dror wrote
Airplay not working toggle button switching gives "enabling" message, then goes on (no "Done" is displayed), but if I come back to the settings page it is off.
With latest update, tap AirPlay label and post the result.
RolandBlaze wrote
Have noticed when streaming from Spotify it displays as being streamed at 48KHz, but Spotify is 44Khz? Can you amend this if poss? I'm aware there may be a few tracks that play at 48Khz on Spotify but very few compared to the amount of 44KHz tracks, and I believe it would be better to set at 44Khz if there is no way to detect what is being provided and automate the change in Rune? ...
My DAC detects more of 48kHz than not. There's no info on how to detect it from each tracks.
amink67 wrote
Temperature: 67 °C, using only heatsinks on CPU (Any suggestions on a good passive cooling solution?)
RPi CPUs can go up to 85°C and may be more. Read
here.
It seems like we can't destroy them quite easily by just running a lot of heavy processes.
Reliang268 wrote
The Regulatory domain setting at Wifi is gone. How to get is back?
Relocated to setting icon next to Timezone.
klassikmann wrote
Even the second system is providing the "Add similar" (Lastfm playlist) feature in the library view introduced in
#4207629. Btw. the new system-setting "Last.fm Scrobbler" is unchecked. I propose not to offer "Add similar" in installations like such.
Similar tracks are based on general database, not the scrobbling data.
R101 wroteIs there any advantage in allowing the automatic partition expansion at first boot? The instructions state that it should be disabled.
The instructions?
Without expansion, there'll be limited spaces left which is fine in general. More space should spread write to more broader area. Should there be any specific requirement to keep the unused part, delete x.sh file from BOOT partition prior to first boot.
Scott wrote
... How do I return from spotify to the normal Library shy of having to do a reset. Library functions work fine and Spotify connects just fine, but cannot figure out how to get back to normal operation once Spotify is triggered
Just press stop. The same for all streamers.
R101 wroteThe edit function for Webradio entries does not seem to work.
Fixed.
klassikmann wroteUpdate Re4 20200718
Update not possible:
Fixed.
