Hello everyone,
i have raspberry pi3 release version: 0.4 (build: beta-20141216)
now sold my PS Audio DAC i use a dragonfly black but is not detected!
please help me that's my debug
Linux version 4.14.39-1-ARCH (builduser@leming) (gcc version 7.3.1 20180406 (GCC)) #1 SMP Sat May 5 19:22:41 UTC 2018
system time: Mon Feb 22 15:40:26 CET 2016
system load: 0.73 0.16 0.05 1/134 708
HW platform: unknown (--)
playerID: --da712d152cb6ec3a33c300d9e053d71f
RAM: 935.92MiB 156.00MiB 779.93MiB 14.52MiB
Swap: 0.00B 0.00B 0.00B
Bootup: Mon Feb 22 15:40:09 2016 Load average: 0.73 0.16 0.05 2/136 710
user : 00:00:05.62 9.0% page in : 147017
nice : 00:00:01.26 2.0% page out: 472
system: 00:00:07.26 11.6% page act: 10323
IOwait: 00:00:08.77 14.0% page dea: 0
hw irq: 00:00:00.00 0.0% page flt: 117534
sw irq: 00:00:00.18 0.3% swap in : 0
idle : 00:00:39.54 63.1% swap out: 0
uptime: 00:00:16.52 context : 73939
irq 16: 0 irq 54: 2163
irq 17: 6384 irq 55: 0
irq 21: 0 irq 56: 0
irq 23: 42 irq 59: 0
irq 24: 2 irq 62: 26618
irq 46: 0 irq 83: 2
irq 48: 0 irq 86: 50
irq 50: 0 irq 92: 7297
irq 51: 17
mmcblk0 2183r mmcblk0p2 2113r
mmcblk0p1 59r sda 1079r 0w
eth0 TX 962.00B RX 773.00B wlan0 TX 0.00B RX 0.00B
lo TX 160.65KiB RX 160.65KiB
systemd-+-agetty
|-avahi-daemon---avahi-daemon
|-dbus-daemon
|-devmon---udevil
|-ifplugd---netctl.action---network---dhcpcd
|-mount.ntfs
|-mpd-+-{decoder}
| |-{io}
| |-{mpd}
| |-{output:default }
| `-{player}
|-nginx---nginx
|-nmbd
|-ntpd---{ntpd}
|-php-fpm---3*[php-fpm]
|-rune_PL_wrk
|-rune_SY_wrk
|-sh---sleep
|-sshd
|-systemd-journal
|-systemd-resolve
|-systemd-udevd
`-wpa_supplicant
Advanced Linux Sound Architecture Driver Version k4.14.39-1-ARCH.
0 [v15 ]: USB-Audio - AudioQuest DragonFly Black v1.5
AudioQuest AudioQuest DragonFly Black v1.5 at usb-3f980000.usb-1.4, full speed
PLAYBACK devices: (aplay -l)
card 0: v15 [AudioQuest DragonFly Black v1.5], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
PCM devices: (aplay -L)
null
default:CARD=v15
AudioQuest DragonFly Black v1.5, USB Audio
Default Audio Device
sysdefault:CARD=v15
front:CARD=v15,DEV=0
Front speakers
surround21:CARD=v15,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=v15,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=v15,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=v15,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=v15,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=v15,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=v15,DEV=0
IEC958 (S/PDIF) Digital Audio Output
card 0:
Simple mixer control 'PCM',0
card 0:
numid=3,iface=MIXER,name='PCM Playback Volume'
numid=1,iface=PCM,name='Playback Channel Map'
Output 1 (default detected output) is enabled
###### mpd version ######
mpd version: 0.19.0
log_level "verbose"
zeroconf_name "runeaudio"
auto_update "yes"
audio_buffer_size "2048"
buffer_before_play "10%"
mixer_type "disabled"
replaygain "off"
hardware platform: unknown
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 18000000
/proc/sys/kernel/sched_rr_timeslice_ms: 100
Module = "snd_usb_audio"
Attributes:
coresize = "159744"
initsize = "0"
initstate = "live"
refcnt = "0"
taint = ""
uevent =
Parameters:
autoclock = "Y"
device_setup = "0,0,0,0,0,0,0,0"
enable = "Y,Y,Y,Y,Y,Y,Y,Y"
id = "(null),(null),(null),(null),(null),(null),(null),(null)"
ignore_ctl_error = "N"
index = "-1,-1,-1,-1,-1,-1,-1,-1"
pid = "-1,-1,-1,-1,-1,-1,-1,-1"
quirk_alias = "(null),(null),(null),(null),(null),(null),(null),(null)"
vid = "-1,-1,-1,-1,-1,-1,-1,-1"
Sections:
.ARM.exidx = "0x7f47e9d4"
.ARM.exidx.exit.text= "0x7f47bce0"
.ARM.exidx.init.text= "0x7f47bcd8"
.alt.smp.init = "0x7f47e9cc"
.bss = "0x7f481d80"
.data = "0x7f480000"
.exit.text = "0x7f476228"
.gnu.linkonce.this_module= "0x7f481b80"
.init.text = "0x7f48d000"
.note.gnu.build-id = "0x7f477000"
.rodata = "0x7f477028"
.rodata.str1.4 = "0x7f47bce8"
.strtab = "0x7f4944a0"
.symtab = "0x7f48e000"
.text = "0x7f465000"
__param = "0x7f47e918"
total 8.0K
drwxr-xr-x 2 root root 4.0K Feb 22 2016 .
drwxr-xr-x 6 root root 4.0K Mar 13 2016 ..
lrwxrwxrwx 1 root root 44 Mar 21 2016
netctl-auto@wlan0.service -> /usr/lib/systemd/system/netctl-auto@.service
lrwxrwxrwx 1 root root 47 Feb 22 2016
netctl-ifplugd@eth0.service -> /usr/lib/systemd/system/netctl-ifplugd@.service
lrwxrwxrwx 1 root root 36 Feb 15 2015 ntpd.service -> /usr/lib/systemd/system/ntpd.service
lrwxrwxrwx 1 root root 48 Feb 8 2015 systemd-resolved.service -> /usr/lib/systemd/system/systemd-resolved.service
/dev/root / ext4 rw,relatime,stripe=32679,data=ordered 0 0
devtmpfs /dev devtmpfs rw,relatime,size=474584k,nr_inodes=118646,mode=755 0 0
cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=25,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2332 0 0
tmpfs /tmp tmpfs rw 0 0
fusectl /sys/fs/fuse/connections fusectl rw,relatime 0 0
/dev/sda1 /mnt/MPD/USB/Musica fuseblk rw,nosuid,nodev,noexec,noatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 0 0
/dev/root 15G 1.9G 12G 14% /
devtmpfs 464M 0 464M 0% /dev
tmpfs 468M 0 468M 0% /dev/shm
tmpfs 468M 6.2M 462M 2% /run
tmpfs 468M 0 468M 0% /sys/fs/cgroup
tmpfs 468M 0 468M 0% /tmp
logs 5.0M 12K 5.0M 1% /var/log
rune-logs 5.0M 40K 5.0M 1% /var/log/runeaudio
/dev/mmcblk0p1 100M 22M 79M 22% /boot
/dev/sda1 1.9T 759G 1.1T 41% /mnt/MPD/USB/Musica
###### Loaded kernel modules ######
Module Size Used by
fuse 102400 3
snd_usb_audio 159744 0
snd_hwdep 16384 1 snd_usb_audio
snd_usbmidi_lib 28672 1 snd_usb_audio
snd_rawmidi 32768 1 snd_usbmidi_lib
snd_seq_device 16384 1 snd_rawmidi
brcmfmac 217088 0
brcmutil 16384 1 brcmfmac
cfg80211 577536 1 brcmfmac
snd_soc_wm8804_i2c 16384 0
snd_soc_wm8804 16384 1 snd_soc_wm8804_i2c
snd_soc_bcm2835_i2s 16384 0
snd_soc_hifiberry_digi 16384 0
snd_soc_core 176128 3 snd_soc_wm8804,snd_soc_bcm2835_i2s,snd_soc_hifiberry_digi
i2c_bcm2835 16384 0
snd_compress 20480 1 snd_soc_core
bcm2835_rng 16384 0
rng_core 16384 1 bcm2835_rng
snd_pcm_dmaengine 16384 1 snd_soc_core
uio_pdrv_genirq 16384 0
fixed 16384 0
uio 16384 1 uio_pdrv_genirq
sch_fq_codel 20480 3
snd_bcm2835 32768 0
snd_pcm 94208 6 snd_soc_wm8804,snd_usb_audio,snd_pcm_dmaengine,snd_soc_bcm2835_i2s,snd_bcm2835,snd_soc_core
snd_timer 32768 1 snd_pcm
snd 65536 10 snd_compress,snd_hwdep,snd_usb_audio,snd_timer,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_bcm2835,snd_soc_core,snd_pcm
ip_tables 24576 0
x_tables 28672 1 ip_tables
ipv6 438272 0
tcp 0 0 0.0.0.0:6600 0.0.0.0:* LISTEN 394/mpd
tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 283/redis-server 12
tcp 0 0 0.0.0.0:5355 0.0.0.0:* LISTEN 279/systemd-resolve
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 292/nginx: master p
tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 292/nginx: master p
tcp 0 0 0.0.0.0:82 0.0.0.0:* LISTEN 292/nginx: master p
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 275/sshd
udp 0 0 0.0.0.0:68 0.0.0.0:* 357/dhcpcd
udp 0 0 0.0.0.0:36966 0.0.0.0:* 246/avahi-daemon: r
udp 0 0 127.0.0.1:123 0.0.0.0:* 286/ntpd
udp 0 0 0.0.0.0:123 0.0.0.0:* 286/ntpd
udp 0 0 0.0.0.0:137 0.0.0.0:* 339/nmbd
udp 0 0 0.0.0.0:138 0.0.0.0:* 339/nmbd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 246/avahi-daemon: r
udp 0 0 0.0.0.0:5355 0.0.0.0:* 279/systemd-resolve
unix 2 [ ACC ] STREAM LISTENING 15364 283/redis-server 12 /tmp/redis.sock
unix 2 [ ACC ] STREAM LISTENING 2315 1/init /run/systemd/private
unix 2 [ ACC ] SEQPACKET LISTENING 2323 1/init /run/udev/control
unix 2 [ ACC ] SEQPACKET LISTENING 2326 1/init /run/systemd/coredump
unix 2 [ ACC ] STREAM LISTENING 3871 1/init /run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 3874 1/init /var/run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 2337 1/init /run/systemd/journal/stdout
unix 2 [ ACC ] STREAM LISTENING 3876 1/init /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 16016 435/php-fpm: master /var/run/php-display.sock
unix 2 [ ACC ] STREAM LISTENING 16019 435/php-fpm: master /var/run/php-db.sock
unix 2 [ ACC ] STREAM LISTENING 16022 435/php-fpm: master /var/run/php-command.sock
unix 2 [ ACC ] STREAM LISTENING 16594 394/mpd /run/mpd.sock
###### Network established sockets (netstat -np) ######
Active Internet connections (w/o servers)
tcp 0 0 127.0.0.1:54176 127.0.0.1:6379 TIME_WAIT -
Active UNIX domain sockets (w/o servers)
unix 3 [ ] DGRAM 2313 1/init /run/systemd/notify
unix 2 [ ] DGRAM 13333 271/wpa_supplicant /run/wpa_supplicant/p2p-dev-wlan0
unix 5 [ ] DGRAM 2340 1/init /run/systemd/journal/socket
unix 6 [ ] DGRAM 2362 1/init /run/systemd/journal/dev-log
unix 2 [ ] DGRAM 2644 271/wpa_supplicant /run/wpa_supplicant/wlan0
unix 2 [ ] DGRAM 13606 339/nmbd /var/lib/samba/private/msg.sock/339
unix 3 [ ] STREAM CONNECTED 14346 292/nginx: master p
unix 3 [ ] STREAM CONNECTED 2614 232/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13819 394/mpd
unix 3 [ ] STREAM CONNECTED 3888 1/init
unix 2 [ ] DGRAM 14971 1/init
unix 3 [ ] STREAM CONNECTED 3573 177/systemd-udevd
unix 3 [ ] STREAM CONNECTED 2465 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16369 394/mpd /run/mpd.sock
unix 3 [ ] STREAM CONNECTED 14119 303/php
unix 3 [ ] STREAM CONNECTED 14739 447/php
unix 3 [ ] STREAM CONNECTED 12081 232/dbus-daemon
unix 3 [ ] STREAM CONNECTED 14022 283/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 2660 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16861 274/php
unix 3 [ ] STREAM CONNECTED 2603 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16878 283/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 13510 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16863 274/php
unix 3 [ ] STREAM CONNECTED 2809 303/php
unix 3 [ ] STREAM CONNECTED 12170 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13798 283/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 14091 702/php
unix 3 [ ] STREAM CONNECTED 14120 283/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 3971 274/php
unix 3 [ ] STREAM CONNECTED 12276 279/systemd-resolve
unix 2 [ ] DGRAM 14337 286/ntpd
unix 3 [ ] STREAM CONNECTED 2742 286/ntpd
unix 3 [ ] STREAM CONNECTED 2741 286/ntpd
unix 2 [ ] DGRAM 13999 687/mount.ntfs
unix 3 [ ] STREAM CONNECTED 14347 292/nginx: master p
unix 2 [ ] DGRAM 11717 177/systemd-udevd
unix 3 [ ] DGRAM 11723 177/systemd-udevd
unix 3 [ ] STREAM CONNECTED 14742 232/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] DGRAM 11722 177/systemd-udevd
unix 3 [ ] STREAM CONNECTED 2600 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 15763 399/bash
unix 3 [ ] STREAM CONNECTED 13716 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13146 229/ifplugd
unix 3 [ ] STREAM CONNECTED 13392 275/sshd
unix 3 [ ] STREAM CONNECTED 12172 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 4092 279/systemd-resolve
unix 3 [ ] STREAM CONNECTED 13470 232/dbus-daemon /run/dbus/system_bus_socket
unix 2 [ ] DGRAM 628 151/systemd-journal
unix 2 [ ] DGRAM 4086 279/systemd-resolve
unix 3 [ ] STREAM CONNECTED 16000 435/php-fpm: master
unix 3 [ ] STREAM CONNECTED 13191 231/sh
unix 2 [ ] DGRAM 15620 357/dhcpcd
unix 3 [ ] STREAM CONNECTED 12282 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 14692 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16015 435/php-fpm: master
unix 3 [ ] STREAM CONNECTED 16014 435/php-fpm: master
unix 3 [ ] STREAM CONNECTED 15437 292/nginx: master p
unix 3 [ ] STREAM CONNECTED 2591 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 15436 292/nginx: master p
unix 3 [ ] STREAM CONNECTED 13252 246/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 2615 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13457 283/redis-server 12
unix 3 [ ] STREAM CONNECTED 2627 249/avahi-daemon: c
unix 3 [ ] STREAM CONNECTED 2626 246/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 2613 232/dbus-daemon
unix 3 [ ] STREAM CONNECTED 2631 246/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 12151 232/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 2612 232/dbus-daemon
unix 2 [ ] DGRAM 2623 246/avahi-daemon: r
###### Network interfaces (ip addr) ######
1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: eth0: mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether b8:27:eb:d4:7e:41 brd ff:ff:ff:ff:ff:ff
3: wlan0: mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether b8:27:eb:81:2b:14 brd ff:ff:ff:ff:ff:ff
###### Network interfaces (ifconfig) ######
eth0: flags=4163 mtu 1500
ether b8:27:eb:d4:7e:41 txqueuelen 1000 (Ethernet)
RX packets 4 bytes 773 (773.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 5 bytes 962 (962.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73 mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1000 (Local Loopback)
RX packets 3771 bytes 178812 (174.6 KiB)
TX packets 3771 bytes 178812 (174.6 KiB)
wlan0: flags=4099 mtu 1500
ether b8:27:eb:81:2b:14 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
###### Network netctl profiles (netctl list) ######
eth0
eth0 netctl status
netctl@eth0.service - Networking for netctl profile eth0
Loaded: loaded (/usr/lib/systemd/system/netctl@.service; static; vendor preset: disabled)
Active: inactive (dead)
Docs: man:netctl.profile(5)
eth0 netctl profile
Description='eth0 connection'
Interface=eth0
ForceConnect=yes
SkipNoCarrier=yes
Connection=ethernet
IP=dhcp
###### Network wifi status (iwconfig) ######
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
###### Kernel status (dmesg) ######
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.39-1-ARCH (builduser@leming) (gcc version 7.3.1 20180406 (GCC)) #1 SMP Sat May 5 19:22:41 UTC 2018
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 8 MiB at 0x3b800000
[ 0.000000] On node 0 totalpages: 245760
[ 0.000000] free_area_init_node: node 0, pgdat 80f9c340, node_mem_map baf86000
[ 0.000000] Normal zone: 2160 pages used for memmap
[ 0.000000] Normal zone: 245760 pages, LIFO batch:31
[ 0.000000] random: get_random_bytes called from start_kernel+0x84/0x418 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu @baf2f000 s39564 r8192 d21876 u69632
[ 0.000000] pcpu-alloc: s39564 r8192 d21876 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 243600
[ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 root=/dev/mmcblk0p2 rw rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 kgdboc=ttyS0,115200 elevator=noop ipv6.disable=1 quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 949168K/983040K available (10240K kernel code, 696K rwdata, 2640K rodata, 1024K init, 745K bss, 25680K reserved, 8192K cma-reserved)
vmalloc : 0xbc800000 - 0xff800000 (1072 MB)
lowmem : 0x80000000 - 0xbc000000 ( 960 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80b00000 (11232 kB)
.init : 0x80e00000 - 0x80f00000 (1024 kB)
.data : 0x80f00000 - 0x80fae1bc ( 697 kB)
.bss : 0x80fb8ee0 - 0x810736d4 ( 746 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000004] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000009] Switching to timer-based delay loop, resolution 52ns
[ 0.000137] Console: colour dummy device 80x30
[ 0.000146] console [tty1] enabled
[ 0.000158] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000166] pid_max: default: 32768 minimum: 301
[ 0.000324] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000332] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000881] Disabling memory control group subsystem
[ 0.000931] CPU: Testing write buffer coherency: ok
[ 0.001161] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001365] Setting up static identity map for 0x100000 - 0x100054
[ 0.001427] Hierarchical SRCU implementation.
[ 0.001749] smp: Bringing up secondary CPUs ...
[ 0.002156] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.002578] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.002972] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.003018] smp: Brought up 1 node, 4 CPUs
[ 0.003023] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.003025] CPU: All CPU(s) started in HYP mode.
[ 0.003027] CPU: Virtualization extensions available.
[ 0.003508] devtmpfs: initialized
[ 0.008494] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.008622] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008631] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.008900] xor: measuring software checksum speed
[ 0.100005] arm4regs : 1845.600 MB/sec
[ 0.200040] 8regs : 1373.600 MB/sec
[ 0.300078] 32regs : 1324.000 MB/sec
[ 0.400112] neon : 2098.400 MB/sec
[ 0.400114] xor: using function: neon (2098.400 MB/sec)
[ 0.400121] pinctrl core: initialized pinctrl subsystem
[ 0.400517] NET: Registered protocol family 16
[ 0.401961] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.404198] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.404201] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.404315] Serial: AMBA PL011 UART driver
[ 0.405012] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.405203] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.580352] raid6: int32x1 gen() 205 MB/s
[ 0.750280] raid6: int32x1 xor() 190 MB/s
[ 0.920462] raid6: int32x2 gen() 329 MB/s
[ 1.090486] raid6: int32x2 xor() 248 MB/s
[ 1.260507] raid6: int32x4 gen() 339 MB/s
[ 1.430532] raid6: int32x4 xor() 268 MB/s
[ 1.600619] raid6: int32x8 gen() 334 MB/s
[ 1.770721] raid6: int32x8 xor() 248 MB/s
[ 1.940753] raid6: neonx1 gen() 703 MB/s
[ 2.110773] raid6: neonx1 xor() 700 MB/s
[ 2.280831] raid6: neonx2 gen() 1048 MB/s
[ 2.450894] raid6: neonx2 xor() 983 MB/s
[ 2.620952] raid6: neonx4 gen() 1501 MB/s
[ 2.791019] raid6: neonx4 xor() 1306 MB/s
[ 2.961078] raid6: neonx8 gen() 1442 MB/s
[ 3.131154] raid6: neonx8 xor() 1164 MB/s
[ 3.131157] raid6: using algorithm neonx4 gen() 1501 MB/s
[ 3.131159] raid6: .... xor() 1306 MB/s, rmw enabled
[ 3.131162] raid6: using neon recovery algorithm
[ 3.131383] bcm2835-dma 3f007000.dma: DMA legacy API manager at bc813000, dmachans=0x1
[ 3.132090] SCSI subsystem initialized
[ 3.132193] usbcore: registered new interface driver usbfs
[ 3.132216] usbcore: registered new interface driver hub
[ 3.132261] usbcore: registered new device driver usb
[ 3.133242] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-05-08 17:30
[ 3.134131] clocksource: Switched to clocksource arch_sys_counter
[ 3.194114] VFS: Disk quotas dquot_6.6.0
[ 3.194190] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 3.194314] FS-Cache: Loaded
[ 3.194425] CacheFiles: Loaded
[ 3.198248] NET: Registered protocol family 2
[ 3.198637] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 3.198691] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.198783] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.198856] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 3.198878] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 3.199032] NET: Registered protocol family 1
[ 3.199290] RPC: Registered named UNIX socket transport module.
[ 3.199293] RPC: Registered udp transport module.
[ 3.199294] RPC: Registered tcp transport module.
[ 3.199297] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.200252] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 3.201443] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 3.205165] FS-Cache: Netfs 'nfs' registered for caching
[ 3.205459] NFS: Registering the id_resolver key type
[ 3.205476] Key type id_resolver registered
[ 3.205478] Key type id_legacy registered
[ 3.205486] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 3.205758] JFS: nTxBlock = 7479, nTxLock = 59835
[ 3.210262] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 3.213442] async_tx: api initialized (async)
[ 3.213475] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 3.213535] io scheduler noop registered (default)
[ 3.213538] io scheduler deadline registered
[ 3.213665] io scheduler cfq registered
[ 3.213668] io scheduler mq-deadline registered
[ 3.213671] io scheduler kyber registered
[ 3.213742] io scheduler bfq registered
[ 3.215207] BCM2708FB: allocated DMA memory fb910000
[ 3.215222] BCM2708FB: allocated DMA channel 0 @ bc813000
[ 3.219945] Console: switching to colour frame buffer device 82x26
[ 3.222470] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 3.222664] vc-sm: Videocore shared memory driver
[ 3.222786] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 3.227173] loop: module loaded
[ 3.227181] Loading iSCSI transport class v2.0-870.
[ 3.227544] libphy: Fixed MDIO Bus: probed
[ 3.227682] usbcore: registered new interface driver lan78xx
[ 3.227704] usbcore: registered new interface driver ax88179_178a
[ 3.227728] usbcore: registered new interface driver smsc95xx
[ 3.227754] usbcore: registered new interface driver cdc_ncm
[ 3.227757] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 3.455534] Core Release: 2.80a
[ 3.455540] Setting default values for core params
[ 3.455553] Finished setting default values for core params
[ 3.655668] Using Buffer DMA mode
[ 3.655671] Periodic Transfer Interrupt Enhancement - disabled
[ 3.655673] Multiprocessor Interrupt Enhancement - disabled
[ 3.655677] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.655692] Dedicated Tx FIFOs mode
[ 3.655890] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbb904000 dma = 0xfb904000 len=9024
[ 3.655903] FIQ FSM acceleration enabled for :
Periodic Split Transactions
[ 3.655906] dwc_otg: Microframe scheduler enabled
[ 3.655933] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8084f9b8
[ 3.655937] WARN::hcd_init_fiq:460: FIQ ASM at 0x8084fd30 length 36
[ 3.655943] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbcc7a000
[ 3.655969] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.655984] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.656001] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 3.656035] Init: Port Power? op_state=1
[ 3.656037] Init: Power Port (0)
[ 3.656132] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.656137] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.656141] usb usb1: Product: DWC OTG Controller
[ 3.656145] usb usb1: Manufacturer: Linux 4.14.39-1-ARCH dwc_otg_hcd
[ 3.656148] usb usb1: SerialNumber: 3f980000.usb
[ 3.656433] hub 1-0:1.0: USB hub found
[ 3.656455] hub 1-0:1.0: 1 port detected
[ 3.656704] dwc_otg: FIQ enabled
[ 3.656706] dwc_otg: NAK holdoff enabled
[ 3.656708] dwc_otg: FIQ split-transaction FSM enabled
[ 3.656712] Module dwc_common_port init
[ 3.656801] usbcore: registered new interface driver uas
[ 3.656842] usbcore: registered new interface driver usb-storage
[ 3.656858] usbcore: registered new interface driver ums-alauda
[ 3.656875] usbcore: registered new interface driver ums-cypress
[ 3.656894] usbcore: registered new interface driver ums-datafab
[ 3.656910] usbcore: registered new interface driver ums_eneub6250
[ 3.656926] usbcore: registered new interface driver ums-freecom
[ 3.656942] usbcore: registered new interface driver ums-isd200
[ 3.656959] usbcore: registered new interface driver ums-jumpshot
[ 3.656975] usbcore: registered new interface driver ums-karma
[ 3.656993] usbcore: registered new interface driver ums-onetouch
[ 3.657016] usbcore: registered new interface driver ums-realtek
[ 3.657033] usbcore: registered new interface driver ums-sddr09
[ 3.657049] usbcore: registered new interface driver ums-sddr55
[ 3.657066] usbcore: registered new interface driver ums-usbat
[ 3.657234] mousedev: PS/2 mouse device common for all mice
[ 3.657582] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 3.657814] device-mapper: uevent: version 1.0.3
[ 3.657954] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised:
dm-devel@redhat.com
[ 3.658169] device-mapper: multipath round-robin: version 1.2.0 loaded
[ 3.658172] device-mapper: multipath queue-length: version 0.2.0 loaded
[ 3.658174] device-mapper: multipath service-time: version 0.3.0 loaded
[ 3.658180] device-mapper: raid: Loading target version 1.13.0
[ 3.658280] bcm2835-cpufreq: min=1200000 max=1200000
[ 3.658473] sdhci: Secure Digital Host Controller Interface driver
[ 3.658475] sdhci: Copyright(c) Pierre Ossman
[ 3.658651] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 3.658797] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 3.658840] Error: Driver 'sdhost-bcm2835' is already registered, aborting...
[ 3.658935] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.659984] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.660075] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.660204] usbcore: registered new interface driver usbhid
[ 3.660206] usbhid: USB HID core driver
[ 3.660587] vchiq: vchiq_init_state: slot_zero = bb980000, is_master = 0
[ 3.661479] [vc_sm_connected_init]: start
[ 3.668305] [vc_sm_connected_init]: end - returning 0
[ 3.668628] Initializing XFRM netlink socket
[ 3.668639] NET: Registered protocol family 17
[ 3.668734] Key type dns_resolver registered
[ 3.669075] Registering SWP/SWPB emulation handler
[ 3.669742] registered taskstats version 1
[ 3.670248] Btrfs loaded, crc32c=crc32c-generic
[ 3.670583] Key type encrypted registered
[ 3.673385] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.673429] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 3.674330] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 3.674334] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 3.734456] sdhost: log_buf @ bb907000 (fb907000)
[ 3.772346] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.773837] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.775324] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.777983] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.814136] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.814608] of_cfs_init
[ 3.814656] of_cfs_init: OK
[ 3.814873] md: Waiting for all devices to be available before autodetect
[ 3.814875] md: If you don't use raid, use raid=noautodetect
[ 3.815236] md: Autodetecting RAID arrays.
[ 3.815238] md: autorun ...
[ 3.815240] md: ... autorun DONE.
[ 3.815274] Waiting for root device /dev/mmcblk0p2...
[ 3.851429] random: fast init done
[ 3.874189] Indeed it is in host mode hprt0 = 00021501
[ 3.888001] mmc1: new high speed SDIO card at address 0001
[ 3.945056] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.948497] mmc0: new high speed SDHC card at address aaaa
[ 3.948720] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ 3.950701] mmcblk0: p1 p2
[ 3.981754] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.981785] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.989132] devtmpfs: mounted
[ 3.990056] Freeing unused kernel memory: 1024K
[ 4.084158] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 4.084238] Indeed it is in host mode hprt0 = 00001101
[ 4.271456] systemd[1]: System time before build time, advancing clock.
[ 4.334294] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 4.334302] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.334634] hub 1-1:1.0: USB hub found
[ 4.334682] hub 1-1:1.0: 5 ports detected
[ 4.355922] IPv6: Loaded, but administratively disabled, reboot required to enable
[ 4.365784] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.369452] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.376845] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.378534] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 4.378858] systemd[1]: Detected architecture arm.
[ 4.379650] systemd[1]: Set hostname to .
[ 4.422410] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read)
[ 4.674157] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.809387] systemd[1]: Created slice System Slice.
[ 4.809622] systemd[1]: Listening on udev Control Socket.
[ 4.810042] systemd[1]: Created slice system-getty.slice.
[ 4.812802] systemd[1]: Listening on Process Core Dump Socket.
[ 4.813298] systemd[1]: Created slice system-netctl\x2dauto.slice.
[ 4.813364] systemd[1]: Reached target System Time Synchronized.
[ 4.813770] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.824379] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 4.824386] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.826845] smsc95xx v1.0.6
[ 4.915998] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:d4:7e:41
[ 5.059841] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.437184] bcm2835-rng 3f104000.rng: hwrng registered
[ 5.454712] snd-hifiberry-digi soc:sound: ASoC: CPU DAI (null) not registered - will retry
[ 5.455189] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 5.510787] wm8804 1-003b: Failed to read device ID: -121
[ 5.511226] wm8804: probe of 1-003b failed with error -121
[ 5.641240] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 5.644943] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[ 5.645085] usbcore: registered new interface driver brcmfmac
[ 5.645398] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 5.723294] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 5.819862] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[ 5.821000] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[ 5.894194] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 5.975316] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 6.104934] usb 1-1.2: New USB device found, idVendor=0bc2, idProduct=231a
[ 6.104944] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.104948] usb 1-1.2: Product: Expansion
[ 6.104952] usb 1-1.2: Manufacturer: Seagate
[ 6.104956] usb 1-1.2: SerialNumber: NA865PBB
[ 6.106294] usb 1-1.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
[ 6.106302] usb 1-1.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
[ 6.106355] usb 1-1.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
[ 6.106359] usb 1-1.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
[ 6.106365] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 6.111314] scsi host0: usb-storage 1-1.2:1.0
[ 6.112103] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 6.300077] brcmfmac: power management disabled
[ 6.302636] random: crng init done
[ 6.302643] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.404150] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[ 6.537997] usb 1-1.4: New USB device found, idVendor=21b4, idProduct=0083
[ 6.538006] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.538010] usb 1-1.4: Product: AudioQuest DragonFly Black v1.5
[ 6.538014] usb 1-1.4: Manufacturer: AudioQuest
[ 6.538018] usb 1-1.4: SerialNumber: AQDFBL0100102319
[ 7.124614] scsi 0:0:0:0: Direct-Access Seagate Expansion 0707 PQ: 0 ANSI: 6
[ 7.125720] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 7.506317] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC3E1
[ 11.605191] hid-generic 0003:21B4:0083.0001: hiddev96,hidraw0: USB HID v1.11 Device [AudioQuest AudioQuest DragonFly Black v1.5] on usb-3f980000.usb-1.4/input2
[ 11.605563] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 11.631080] snd_usb_audio: unknown parameter 'nrpacks' ignored
[ 11.635240] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 11.641207] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 11.641294] usbcore: registered new interface driver snd-usb-audio
[ 12.270133] brcmfmac: power management disabled
[ 12.374508] sd 0:0:0:0: [sda] 3907029167 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 12.374796] sd 0:0:0:0: [sda] Write Protect is off
[ 12.374803] sd 0:0:0:0: [sda] Mode Sense: 47 00 00 08
[ 12.375104] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 12.403099] sda: sda1
[ 12.405094] sd 0:0:0:0: [sda] Attached SCSI disk
[ 14.261001] fuse init (API version 7.26)
###### PHP backend ######
php version: 5.5.19
debug level: 0
