carlmart wroteThis is what I get when I turn on the Raspberry with Rune on the SD card.
Your PI is not correctly booting the kernel image (Linux + Rune).
1) Make sure you have a suitable power supply like the official PI one (possible voltage drop otherwise will cause all sorts of strange issues).
2) Make sure you are imaging the SDCard correctly as per instructions.
3) Try imaging and booting Rasperian on the SDcard to check everything is ok (Pi & SDcard combination).
4) Try a different SDCard.
5) I'm using Rune 0,4b with a Topping D10 on a 3B Pi and it is beautiful ! (both the simplicity and operation of Rune 0.4b & the Topping sound).
6) Finally, once all up and running ALWAYS shutdown your PI from the Rune menu - never simply turn off the power !
