "0xbf142d2c"
.ARM.exidx.init.text= "0xbf142d24"
.ARM.exidx = "0xbf145144"
.ARM.extab = "0xbf1450d8"
.ARM.extab.init.text= "0xbf142d18"
.bss = "0xbf148b2c"
.data = "0xbf1455f0"
.exit.text = "0xbf141534"
.gnu.linkonce.this_module= "0xbf1489c4"
.init.text = "0xbf151000"
.note.gnu.build-id = "0xbf1455cc"
.rodata = "0xbf141540"
.rodata.str1.4 = "0xbf142dc4"
.strtab = "0xbf155ec8"
.symtab = "0xbf151048"
.text = "0xbf136000"
__param = "0xbf142d34"
hardware platform: RaspberryPi
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 1500000
rootfs / rootfs rw 0 0
/dev/root / ext4 rw,noatime,nouser_xattr,errors=remount-ro,data=ordered 0 0
devtmpfs /dev devtmpfs rw,relatime,size=84748k,nr_inodes=21187,mode=755 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=30,pgrp=1,timeout=300,minproto=5,maxproto=5,direct 0 0
tmpfs /sys/fs/cgroup tmpfs rw,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpuacct,cpu 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
cgroup /sys/fs/cgroup/net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_prio 0 0
Ramdisk /run/shm tmpfs rw,nosuid,nodev,noexec,relatime,size=262144k 0 0
tmpfs /tmp tmpfs rw 0 0
rpc_pipefs /var/lib/nfs/rpc_pipefs rpc_pipefs rw,relatime 0 0
/dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
/dev/root /var/tmp ext4 rw,noatime,nouser_xattr,errors=remount-ro,data=ordered 0 0
/dev/sda /mnt/MPD/USB/sda-usb-UFD_3.0_Silicon- ext4 rw,nosuid,nodev,noexec,noatime,data=ordered 0 0
//192.168.137.1/Music /mnt/MPD/PC cifs ro,relatime,vers=1.0,sec=ntlm,cache=strict,unc=\\192.168.137.1\Music,uid=45,forceuid,gid=45,forcegid,addr=192.168.137.1,file_mode=0755,dir_mode=0755,nounix,serverino,rsize=16384,wsize=16384,actimeo=1 0 0
log_level "default"
zeroconf_name "runeaudio"
audio_buffer_size "512"
buffer_before_play "0%"
auto_update "no"
mixer_type "none"
enabled "no"
name "USB-Audio"
dsd_usb "yes"
type "null"
name "Null"
enabled "no"
device "hw:1,0"
name "AnalogJack/HDMI"
###### PHP backend ######
php version: 5.5
debug level: 2
###### SESSION ######
STATUS: 1
SAVE PATH: /run
###### SESSION DATA ######
Array
[orionprofile] => RuneAudio
[cmediafix] => 0
[playmod] => 0
[ramplay] => 0
[sessionid] => rjkd75n6oq8e8387jmn48167g6
[mpdconfhash] => 6365a4f344e7f0c09f3d8b10d29cd952
[lastfm_apikey] => ba8ad00468a50732a3860832eaed0882
[netconfhash] => 643f8967af551f683b3cfd493950c550
[mpdconf_advanced] => 0
[netconf_advanced] => 0
[dev] =>
[sourceconfhash] => d41d8cd98f00b204e9800998ecf8427e
[sourceconf_advanced] => 1
[debug] => 2
[hiddendebug] => 0
[opcache] => 1
[playerid] => 01bfda27b240a58b82fc9d153f3e637311
[hwplatform] => RaspberryPi
[hwplatformid] => 01
[airplay] => 0
[scrobbling_lastfm] => 0
[scrobbling_librefm] => 0
[scrobbling_jamendo] => 0
[spotify] => 0
[db_version] => 1.2
[udevil] => 1
[coverart] => 1
[volume] => 0
[ao] => 0
[ntpserver] => ntp.inrim.it
[hostname] => runeaudio
[w_queue] =>
[w_queueargs] =>
[w_lock] => 0
[w_active] => 0
[w_jobID] =>
[debugdata] =>
[netconf] => Array
[eth0] => Array
[ip] => 192.168.137.153
[state] => play
[notify] =>
