Strange.....
Library remains empty (even after reinstalling Rune from scratch)
But the're has been an Mojave update (including Safari)??? (I don't suspect the last DSM update from Synology, because other items of the library are also invisible)
My debug info:
Linux version 4.14.34-1-ARCH (alarm@alarmpi) (gcc version 7.3.1 20180312 (GCC)) #1 SMP Tue May 15 00:50:02 CDT 2018
System time: Sun May 26 16:56:07 CEST 2019
System load: 0.58 0.21 0.08 1/144 756
Hardware model: Raspberry Pi 2 Model B Rev 1.1
Linux version: 4.14.34-1-ARCH
RuneOS/UI: 0.5b (gearhead) - Experimental Beta 0.5 20180903
Git Branch: 0.5b
HW platform: RaspberryPi (08)
Build version: janui-20180903-10
PlayerID: 088185d72ce70296c67656fbb9b9b090ac
###### Boot configuration (cat /boot/config.txt) ######
# Uncomment some or all of these to enable the optional hardware interfaces
# Params:
# i2c_arm Set to "on" to enable the ARM's i2c interface
# (default "off")
# i2c_vc Set to "on" to enable the i2c interface
# usually reserved for the VideoCore processor
# (default "off")
# i2c_arm_baudrate Set the baudrate of the ARM's i2c interface
# (default "100000")
# i2c_vc_baudrate Set the baudrate of the VideoCore i2c interface
# i2c_baudrate An alias for i2c_arm_baudrate
# i2s Set to "on" to enable the i2s interface
# (default "off")
# spi Set to "on" to enable the spi interfaces
# (default "off")
# act_led_trigger Choose which activity the LED tracks.
# Use "heartbeat" for a nice load indicator.
# (default "mmc")
# act_led_activelow Set to "on" to invert the sense of the LED
# (default "off")
# act_led_gpio Set which GPIO pin to use for the activity LED
# (in case you want to connect it to an external
# device)
# (default "16" on a non-Plus board, "47" on a
# Plus or Pi 2)
# N.B. It is recommended to only enable those interfaces that are needed.
# Leaving all interfaces enabled can lead to unwanted behaviour (i2c_vc
# interfering with Pi Camera, I2S and SPI hogging GPIO pins, etc.)
# Note also that i2c, i2c_arm and i2c_vc are aliases for the physical
# interfaces i2c0 and i2c1. Use of the numeric variants is still possible
# but deprecated because the ARM/VC assignments differ between board
# revisions. The same board-specific mapping applies to i2c_baudrate,
# and the other i2c baudrate parameters.
## RuneAudio HDMI & 3,5mm jack
dtparam=audio=off
## RuneAudio I2S-Settings
dtoverlay=hifiberry-digi-pro
# Uncomment to enable the lirc-rpi module
# Params: gpio_out_pin GPIO pin for output (default "17")
# gpio_in_pin GPIO pin for input (default "18")
# gpio_in_pull Pull up/down/off on the input pin
# (default "down")
# sense Override the IR receive auto-detection logic:
# (default "-1")
# softcarrier Turn the software carrier "on" or "off"
# (default "on")
# (default "off")
# LCD settings
# 180 degrees
# Normal
lcd_rotate=0
## Boot splash
# set to 1 to disable or 0 to enable boot splash
disable_splash=1
# Uncomment if you get no picture on HDMI for a default "safe" mode
# Uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
# Uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
# Uncomment to force a console size. By default it will be display's size minus
# overscan.
# Uncomment if hdmi display is not detected and composite is being output
# Uncomment to force a specific HDMI mode (this will force VGA)
# Uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
# Uncomment to set monitor mode to DMT
# Uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
# setting the max usb current to 1200mA
max_usb_current=1
# memory options
gpu_mem=16
## Some overclocking settings, governor is set to on-demand as standard
## The values below are valid for the B+ and Zero models
## Overclocking should not be needed for the 2B, 3B and 3B+ models
## See your documentation for A and B models
## None
## Modest
## Medium
## High
## Turbo
## General CPU settings
force_turbo=1
# Lowering max CPU temperature from 85 (standard) to 70 or 75 degrees gives some protection when (force) turbo is set
# If the max temp is reached the cpu will autmatically be throttled back
# Boot delay sometimes needs to be set to higher values when overclocking is enabled
# Default boot delay is 1 second, 3B+ needs a delay of 2
boot_delay=2
initramfs initramfs-linux.img followkernel
RAM: 973.57MiB 232.21MiB 741.36MiB 20.92MiB
Swap: 0.00B 0.00B 0.00B
Bootup: Sun May 26 16:55:00 2019 Load average: 0.58 0.21 0.08 1/146 773
user : 00:00:32.82 12.5% page in : 116548
nice : 00:00:04.78 1.8% page out: 14240
system: 00:00:15.60 5.9% page act: 11550
IOwait: 00:00:06.85 2.6% page dea: 0
hw irq: 00:00:00.00 0.0% page flt: 168885
sw irq: 00:00:00.33 0.1% swap in : 0
idle : 00:03:23.09 77.1% swap out: 0
uptime: 00:01:06.92 context : 48654
irq 16: 0 irq 51: 0
irq 17: 13695 irq 54: 0
irq 21: 0 irq 59: 0
irq 23: 50 irq 62: 21278
irq 24: 2 irq 83: 16
irq 46: 0 irq 86: 489
irq 48: 0 irq 87: 30
irq 50: 3620
mmcblk0 3203r 4 mmcblk0p2 3039r
mmcblk0p1 84r
eth0 TX 13.09KiB RX 19.52KiB lo TX 194.22KiB RX 194.22KiB
systemd-+-agetty
|-avahi-daemon---avahi-daemon
|-dbus-daemon
|-devmon---udevil
|-dhcpcd
|-haveged
|-ifplugd
|-mpd---4*[{mpd}]
|-nginx---nginx
|-php-fpm---3*[php-fpm]
|-python
|-redis-server---3*[{redis-server}]
|-rpc.statd
|-rpcbind
|-rune_PL_wrk---sh---curl
|-rune_SY_wrk
|-sh---sleep
|-sshd
|-systemd-journal
|-systemd-resolve
|-systemd-timesyn---{systemd-timesyn}
`-systemd-udevd-+-9*[systemd-udevd]
`-systemd-udevd---refresh_ao
Advanced Linux Sound Architecture Driver Version k4.14.34-1-ARCH.
0 [sndrpihifiberry]: HifiberryDigi - snd_rpi_hifiberry_digi
PLAYBACK devices: (aplay -l)
card 0: sndrpihifiberry [snd_rpi_hifiberry_digi], device 0: HiFiBerry Digi+ Pro HiFi wm8804-spdif-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
PCM devices: (aplay -L)
null
pulse
PulseAudio Sound Server
default:CARD=sndrpihifiberry
snd_rpi_hifiberry_digi,
Default Audio Device
sysdefault:CARD=sndrpihifiberry
card 0:
Simple mixer control 'Tx Source',0
card 0:
numid=1,iface=MIXER,name='Tx Source'
Output 1 (snd_rpi_hifiberry_digi) is enabled
MPD statistics: (mpc stats)
Artists: 337
Albums: 521
Songs: 5615
Play Time: 0 days, 0:00:00
Uptime: 0 days, 0:00:44
DB Updated: Sun May 26 16:52:44 2019
DB Play Time: 17 days, 13:07:51
###### mpd version ######
Music Player Daemon 0.20.20
Copyright (C) 2003-2007 Warren Dukes
Copyright 2008-2017 Max Kellermann
This is free software; see the source for copying conditions. There is NO
warranty; not even MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Database plugins:
simple proxy upnp
Storage plugins:
local smbclient nfs curl
Neighbor plugins:
smbclient upnp
Decoders plugins:
[mad] mp3 mp2
[vorbis] ogg oga
[oggflac] ogg oga
[flac] flac
[sndfile] wav aiff aif au snd paf iff svx sf voc w64 pvf xi htk caf sd2
[audiofile] wav au aiff aif
[dsdiff] dff
[dsf] dsf
[faad] aac
[mpcdec] mpc
[ffmpeg] 16sv 3g2 3gp 4xm 8svx aa3 aac ac3 adx afc aif aifc aiff al alaw amr anim apc ape asf atrac au aud avi avm2 avs bap bfi c93 cak cin cmv cpk daud dct divx dts dv dvd dxa eac3 film flac flc fli fll flx flv g726 gsm gxf iss m1v m2v m2t m2ts m4a m4b m4v mad mj2 mjpeg mjpg mka mkv mlp mm mmf mov mp+ mp1 mp2 mp3 mp4 mpc mpeg mpg mpga mpp mpu mve mvi mxf nc nsv nut nuv oga ogm ogv ogx oma ogg omg opus psp pva qcp qt r3d ra ram rl2 rm rmvb roq rpl rvc shn smk snd sol son spx str swf tak tgi tgq tgv thp ts tsp tta xa xvid uv uv2 vb vid vob voc vp6 vmd wav webm wma wmv wsaud wsvga wv wve
[pcm]
Filters:
libsamplerate soxr
Tag plugins:
id3tag
Output plugins:
null fifo pipe alsa openal httpd
Encoder plugins:
null vorbis wave flac
Input plugins:
file alsa curl ffmpeg smbclient nfs mms
Playlist plugins:
extm3u m3u pls xspf asx rss soundcloud flac cue embcue
Protocols:
file:// http:// https:// mms:// mmsh:// mmst:// mmsu:// gopher:// rtp:// rtsp:// rtmp:// rtmpt:// rtmps:// smb:// nfs:// alsa://
Other features:
avahi epoll icu inotify systemd tcp un
log_level "default"
zeroconf_name "RuneAudio"
auto_update "no"
audio_buffer_size "4096"
buffer_before_play "10%"
mixer_type "disabled"
# MPD version number: 0.20.20
resampler {
plugin "soxr"
quality "very high"
name "snd_rpi_hifiberry_digi"
hardware platform: RaspberryPi
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 4500000
/proc/sys/kernel/sched_rr_timeslice_ms: 100
total 8.0K
drwxr-xr-x 2 root root 4.0K May 26 16:38 .
drwxr-xr-x 6 root root 4.0K May 26 16:38 ..
lrwxrwxrwx 1 root root 44 Jan 29 2017 amixer-webui.service -> /usr/lib/systemd/system/amixer-webui.service
lrwxrwxrwx 1 root root 41 Mar 13 2018 brcm43438.service -> /usr/lib/systemd/system/brcm43438.service
lrwxrwxrwx 1 root root 47 May 26 16:38 netctl-ifplugd@eth0.service -> /usr/lib/systemd/system/netctl-ifplugd@.service
lrwxrwxrwx 1 root root 48 Mar 13 2018 systemd-resolved.service -> /usr/lib/systemd/system/systemd-resolved.service
sys /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
dev /dev devtmpfs rw,nosuid,relatime,size=491284k,nr_inodes=122821,mode=755 0 0
run /run tmpfs rw,nosuid,nodev,relatime,mode=755 0 0
/dev/mmcblk0p2 / ext4 rw,relatime,stripe=32679,data=ordered 0 0
cgroup2 /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate 0 0
cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd 0 0
bpf /sys/fs/bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 0 0
cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=11352 0 0
tmpfs /tmp tmpfs rw,nosuid,nodev 0 0
var-tmp /var/tmp tmpfs rw,nosuid,nodev,noatime,size=5120k 0 0
http-tmp /srv/http/tmp tmpfs rw,nosuid,nodev,noatime,size=5120k,uid=33,gid=33 0 0
192.168.1.9:/volume1/music /mnt/MPD/NAS/Synology nfs ro,noexec,noatime,vers=3,rsize=8192,wsize=16384,namlen=255,soft,nocto,proto=tcp,timeo=50,retrans=2,sec=sys,mountaddr=192.168.1.9,mountvers=3,mountport=892,mountproto=udp,local_lock=none,addr=192.168.1.9 0 0
dev 480M 0 480M 0% /dev
run 487M 13M 475M 3% /run
/dev/mmcblk0p2 3.5G 2.4G 1017M 70% /
tmpfs 487M 0 487M 0% /dev/shm
tmpfs 487M 0 487M 0% /sys/fs/cgroup
tmpfs 487M 0 487M 0% /tmp
logs 5.0M 8.0K 5.0M 1% /var/log
var-tmp 5.0M 0 5.0M 0% /var/tmp
http-tmp 5.0M 0 5.0M 0% /srv/http/tmp
rune-logs 5.0M 24K 5.0M 1% /var/log/runeaudio
/dev/mmcblk0p1 100M 22M 79M 22% /boot
192.168.1.9:/volume1/music 5.3T 222G 5.1T 5% /mnt/MPD/NAS/Synology
###### Filesystem mounts - partitions (parted -ls) ######
Model: SD SL16G (sd/mmc)
Disk /dev/mmcblk0: 15.9GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 106MB 105MB primary fat16 lba
2 106MB 3986MB 3880MB primary ext4
###### Loaded kernel modules (lsmod) ######
Module Size Used by
rpcsec_gss_krb5 32768 0
cfg80211 577536 0
8021q 28672 0
garp 16384 1 8021q
mrp 20480 1 8021q
stp 16384 1 garp
llc 16384 2 garp,stp
snd_soc_wm8804_i2c 16384 1
snd_soc_wm8804 16384 1 snd_soc_wm8804_i2c
snd_soc_hifiberry_digi 16384 0
snd_soc_bcm2835_i2s 16384 2
snd_soc_core 176128 3 snd_soc_wm8804,snd_soc_bcm2835_i2s,snd_soc_hifiberry_digi
snd_compress 20480 1 snd_soc_core
snd_pcm_dmaengine 16384 1 snd_soc_core
snd_pcm 94208 4 snd_soc_wm8804,snd_pcm_dmaengine,snd_soc_bcm2835_i2s,snd_soc_core
snd_timer 32768 1 snd_pcm
snd 65536 4 snd_compress,snd_timer,snd_soc_core,snd_pcm
i2c_bcm2835 16384 0
bcm2835_rng 16384 0
rng_core 16384 1 bcm2835_rng
uio_pdrv_genirq 16384 0
fixed 16384 2
uio 16384 1 uio_pdrv_genirq
sch_fq_codel 20480 2
crypto_user 16384 0
ip_tables 24576 0
x_tables 24576 1 ip_tables
ipv6 438272 48
tcp 0 0 0.0.0.0:6600 0.0.0.0:* LISTEN 509/mpd
tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 252/redis-server 12
tcp 0 0 0.0.0.0:5355 0.0.0.0:* LISTEN 231/systemd-resolve
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 1/init
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 239/python
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 264/nginx: master p
tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 264/nginx: master p
tcp 0 0 0.0.0.0:82 0.0.0.0:* LISTEN 264/nginx: master p
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 240/sshd
tcp 0 0 0.0.0.0:45571 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:32805 0.0.0.0:* LISTEN 693/rpc.statd
tcp6 0 0 :::5355 :::* LISTEN 231/systemd-resolve
tcp6 0 0 :::38447 :::* LISTEN -
tcp6 0 0 :::111 :::* LISTEN 1/init
tcp6 0 0 :::22 :::* LISTEN 240/sshd
udp 0 0 0.0.0.0:57277 0.0.0.0:* 693/rpc.statd
udp 0 0 127.0.0.53:53 0.0.0.0:* 231/systemd-resolve
udp 0 0 0.0.0.0:68 0.0.0.0:* 549/dhcpcd
udp 0 0 0.0.0.0:111 0.0.0.0:* 1/init
udp 0 0 0.0.0.0:33420 0.0.0.0:* -
udp 0 0 0.0.0.0:50864 0.0.0.0:* 241/avahi-daemon: r
udp 0 0 0.0.0.0:5353 0.0.0.0:* 241/avahi-daemon: r
udp 0 0 0.0.0.0:5355 0.0.0.0:* 231/systemd-resolve
udp 0 0 0.0.0.0:64310 0.0.0.0:* 671/rpcbind
udp 0 0 127.0.0.1:869 0.0.0.0:* 693/rpc.statd
udp6 0 0 :::38361 :::* -
udp6 0 0 :::111 :::* 1/init
udp6 0 0 :::5355 :::* 231/systemd-resolve
unix 2 [ ACC ] STREAM LISTENING 11325 1/init /run/systemd/private
unix 2 [ ACC ] STREAM LISTENING 18242 625/php-fpm: master /var/run/php-command.sock
unix 2 [ ACC ] STREAM LISTENING 18245 625/php-fpm: master /var/run/php-db.sock
unix 2 [ ACC ] STREAM LISTENING 18248 625/php-fpm: master /var/run/php-display.sock
unix 2 [ ACC ] SEQPACKET LISTENING 11338 1/init /run/udev/control
unix 2 [ ACC ] SEQPACKET LISTENING 11341 1/init /run/systemd/coredump
unix 2 [ ACC ] STREAM LISTENING 18003 509/mpd /run/mpd.sock
unix 2 [ ACC ] STREAM LISTENING 11354 1/init /run/systemd/journal/stdout
unix 2 [ ACC ] STREAM LISTENING 13467 1/init /run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 668 1/init /run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 13471 1/init /run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 3049 252/redis-server 12 /run/redis.sock
