Hi Janui,
it is a Raspberry Pi Model A Rev 2. There is a fatal error in the log:
Apr 12 15:25:40 runeaudio kernel: CPU: All CPU(s) started in SVC mode.
Apr 12 15:25:40 runeaudio kernel: FS-Cache: Loaded
Apr 12 15:25:40 runeaudio kernel: CacheFiles: Loaded
Apr 12 15:25:40 runeaudio kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
Apr 12 15:25:40 runeaudio kernel: loop: module loaded
Apr 12 15:25:40 runeaudio kernel: Loading iSCSI transport class v2.0-870.
Apr 12 15:25:40 runeaudio kernel: device-mapper: multipath round-robin: version 1.2.0 loaded
Apr 12 15:25:40 runeaudio kernel: device-mapper: multipath queue-length: version 0.2.0 loaded
Apr 12 15:25:40 runeaudio kernel: device-mapper: multipath service-time: version 0.3.0 loaded
Apr 12 15:25:40 runeaudio kernel: device-mapper: raid: Loading target version 1.13.0
Apr 12 15:25:40 runeaudio kernel: Error: Driver 'sdhost-bcm2835' is already registered, aborting...
Apr 12 15:25:40 runeaudio kernel: [vc_sm_connected_init]: start
Apr 12 15:25:40 runeaudio kernel: Btrfs loaded, crc32c=crc32c-generic
Apr 12 15:25:40 runeaudio kernel: mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Apr 12 15:25:41 runeaudio kernel: IPv6: Loaded, but administratively disabled, reboot required to enable
Apr 12 15:25:41 runeaudio systemd[1]: Reached target Swap.
Apr 12 15:25:41 runeaudio systemd[1]: Starting Remount Root and Kernel File Systems...
Apr 12 15:25:41 runeaudio systemd-journald[145]: Journal started
Apr 12 15:25:41 runeaudio systemd[1]: Started Apply Kernel Variables.
Apr 12 15:25:41 runeaudio systemd[1]: Started Create Static Device Nodes in /dev.
Apr 12 15:25:41 runeaudio systemd[1]: Starting udev Kernel Device Manager...
Apr 12 15:25:41 runeaudio systemd[1]: Reached target Local File Systems (Pre).
Apr 12 15:25:42 runeaudio systemd[1]: Started udev Kernel Device Manager.
Apr 12 15:25:42 runeaudio systemd[1]: Started udev Coldplug all Devices.
Apr 12 15:25:42 runeaudio systemd[1]: Starting Network Service...
Apr 12 15:25:42 runeaudio systemd[1]: Started Network Service.
Apr 12 15:25:46 runeaudio systemd[1]: Reached target Local File Systems.
Apr 12 15:25:46 runeaudio systemd[1]: Starting Rebuild Dynamic Linker Cache...
Apr 12 15:25:46 runeaudio systemd[1]: Starting Rebuild Journal Catalog...
Apr 12 15:25:46 runeaudio systemd[1]: Starting Create Volatile Files and Directories...
Apr 12 15:25:47 runeaudio systemd[1]: Started Rebuild Journal Catalog.
Apr 12 15:25:47 runeaudio systemd[1]: Started Create Volatile Files and Directories.
Apr 12 15:25:47 runeaudio systemd[1]: Starting Network Name Resolution...
Apr 12 15:25:47 runeaudio systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Apr 12 15:25:47 runeaudio systemd[1]: Started Update UTMP about System Boot/Shutdown.
Apr 12 15:25:48 runeaudio systemd[1]: Started Rebuild Dynamic Linker Cache.
Apr 12 15:25:48 runeaudio systemd[1]: Starting Update is Completed...
Apr 12 15:25:48 runeaudio systemd[1]: Starting Load/Save RF Kill Switch Status...
Apr 12 15:25:49 runeaudio systemd[1]: Started Network Name Resolution.
Apr 12 15:25:49 runeaudio systemd[1]: Reached target Host and Network Name Lookups.
Apr 12 15:25:49 runeaudio systemd[1]: Started Update is Completed.
Apr 12 15:25:49 runeaudio systemd[1]: Reached target System Initialization.
Apr 12 15:25:49 runeaudio systemd[1]: Started Daily rotation of log files.
Apr 12 15:25:49 runeaudio systemd[1]: Started Daily verification of password and group files.
Apr 12 15:25:49 runeaudio systemd[1]: Started Daily Cleanup of Temporary Directories.
Apr 12 15:25:49 runeaudio systemd[1]: Reached target Timers.
Apr 12 15:25:49 runeaudio systemd[1]: Reached target Sockets.
Apr 12 15:25:49 runeaudio systemd[1]: Reached target Basic System.
Apr 12 15:25:49 runeaudio systemd[1]: Started Entropy Harvesting Daemon.
Apr 12 15:25:49 runeaudio systemd[1]: Starting Save/Restore Sound Card State...
Apr 12 15:25:49 runeaudio systemd[1]: Started D-Bus System Message Bus.
Apr 12 15:25:49 runeaudio systemd[1]: Started Rune Audio Amixer-WebUI Service.
Apr 12 15:25:50 runeaudio systemd[1]: Starting NTP client/server...
Apr 12 15:25:50 runeaudio systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Apr 12 15:25:50 runeaudio systemd[1]: Started Load/Save RF Kill Switch Status.
Apr 12 15:25:50 runeaudio systemd[1]: Started Save/Restore Sound Card State.
Apr 12 15:25:50 runeaudio chronyd[209]: chronyd version 3.3 starting (+CMDMON +NTP +REFCLOCK +RTC +PRIVDROP +SCFILTER +SIGND +ASYNCDNS +SECHASH +IPV6 -DEBUG)
Apr 12 15:25:50 runeaudio systemd[1]: Starting Automatic wireless network connection using netctl profiles...
Apr 12 15:25:50 runeaudio systemd[1]: Reached target Sound Card.
Apr 12 15:25:50 runeaudio avahi-daemon[206]: avahi-daemon 0.7 starting up.
Apr 12 15:25:50 runeaudio systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Apr 12 15:25:50 runeaudio avahi-daemon[206]: Loading service file /services/runeaudio.service.
Apr 12 15:25:51 runeaudio systemd[1]: Started NTP client/server.
Apr 12 15:25:51 runeaudio avahi-daemon[206]: Server startup complete. Host name is runeaudio.local. Local service cookie is 2378470307.
Apr 12 15:25:52 runeaudio kernel: ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
Apr 12 15:25:53 runeaudio systemd[1]: Started Automatic wireless network connection using netctl profiles.
Apr 12 15:25:53 runeaudio systemd[1]: Reached target Network.
Apr 12 15:25:53 runeaudio wpa_actiond[241]: Starting wpa_actiond session for interface 'wlan0'
Apr 12 15:25:53 runeaudio systemd[1]: Starting Permit User Sessions...
Apr 12 15:25:53 runeaudio systemd[1]: Starting A high performance web server and a reverse proxy server...
Apr 12 15:25:53 runeaudio systemd[1]: Started OpenSSH Daemon.
Apr 12 15:25:53 runeaudio systemd[1]: Starting Advanced key-value store...
Apr 12 15:25:54 runeaudio systemd[1]: Started Advanced key-value store.
Apr 12 15:25:54 runeaudio systemd[1]: Started Permit User Sessions.
Apr 12 15:25:54 runeaudio systemd[1]: Started Getty on tty1.
Apr 12 15:25:54 runeaudio systemd[1]: Started Serial Getty on ttyAMA0.
Apr 12 15:25:54 runeaudio systemd[1]: Reached target Login Prompts.
Apr 12 15:25:54 runeaudio systemd[1]: Started A high performance web server and a reverse proxy server.
Apr 12 15:26:28 runeaudio chronyd[209]: System clock wrong by 22575583.254463 seconds, adjustment started
Dec 29 22:26:11 runeaudio systemd[1]: Starting Rotate log files...
Dec 29 22:26:11 runeaudio systemd[1]: Started Verify integrity of password and group files.
Dec 29 22:26:11 runeaudio systemd[1]: Started Rotate log files.
Dec 29 22:26:52 runeaudio systemd[1]: sys-subsystem-net-devices-eth0.device: Job sys-subsystem-net-devices-eth0.device/start timed out.
Dec 29 22:26:52 runeaudio systemd[1]: netctl-ifplugd@eth0.service: Job netctl-ifplugd@eth0.service/start failed with result 'dependency'.
Dec 29 22:26:52 runeaudio systemd[1]: sys-subsystem-net-devices-eth0.device: Job sys-subsystem-net-devices-eth0.device/start failed with result 'timeout'.
Dec 29 22:26:52 runeaudio systemd[1]: Reached target Multi-User System.
Dec 29 22:26:52 runeaudio systemd[1]: Reached target Graphical Interface.
Dec 29 22:26:52 runeaudio systemd[1]: Started RuneAudio System Worker.
Dec 29 22:26:52 runeaudio systemd[1]: Startup finished in 23.698s (kernel) + 1min 33.293s (userspace) = 1min 56.992s.
Dec 29 22:26:57 runeaudio rune_SY_wrk[346]: Fatal error: Call to undefined method Redis::exits() in /srv/http/app/libs/runeaudio.php on line 3167
Dec 29 22:26:58 runeaudio systemd[1]: rune_SY_wrk.service: Service hold-off time over, scheduling restart.
Dec 29 22:26:58 runeaudio systemd[1]: rune_SY_wrk.service: Scheduled restart job, restart counter is at 1.
Dec 29 22:26:58 runeaudio systemd[1]: Stopped RuneAudio System Worker.
Dec 29 22:26:58 runeaudio systemd[1]: Started RuneAudio System Worker.
Dec 29 22:27:02 runeaudio rune_SY_wrk[363]: Fatal error: Call to undefined method Redis::exits() in /srv/http/app/libs/runeaudio.php on line 3167
Dec 29 22:27:03 runeaudio systemd[1]: rune_SY_wrk.service: Service hold-off time over, scheduling restart.
Dec 29 22:27:03 runeaudio systemd[1]: rune_SY_wrk.service: Scheduled restart job, restart counter is at 2.
Dec 29 22:27:03 runeaudio systemd[1]: Stopped RuneAudio System Worker.
Dec 29 22:27:03 runeaudio systemd[1]: Started RuneAudio System Worker.
Dec 29 22:27:06 runeaudio rune_SY_wrk[384]: Fatal error: Call to undefined method Redis::exits() in /srv/http/app/libs/runeaudio.php on line 3167
Dec 29 22:27:07 runeaudio systemd[1]: rune_SY_wrk.service: Service hold-off time over, scheduling restart.
Dec 29 22:27:07 runeaudio systemd[1]: rune_SY_wrk.service: Scheduled restart job, restart counter is at 3.
Dec 29 22:27:07 runeaudio systemd[1]: Stopped RuneAudio System Worker.
Dec 29 22:27:07 runeaudio systemd[1]: Started RuneAudio System Worker.
Dec 29 22:27:11 runeaudio rune_SY_wrk[397]: Fatal error: Call to undefined method Redis::exits() in /srv/http/app/libs/runeaudio.php on line 3167
Dec 29 22:27:12 runeaudio systemd[1]: rune_SY_wrk.service: Service hold-off time over, scheduling restart.
Dec 29 22:27:12 runeaudio systemd[1]: rune_SY_wrk.service: Scheduled restart job, restart counter is at 4.
Dec 29 22:27:12 runeaudio systemd[1]: Stopped RuneAudio System Worker.
Dec 29 22:27:12 runeaudio systemd[1]: Started RuneAudio System Worker.
Dec 29 22:27:15 runeaudio rune_SY_wrk[410]: Fatal error: Call to undefined method Redis::exits() in /srv/http/app/libs/runeaudio.php on line 3167
Dec 29 22:27:16 runeaudio systemd[1]: rune_SY_wrk.service: Service hold-off time over, scheduling restart.
Dec 29 22:27:16 runeaudio systemd[1]: rune_SY_wrk.service: Scheduled restart job, restart counter is at 5.
Dec 29 22:27:16 runeaudio systemd[1]: Stopped RuneAudio System Worker.
Dec 29 22:27:16 runeaudio systemd[1]: Started RuneAudio System Worker.
Dec 29 22:27:19 runeaudio rune_SY_wrk[424]: Fatal error: Call to undefined method Redis::exits() in /srv/http/app/libs/runeaudio.php on line 3167
Dec 29 22:27:20 runeaudio systemd[1]: rune_SY_wrk.service: Service hold-off time over, scheduling restart.
Dec 29 22:27:20 runeaudio systemd[1]: rune_SY_wrk.service: Scheduled restart job, restart counter is at 6.
Dec 29 22:27:20 runeaudio systemd[1]: Stopped RuneAudio System Worker.
Dec 29 22:27:20 runeaudio systemd[1]: Started RuneAudio System Worker.
Dec 29 22:27:23 runeaudio rune_SY_wrk[437]: Fatal error: Call to undefined method Redis::exits() in /srv/http/app/libs/runeaudio.php on line 3167
Dec 29 22:27:24 runeaudio systemd[1]: rune_SY_wrk.service: Service hold-off time over, scheduling restart.
Dec 29 22:27:24 runeaudio systemd[1]: rune_SY_wrk.service: Scheduled restart job, restart counter is at 7.
Dec 29 22:27:24 runeaudio systemd[1]: Stopped RuneAudio System Worker.
Dec 29 22:27:24 runeaudio systemd[1]: Started RuneAudio System Worker.
Dec 29 22:27:27 runeaudio rune_SY_wrk[450]: Fatal error: Call to undefined method Redis::exits() in /srv/http/app/libs/runeaudio.php on line 3167
Dec 29 22:27:29 runeaudio systemd[1]: rune_SY_wrk.service: Service hold-off time over, scheduling restart.
Dec 29 22:27:29 runeaudio systemd[1]: rune_SY_wrk.service: Scheduled restart job, restart counter is at 8.
Dec 29 22:27:29 runeaudio systemd[1]: Stopped RuneAudio System Worker.
Dec 29 22:27:29 runeaudio systemd[1]: Started RuneAudio System Worker.
Dec 29 22:27:32 runeaudio rune_SY_wrk[463]: Fatal error: Call to undefined method Redis::exits() in /srv/http/app/libs/runeaudio.php on line 3167
Dec 29 22:27:33 runeaudio systemd[1]: rune_SY_wrk.service: Service hold-off time over, scheduling restart.
Dec 29 22:27:33 runeaudio systemd[1]: rune_SY_wrk.service: Scheduled restart job, restart counter is at 9.
Dec 29 22:27:33 runeaudio systemd[1]: Stopped RuneAudio System Worker.
Dec 29 22:27:33 runeaudio systemd[1]: Started RuneAudio System Worker.
Dec 29 22:27:36 runeaudio rune_SY_wrk[476]: Fatal error: Call to undefined method Redis::exits() in /srv/http/app/libs/runeaudio.php on line 3167
Dec 29 22:27:37 runeaudio systemd[1]: rune_SY_wrk.service: Service hold-off time over, scheduling restart.
Dec 29 22:27:37 runeaudio systemd[1]: rune_SY_wrk.service: Scheduled restart job, restart counter is at 10.
Dec 29 22:27:37 runeaudio systemd[1]: Stopped RuneAudio System Worker.
Dec 29 22:27:37 runeaudio systemd[1]: Started RuneAudio System Worker.
Dec 29 22:27:40 runeaudio rune_SY_wrk[489]: Fatal error: Call to undefined method Redis::exits() in /srv/http/app/libs/runeaudio.php on line 3167
Dec 29 22:27:41 runeaudio systemd[1]: rune_SY_wrk.service: Service hold-off time over, scheduling restart.
Dec 29 22:27:41 runeaudio systemd[1]: rune_SY_wrk.service: Scheduled restart job, restart counter is at 11.
Dec 29 22:27:41 runeaudio systemd[1]: Stopped RuneAudio System Worker.
Dec 29 22:27:41 runeaudio systemd[1]: Started RuneAudio System Worker.
Dec 29 22:27:44 runeaudio rune_SY_wrk[502]: Fatal error: Call to undefined method Redis::exits() in /srv/http/app/libs/runeaudio.php on line 3167
Dec 29 22:27:46 runeaudio systemd[1]: rune_SY_wrk.service: Service hold-off time over, scheduling restart.
Dec 29 22:27:46 runeaudio systemd[1]: rune_SY_wrk.service: Scheduled restart job, restart counter is at 12.
Dec 29 22:27:46 runeaudio systemd[1]: Stopped RuneAudio System Worker.
Dec 29 22:27:46 runeaudio systemd[1]: Started RuneAudio System Worker.
thx for your help
