Hello andre_chang,
MPD needs to be built with the SoXr option to be able to use it. Look at the results of:
mpd --version
It is included if you see this, or something similar:
Filters:
libsamplerate soxr
You should look for the word ‘soxr’, it may be in a different section depending upon the version which you are using. If it is not there MPD will need to be upgraded. I have a couple of pre-built versions which you may be able to use, please tell me the version number which you are currently using.
Swtching SoXr on is dependant on the version of MPD. For v0.19.xx the following line needs to be included in /etc/mpd.conf :
samplerate_converter “soxr very high”
For v0.20.xx this needs to be added to /etc/mpd.conf :
resampler {
plugin "soxr"
quality "very high"
MPD will fail to start if you set Soxr ON when it is not built in.
See the following post for modifying the file /srv/http/db/redis_acards_details file. This is a way of automatically adding the ‘format’ output_block clause for the Hifiberry DAC:
#4434455
We need Franks help to do the same for your WM8805.
