Ripa wrote
About Qobuz streaming access, I am using my Qobuz streaming account with the BubbleUPnP app for Android, using the RuneAudio player as a UPnP/DLNA renderer. It works flawlessly, even with HiRes 192kHz 24 bit.
The only tricky bit is if you have active player queues running both on the Bubble and Rune, they are taking turns in what is played which can be surprising sometimes. It is best to clear the queue that is not used.
BN
Hi BN,
Can you help me with this step by step to make this work, please
does it also work for deezer
thx
Jempie
Hi Jempie,
To use RuneAudio, BubbleUPnP and Qobuz, you need an Android pad or phone, and a running RuneAudio unit with UPnP/DLNA enabled, all on the same network. On the Android, install BubbleUPnP. You may select use the free version to start with, you may want to pay for a licensed version later to get rid of the ads, plus some other limitations.
On the top left of the BuppleUPnP app there is a menu, tap on it and you will see RENDERER, LIBRARY and Settings.
Under RENDERER you should see "Local Renderer", which is you Android unit, and "RuneAudioUPnP", which is your RuneAudio player. Select "RuneAudioUPnP".
Open library "Local and Cloud", select Qobuz and enter your credentials.
Browse the Qobuz for music in main bottom right tab Library, add tracks to the middle tab Playlist, tap on an item in the playlist to play it.
This is it, really.
(I will NOT describe the details of how to use BubbleUPnP here, it is off-topic in this forum, please refer to the appropriate docs, help, or forums for this).
deezer I have used, so there you are on your own.
BN
