Why Orion? Each sound signature can sound slightly different on some systems. The developer of the new settings liked the 'Orion' settings as a starting point.
How to isolate the cpu - see
#86245
The DEV branch is a newer development version of the RuneAudio app - this is needed for some of the modification to work.
HDMI - your choice.
If you have an ethernet connection to your Pi instead of using wifi, disabling the wifi will reduce the boot time to around 10 seconds. This can be achieved by typing '
systemctl disable netctl-auto@wlan0' in a console session, i.e. PuTTY.
Your four '
renice -10' instructions go in the Orion profile. See extract from ealier post below:-
Orion Optimize Mods (/var/www/command/orion_optimize.sh)
nano /var/www/command/orion_optimize.sh
# common startup #
#if [ "$PID" != null ]; then
#echo "Set priority for: cifsd"
#renice -20 $PID
#fi
cifsprio pid=$(pidof cifsd)
echo "Set normal priority for: rune_SY_wrk"
renice 20 $(pgrep rune_SY_wrk)
echo "Set normal priority for: rune_PL_wrk"
renice 20 $(pgrep rune_PL_wrk)
echo "Set normal priority for: smbd"
renice 19 $(pidof smbd)
echo "Set normal priority for: nmbd"
renice 19 $(pidof nmbd)
#runeFrost
renice -10 -p 3
renice -10 -p 12
renice -10 -p 16
renice -10 -p 20
The '
renice 19' instruction should be already present in the Orion file. I don't recognise the 'taskset' instruction so can't advise on that one.
