RolandBlaze wrote
Have noticed when streaming from Spotify it displays as being streamed at 48KHz, but Spotify is 44Khz? Can you amend this if poss? I'm aware there may be a few tracks that play at 48Khz on Spotify but very few compared to the amount of 44KHz tracks, and I believe it would be better to set at 44Khz if there is no way to detect what is being provided and automate the change in Rune? ...
My DAC detects more of 48kHz than not. There's no info on how to detect it from each tracks.
Have to agree to disagree sorry, It will ALWAYS output at 48 kHz for you as its hard-coded into asla.conf in the build?
"defaults.pcm.dmix.rate 48000"
Not to worry as I can change it myself, but it is wrong. Spotify is mostly 44kHz, check Volumio, check Moode, both output Spotify at 44 kHz.
Thanks again tho for the build and the quick updates
