ceejayemm wrote
I am still having issues with the MPD Mixer Control for the Merus Amp changing from DAC Hardware to MPD Software but I cannot figure out what is causing this to happen. It does come back after a reboot. I also have issues with the volume level, apparently changing of their own accord, frequently ending up at 100, which can be a bit of a shock when starting up the device. In earlier versions of RA there was an option to set a startup volume level which would ensure that on startup the volume level could be set low and then increased as necessary with the volume control. Could this be reinstated to help with this issue ?
Please don't take any of the above as any criticism of your work but purely to help resolve the issues we have at the moment with this great bit of software. As a (past) software developer myself I know how useful feedback can be, if there is any more info I can provide please let me know.
Normally, MPD saves volume level periodically includes when reboot/shutdown properly.
Please post your list of devices from MPD setting page: Devices and Hardware Mixers (Tap/click them.)
The latest updated image file may have something better for your DAC.
Suggestions and bug reports are always welcome.
maxus minimax wrote
I want to send basic commands, play, stop, volume... via some kind of simple Http or TCP API to the RPi. With the V0.3 image, I can use e.g.
http://192.168.10.20/command?cmd=play, but that doesn´t work with +R_e4. I understand these commands control MPD using MPC. Doesn´t +R_e4 use MPC also?
R+R e4 uses MPC for most of MPD commands but there's no API. Please explain why should there be.
