@[deleted]
Since I already resolved this issue and I didn't keep any logs, then I tried to simulate that again.
Actually, my results are pretty much similar to the above snapshots provided by jlynton.
The Wi-Fi profile's configuration (created by RuneAudio) looks like that:
Interface=wlan0
Connection=wireless
IP=dhcp
ESSID=*******
Security=wpa
Key=########
Then I modified this profile to match my previous setup/settings:
Description='wlan0 connection'
Interface=wlan0
Connection=wireless
Security=wpa-configsection
IP=dhcp
WPAConfigSection=(
'ssid="********"'
'psk="########"'
'key_mgmt=WPA-PSK'
'proto=RSN'
'group=CCMP'
'pairwise=CCMP'
'priority=3'
By using this opportunity, I would like to express my great appreciation to all the efforts made by you in order to enhance RuneAudio.
@[deleted]
NAS setup in RuneAudio is very specific process, especially if it is necessary to connect NAS via NFS.
I use SMB/CIFS method to connect my network storages (WD MyCloud & WD MyBookLive). For the latter I found it necessary to specify an option "vers=1.0" that actually downgrades Samba version to v.1.0. I didn't manage to mount MyBookLive without this trick.
Nevertheless, I still couldn't see my mounting points at the Network menu, however the Library tab depicts both storages in a typical manner.
