1) Yes I have. I have set all the other settings and can get music through the system, it is just the hardware volume control which should be cleaner... When I set it to software volume, I can control it. When I set it to hardware, I get 100% volume. I can mouse it down, but it pops back to 10% as soon as I do it. According to Daniel at hifiberry, it should work as hardware volume control:
You can try to edit mpd.conf by yourself and set the mixer:
mixer_control “Playback Digital”
However as I'm not an expert with these, I can't say for sure that this will work.
Hardware control - always 100% volume and cannot set lower:
name "Output"
mixer_control "Playback Digital"
mixer_device "hw:0"
mixer_index "0"
dop "no"
Software control - variable volume:
name "Output"
dop "no"
list:
aplay -l
card 0: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
2) Yes, I have enabled upnp and airplay in settings. When I hover over the upnp icon from the ? screen, it does not change color. I do not want to mount the filesystem NFS as that is a huge amount of overhead and I'd rather let upnp run it. It does work from Volumio, but I had to turn on their Library View to be able to see it. Interestingly, MPD does not require me to tell it the name of my upnp/dlna server and it 'just shows up' in Volumio.
3) Got it, thanks. add my pls file to this directory: /mnt/MPD/Webradio
I was able to 'resolve' the continuous 'connecting' problem. I updated arch and then did a git pull to update rune. I still have problems 1 & 2.
Thanks!
Keith
