janui Hi jackyworne, See here: https://www.raspberrypi.org/documentation/installation/installing-images/linux.md janui
R101 If you are running one of the Ubuntu variants, the easiest way is to use the "restore disk image" option in the gnome-disks utility.
hondagx35 Hi, what is wrong with this doc? http://www.runeaudio.com/documentation/quick-start/sd-card-setup-linux/ Frank
spilltone Hello, I don't have the issues above. My setup works well with webradios, on a B rev2 with Hifiberry Digi.
iruka I would like to use OpenVPN to be able to use webradio. if I try to install with packman I get a error message> resolving dependencies... looking for conflicting packages... :: systemd-libs and libsystemd are in conflict. Remove libsystemd? [y/N] n error: unresolvable package conflicts detected error: failed to prepare transaction (conflicting dependencies) :: systemd-libs and libsystemd are in conflict [root@runeaudio ~]# systemd-libs and libsystemd are in conflict. Remove libsystemd? pacman --sync --refresh -bash: systemd-libs: command not found I guess I need some older version? Any one have any information? Regards,
