Hi guys,
Sorry for the mess.
What happened?:
- RuneAudio 0.4b downloads and uses
jQuery UI with <script src="
https://code.jquery.com/ui/1.12.0/jquery-ui.js"></script>
- Previous RuneUI Enhancement update switched from online download to a local file instead by
commenting out the jQuery UI script line.
- This brought an issue as the line in
footer.php is the last line with
no trailing new line.
- A script for show/hide items feature,
hammer.min.js, which was appended to the file with
echo command ended up in the same line as
jquery-ui.js. So it was
also commented out which caused error for the feature.
- Then along came the mess.
- Tried to fix it by
inserting a new line during Addons Menu installation but it left a lot of blank lines after multiple updates.
- Tried with
heredoc but it just made the code cleaner, no escaped single quotes
- Tried to get rid of the blank lines with
sed command and it worked.
- Since
heredoc and sed modified the same file,
moved heredoc lines to sed to do it in single command.
No escaped single quotes in heredoc must be
escaped in sed but I
missed it.
- Appending lines to the end with
sed, There's even
no more blank lines in the first place.
Now it was fixed. Please uninstall > reinstall Addons Menu
By the way, a by-product of the fixing process is a feature like a
silver bullet to restore RuneUI to default in case of something was wrong.
Browser URL:
< RuneAudio_IP >/restoreui.php
- available after install / update / reinstall
Addons Menu
- RuneUI
restored to default (header.php, playback.php, footer.php with
Addons Menu ready)
- click
Menu > Addons to reinstall Addons Menu
- installed addons
show update status
update each addon to get them back
