Let me explain in more detail what I've done after the last update of RuneAudio_Addons left my installation inoperable.
1. Base Installation
- Flashing a 8GB SD Card using Windows and the "USB Image Tool" using RuneAudio_rpi2_rp3_0.4-beta_20170229_2GB.img
- Boot the Pi
- Configuring my old settings
a) mpd.conf:
auto_update "yes"
audio_buffer_size "4096"
buffer_before_play "20%"
mixer_type "disabled"
replaygain "off"
name "snd_rpi_hifiberry_digi"
b) disable "HDMI & 3,5mm jack"
c) disable WLAN (modifying /etc/modprobe.d/disable_rpi3_wifi_bt.conf)
d) Extend partition to 8GB as described in
http://www.runeaudio.com/documentation/
e) setting dev-mode after removing /var/www/command/mpd-watchdog
f) update via "git pull"
2. Installing RuneAudio_Addons via SSH
wget -qN --show-progress --no-check-certificate https://github.com/rern/RuneAudio_Addons/raw/master/install.sh; chmod +x install.sh; ./install.sh
Observation: This step took an extremely long time during the download of master.zip (between 30 to 50 minutes (!). Instead, a test download of master.zip from the git was immediate.
After that the "Addons" menu is available but without any functionality.
Herbert
