I am slapping my forehead in amazement.
Not sure why you can't see the photos. I can see them when I view the post.
2. You need to be 100% sure that D: is your SD card. If it contains the files 'Overlays' and 'Kernel7' then it probably is. But I would check in 'My Computer' anyway.
4. This where you are getting stuck I think. The 'Open' button is perhaps confusing things because you're not really opening anything. Just specifying a filename and location. Here's what to do again (again). Follow this
exactly:
- Click little blue folder.
- Specify a location on your PC (if you want, but 'Downloads' is fine for now).
- Type a filename in the box next to the 'Open' button. Or just copy paste this:
RuneMod24-02-18.img
- Click 'Open'
The filename and destination you just entered will now appear in Win32DiskImager.
As long as you know that you've got the correct drive letter in 'Devices' and you are happy with the destination and filename of the file, click 'Read'.
That's it. It will take a few minutes, depending on the size of the SD card and how fast your PC is.
And, by the way, you're not using Linux to do this. You're using Windows.
