Hi Toube,
Toube wroteadding .m3u8 playlist support
We rely om MPD do all playlist support. The playlist type .m3m8 is not listed as a supported type. But you could try adding 'm3m' and 'm3m extended' playlist types, it may work. The best way to do this is to add the following lines to /etc/mpd.conf:
## your-extra-mpd.conf ##
## Playlist Plugin Example ##
# This is an example for adding a Playlist Plugin to MPD
# You could use this file for setting many other MPD options
# This file needs to be placed in the directory /home to activate it
# Set the correct file protections with the command: chmod 644 /home/your-extra-mpd.conf
playlist_plugin {
name "m3u"
enabled "true"
playlist_plugin {
name "extm3u"
enabled "true"
## end your-exta-mpd.conf ##
I know you use a manually edited mpd.conf file which is not managed by the UI.
For users who use the UI for MPD configuration management, create a separate file /home/your-extra-mpd.conf with the above contents. It will then be automatically included.
