Hi HJLK,
HJLK wrote...the volume UP/DOWN buttons start to work only AFTER I adjust the volume once thru the wheel...
Yes, thanks, I know about this. It's on my list of things to do.
HJLK wrote...This may be helped by adding a "metadata_to_use" line (with tags to use) in mpd.conf BUT I cannot change the mpd.conf file...
I am not sure it will help with your problem, but you can add a "metadata_to_use" clause in /etc/mpd.conf by logging in via SSH and using this command:
redis-cli hset mpdconf metadata_to_use "tags"
Replace "tags" with a string like this: "artist,album,title,track,name,genre,date,composer,performer,disc", or use the format "+comment" or "-disc" to respectively add or remove a single tag.
After running the command you will need to reboot to activate it, then you will need rebuild your MPD library (see the option in the Sources UI).
To remove the "metadata_to_use" clause in /etc/mpd.conf use this command:
redis-cli hdel mpdconf metadata_to_use
Followed by a reboot and a MPD library rebuild.
