Hey Janui,
Thank you so much for your very detailed response.
I indeed pulled ethernet cat6 cables all over the house, but I'm planning to put the devices (most probably raspberries) in a central location, together with the network devices and the storage devices. I'll pull audio cables to each room from that central point.
Reason for this is
- a) easy to access devices (don't have to start putting them in the walls to hide them
b) always know where the devices are
c) central place for all things that can go wrong (I don't like to run around)
d) possibility to replace the devices (if I later decide to install different hardware that would not fit in the designated room)
I have already purchased the first speakers (water resistant ones for in the bathroom). These seem to be simple analogue. I'm all new to audio hardware, so I don't know how normal this is.
So, saying we go for a RB B3 or B3+ so I can run other services on them also (print server, openhab, ...). I will need 6 such devices, plus a DAC and an amplifier.
I'll have a look around what are the options. I'm not an audiophile, but I really enjoy music, so basic speakers are fine. It's that of play music from my mono cellphone speaker, so anything better than that is a winner
The music is already stored on a NAS (up and around 1TB worth of music), which serves it in multiple fashions (itunes server, samba, nfs). The NAS has 4x1Gbit bonding. it is sufficient to stream at least 4x 4K video plus 6x audio. I'm not worried there
Probably the most important point at this moment is the possibility to control all devices through one interface. As I read your reply, it seems that this is also a possibility. This makes me happy.
Thank you again for the expansive explanation. I'm looking forward to get started.
By the way, the longest audio cables I'll put will be around 15m. I still have to check the type of speakers, but I assume a simple analogue audio cable is capable of traversing this distance?
ofmann
