on a Pi3 i wouldn't use the UART as power indicator.
Because with enable_uart=1 will cap the CPU speed of your CPU to a constant 600Mhz instead of fluctuating speed up to 1.2Ghz.
Try this:
Info: Pi3 uses a GPIO expander to drive the LEDs which can only be accessed
from the VPU. There is a special driver for this with a separate DT
node, which has the unfortunate consequence of breaking the
act_led_gpio and act_led_activelow dtparams.
This overlay changes the GPIO controller back to the standard one and
restores the dtparams.
Load: dtoverlay=pi3-act-led,<param>=<val>
Params: activelow Set to "on" to invert the sense of the LED
(default "off")
gpio Set which GPIO to use for the activity LED
(in case you want to connect it to an external
device)
REQUIRED
