Bjarne Hi I got a Asus RT N66U router with USB where I can connect a USB HDD. Does anybody know if it's possible to play the music on it with Rune Audio? Just connecting it to the router I can see it in windows explorer Thanks in advance Bjarne
ACX That should be a Samba share, so the answer is yes. Go to Menu > Sources > Add new mount, select "SMB/CIFS" as Fileshare protocol, put your router's IP address and set correctly the Remote directory (you have to know it to make it work). That's all...
Bjarne Thanks I know the IP and set it to "SMB/CIFS", but I'm not shure about the Remote dir. I have tried different path according to picture, but without success Capture.JPG (23.88 KiB) Viewed 3135 times
Bjarne Music is playing But there is no cover art? There is a jpg file called "Folder.jpg" in same dir as music. /Bjarne
Bjarne How many mounts is it possible to make to the same HDD on my router? I tried to make 9 because my music is placed in different genres and to avoid too much clicking down path. But it only mounts a part of them and when remount all it's a different number that is mounted? /Bjarne
ACX Why don't you use the "Add to favorites" feature for that? You find it the contextual menu of each folder.
ACX Bjarne wroteBut back to my question. Is there a limit for how many mounts you can make?/Bjarne Not that I know of, but I never tested it with so many mounts...
