i just upgrade MPD, all working fine, but i have just one problem in on the touchscreen, it's starting correct during the "power on" until the loading screen picture, but when runeaudio is strating running , the 7" began totaly black screen ....... i can work it 100%, from computer, tablett, smartphone .....but impossible from 7" the only problem i have find until now
something more to do????
i am not a code expert, but i get some error on the journalctl ....... now i am looking for some info about errors ........seems not all for the touch screen's problem
in advance tnx for openning my eyes !! sorry for long copy message
results of mpd -V >>>
Music Player Daemon 0.20.12
result of>>>[code]root@runeaudio:~ # journalctl
Feb 22 15:40:16 runeaudio kernel: snd-hifiberry-dac soc:sound: ASoC: CPU DAI (null) not registered
Feb 22 15:40:16 runeaudio kernel: snd-hifiberry-dac soc:sound: snd_soc_register_card() failed: -517
Feb 22 15:40:16 runeaudio kernel: snd-hifiberry-dac soc:sound: pcm5102a-hifi <-> 3f203000.i2s mapping ok
Feb 22 15:40:17 runeaudio systemd[1]: Found device SMSC9512/9514 Fast Ethernet Adapter.
Feb 22 15:40:17 runeaudio systemd[1]: Started Load/Save Screen Backlight Brightness of backlight:rpi_backlight.
Feb 22 15:40:17 runeaudio systemd[1]: Found device /dev/mmcblk0p1.
Feb 22 15:40:17 runeaudio systemd[1]: boot.mount: Directory /boot to mount over is not empty, mounting anyway.
Feb 22 15:40:17 runeaudio systemd[1]: Mounting /boot...
Feb 22 15:40:17 runeaudio kernel: usbcore: registered new interface driver brcmfmac
Feb 22 15:40:17 runeaudio kernel: random: nonblocking pool is initialized
Feb 22 15:40:17 runeaudio kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2412 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2417 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2422 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2427 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2432 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2437 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2442 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2447 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2452 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2457 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2462 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2467 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2472 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: Updating information on frequency 2484 MHz with regulatory rule:
Feb 22 15:40:17 runeaudio kernel: cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
Feb 22 15:40:17 runeaudio kernel: cfg80211: Ignoring regulatory request set by core since the driver uses its own custom regulatory domain
Feb 22 15:40:17 runeaudio kernel: brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
Feb 22 15:40:17 runeaudio kernel: cfg80211: World regulatory domain updated:
Feb 22 15:40:17 runeaudio kernel: cfg80211: DFS Master region: unset
Feb 22 15:40:19 runeaudio systemd-udevd[250]: Process '/var/www/command/refresh_ao' failed with exit code 255.
Feb 22 15:40:19 runeaudio systemd-udevd[239]: Process '/var/www/command/refresh_ao' failed with exit code 255.
Feb 22 15:40:19 runeaudio ifplugd[305]: Using interface eth0/B8:27:EB:2B:76:90 with driver <smsc95xx> (version: 22-Aug-2005)
Feb 22 15:40:19 runeaudio ifplugd[305]: Using detection mode: SIOCETHTOOL
Feb 22 15:40:19 runeaudio ifplugd[305]: Initialization complete, link beat not detected.
Feb 22 15:40:19 runeaudio kernel: smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Feb 22 15:40:19 runeaudio sh[306]: /var/www/command/mpd-watchdog: starting...
Feb 22 15:40:19 runeaudio systemd[1]: Reached target Sound Card.
Feb 22 15:40:19 runeaudio avahi-daemon[309]: Found user 'avahi' (UID 84) and group 'avahi' (GID 84).
Feb 22 15:40:19 runeaudio avahi-daemon[309]: Successfully dropped root privileges.
Feb 22 15:40:19 runeaudio avahi-daemon[309]: avahi-daemon 0.6.32 starting up.
Feb 22 15:40:19 runeaudio avahi-daemon[309]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Feb 22 15:40:19 runeaudio systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Feb 22 15:40:19 runeaudio avahi-daemon[309]: Successfully called chroot().
Feb 22 15:40:19 runeaudio avahi-daemon[309]: Successfully dropped remaining capabilities.
Feb 22 15:40:19 runeaudio avahi-daemon[309]: Loading service file /services/runeaudio.service.
Feb 22 15:40:19 runeaudio avahi-daemon[309]: Network interface enumeration completed.
Feb 22 15:40:19 runeaudio avahi-daemon[309]: Server startup complete. Host name is runeaudio.local. Local service cookie is 1645457898.
Feb 22 15:40:19 runeaudio avahi-daemon[309]: Service "RuneAudio [runeaudio] [b8:27:eb:2b:76:90]" (/services/runeaudio.service) successfully established.
Feb 22 15:40:19 runeaudio systemd[1]: Started Save/Restore Sound Card State.
Feb 22 15:40:19 runeaudio systemd-udevd[245]: Process '/var/www/command/ui_notify.php 'Usb Storage' connected simplemessage' failed with exit code 255.
Feb 22 15:40:20 runeaudio kernel: brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
Feb 22 15:40:20 runeaudio kernel: brcmfmac: brcmf_add_if: ignore IF event
Feb 22 15:40:20 runeaudio kernel: brcmfmac: power management disabled
Feb 22 15:40:20 runeaudio netctl-auto[302]: Could not read interface p2p-dev-wlan0 flags: No such device
Feb 22 15:40:20 runeaudio systemd[1]: Started Automatic wireless network connection using netctl profiles.
Feb 22 15:40:20 runeaudio wpa_actiond[344]: Starting wpa_actiond session for interface 'wlan0'
Feb 22 15:40:20 runeaudio systemd[1]: Reached target Network.
Feb 22 15:40:20 runeaudio systemd[1]: Starting Network Time Service...
Feb 22 15:40:20 runeaudio systemd[1]: Started OpenSSH Daemon.
Feb 22 15:40:20 runeaudio systemd[1]: Starting Advanced key-value store...
Feb 22 15:40:20 runeaudio systemd[1]: Starting A high performance web server and a reverse proxy server...
Feb 22 15:40:20 runeaudio systemd[1]: Started RuneAudio Playback Worker.
Feb 22 15:40:20 runeaudio systemd[1]: Starting The PHP FastCGI Process Manager...
Feb 22 15:40:20 runeaudio systemd[1]: Started Advanced key-value store.
Feb 22 15:40:20 runeaudio ntpd[345]: ntpd 4.2.8p9@1.3265-o Sat Jan 14 21:31:12 UTC 2017 (1): Starting
Feb 22 15:40:20 runeaudio ntpd[345]: Command line: /usr/bin/ntpd -g -u ntp:ntp
Feb 22 15:40:20 runeaudio systemd[1]: Started Network Time Service.
Feb 22 15:40:20 runeaudio systemd-udevd[245]: Process '/var/www/command/refresh_ao' failed with exit code 255.
Feb 22 15:40:20 runeaudio rune_PL_wrk[352]: Fatal error: Uncaught exception 'RedisException' with message 'Redis server went away' in /srv/http/app/libs/runeaudio.php:1
Feb 22 15:40:20 runeaudio rune_PL_wrk[352]: Stack trace:
Feb 22 15:40:20 runeaudio rune_PL_wrk[352]: #0 /srv/http/app/libs/runeaudio.php(1259): Redis->get('debug')
Feb 22 15:40:20 runeaudio rune_PL_wrk[352]: #1 /srv/http/app/libs/runeaudio.php(789): runelog('sysCmd($str)', 'echo "---------...')
Feb 22 15:40:20 runeaudio rune_PL_wrk[352]: #2 /srv/http/command/rune_PL_wrk(42): sysCmd('echo "---------...')
Feb 22 15:40:20 runeaudio rune_PL_wrk[352]: #3 {main}
Feb 22 15:40:20 runeaudio rune_PL_wrk[352]: thrown in /srv/http/app/libs/runeaudio.php on line 1259
Feb 22 15:40:20 runeaudio systemd[1]: rune_PL_wrk.service: Main process exited, code=exited, status=255/n/a
Feb 22 15:40:20 runeaudio systemd[1]: rune_PL_wrk.service: Unit entered failed state.
Feb 22 15:40:20 runeaudio systemd[1]: rune_PL_wrk.service: Failed with result 'exit-code'.
Feb 22 15:40:36 runeaudio sudo[676]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/xinit
Feb 22 15:40:36 runeaudio sudo[676]: pam_unix(sudo:session): session opened for user root by (uid=0)
Feb 22 15:40:36 runeaudio devmon[619]: device: [/dev/sda1]
Feb 22 15:40:36 runeaudio devmon[619]: systeminternal: [0]
Feb 22 15:40:36 runeaudio devmon[619]: usage: [filesystem]
Feb 22 15:40:36 runeaudio devmon[619]: type: [vfat]
Feb 22 15:40:36 runeaudio devmon[619]: label: [ROMANO]
Feb 22 15:40:36 runeaudio devmon[619]: ismounted: [0]
Feb 22 15:40:36 runeaudio devmon[619]: nopolicy: [0]
Feb 22 15:40:36 runeaudio devmon[619]: hasmedia: [1]
Feb 22 15:40:36 runeaudio devmon[619]: opticaldisc: []
Feb 22 15:40:36 runeaudio devmon[619]: numaudiotracks: []
Feb 22 15:40:36 runeaudio devmon[619]: blank: []
Feb 22 15:40:36 runeaudio devmon[619]: media: []
Feb 22 15:40:36 runeaudio devmon[619]: partition: [1]
Feb 22 15:40:36 runeaudio devmon[619]: devmon: /usr/sbin/udevil --mount /dev/sda1 --mount-options "noexec,nosuid,nodev,noatime" # (ROMANO)
Feb 22 15:40:36 runeaudio kernel: FAT-fs (sda1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
Feb 22 15:40:36 runeaudio kernel: FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Feb 22 15:40:38 runeaudio devmon[619]: Warning: Missing argument 2 for ui_libraryHome(), called in /srv/http/command/usbmount on line 66 and defined in /srv/http/app/li
Feb 22 15:40:38 runeaudio devmon[619]: Notice: Undefined index: enable in /srv/http/app/libs/runeaudio.php on line 3474
Feb 22 15:40:38 runeaudio devmon[619]: Notice: Trying to get property of non-object in /srv/http/app/libs/runeaudio.php on line 3318
Feb 22 15:40:38 runeaudio devmon[619]: Notice: Undefined variable: clientUUID in /srv/http/app/libs/runeaudio.php on line 3318
Feb 22 15:40:38 runeaudio devmon[619]: Mounted /dev/sda1 at /mnt/MPD/USB/ROMANO
Feb 22 15:40:39 runeaudio systemd[1]: Reloading.
Feb 22 15:40:40 runeaudio systemd[1]: Reloading.
Feb 22 15:40:41 runeaudio systemd[1]: Stopping Automatic wireless network connection using netctl profiles...
Feb 22 15:40:41 runeaudio netctl-auto[952]: /usr/bin/netctl-auto: line 222: kill: (344) - No such process
Feb 22 15:40:42 runeaudio sudo[676]: pam_unix(sudo:session): session closed for user root
Feb 22 15:40:43 runeaudio systemd[1]: Stopped Automatic wireless network connection using netctl profiles.
Feb 22 15:40:44 runeaudio systemd[1]: Started Hostapd IEEE 802.11 AP, IEEE 802.1X/WPA/WPA2/EAP/RADIUS Authenticator.
Feb 22 15:40:44 runeaudio hostapd[985]: Configuration file: /etc/hostapd/hostapd.conf
Feb 22 15:40:44 runeaudio hostapd[985]: Failed to create interface mon.wlan0: -95 (Operation not supported)
Feb 22 15:40:44 runeaudio hostapd[985]: wlan0: Could not connect to kernel driver
Feb 22 15:40:44 runeaudio hostapd[985]: Using interface wlan0 with hwaddr b8:27:eb:7e:23:c5 and ssid "RuneAudioAP"
Feb 22 15:40:44 runeaudio systemd[1]: Starting A lightweight DHCP and caching DNS server...
Feb 22 15:40:44 runeaudio hostapd[985]: random: Only 15/20 bytes of strong random data available from /dev/random
Feb 22 15:40:44 runeaudio hostapd[985]: random: Not enough entropy pool available for secure operations
Feb 22 15:40:44 runeaudio hostapd[985]: WPA: Not enough entropy in random pool for secure operations - update keys later when the first station connects
Feb 22 15:40:44 runeaudio dnsmasq[989]: dnsmasq: syntax check OK.
Feb 22 15:40:44 runeaudio kernel: brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
Feb 22 15:40:44 runeaudio kernel: brcmfmac: brcmf_add_if: ignore IF event
