Hi viperman3,
Each day the webgui will stop responding to inputs.
You wrote that the UI is not accessible, how did you get the debug info?
Is the debug info from before or after this happens?
I think your problems start here:
[35156.049169] systemd[1]: Stopping Music Player Daemon...
[35246.247308] systemd[1]: mpd.service stop-sigterm timed out. Killing.
[35282.020275] INFO: task decoder:808 blocked for more than 120 seconds.
[35426.747921] systemd[1]: mpd.service stop-final-sigterm timed out. Killing.
[35516.832214] systemd[1]: mpd.service still around after final SIGKILL. Entering failed mode.
[35516.832856] systemd[1]: Unit mpd.service entered failed state.
[35516.832917] systemd[1]: mpd.service failed.
If this happens again, it would be helpful to get the output from:
- free
- df
- systemctl
Another odd issue I've noticed is the IP address registered to the Pi2 shows up with two IP (192.168.2.30, which is the static IP I setup with "runeaudio" as hostname and 192.168.2.55 which shows up with "RUNEAUDIO" as the hostname
You can solve this by executing this command:
systemctl disable dhcpcd.service
