Get many times after rebooting RPI Could not connect to Runeaudio (Airplay) message. Only way to 'solve' this problem is writing a clean image onto the micro sd card.
My debug info:
Linux version 4.4.39-ARCH+ (frank@franks-ubuntu) (gcc version 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Linaro GCC 2013.11) ) #5 SMP Sat Feb 11 15:43:36 CET 2017
system time: Mon Feb 22 15:40:28 CET 2016
system load: 0.72 0.16 0.05 2/168 783
HW platform: RaspberryPi2 (08)
playerID: 08b26fff2ac4ddac6fee7fbbc1890504ae
###### Boot configuration ######
# Uncomment some or all of these to enable the optional hardware interfaces
# Params:
# i2c_arm Set to "on" to enable the ARM's i2c interface
# (default "off")
# i2c_vc Set to "on" to enable the i2c interface
# usually reserved for the VideoCore processor
# (default "off")
# i2c_arm_baudrate Set the baudrate of the ARM's i2c interface
# (default "100000")
# i2c_vc_baudrate Set the baudrate of the VideoCore i2c interface
# i2c_baudrate An alias for i2c_arm_baudrate
# i2s Set to "on" to enable the i2s interface
# (default "off")
# spi Set to "on" to enable the spi interfaces
# (default "off")
# act_led_trigger Choose which activity the LED tracks.
# Use "heartbeat" for a nice load indicator.
# (default "mmc")
# act_led_activelow Set to "on" to invert the sense of the LED
# (default "off")
# act_led_gpio Set which GPIO pin to use for the activity LED
# (in case you want to connect it to an external
# device)
# (default "16" on a non-Plus board, "47" on a
# Plus or Pi 2)
# N.B. It is recommended to only enable those interfaces that are needed.
# Leaving all interfaces enabled can lead to unwanted behaviour (i2c_vc
# interfering with Pi Camera, I2S and SPI hogging GPIO pins, etc.)
# Note also that i2c, i2c_arm and i2c_vc are aliases for the physical
# interfaces i2c0 and i2c1. Use of the numeric variants is still possible
# but deprecated because the ARM/VC assignments differ between board
# revisions. The same board-specific mapping applies to i2c_baudrate,
# and the other i2c baudrate parameters.
#dtparam=i2c_arm=on
#dtparam=i2c_vc=on
#dtparam=i2s=on
#dtparam=spi=on
#dtparam=act_led_trigger=mmc
#dtdebug=on
#dtparam=uart1=off
#dtoverlay=pi3-disable-bt-overlay
#dtoverlay=pi3-miniuart-bt-overlay
## RuneAudio HDMI & 3,5mm jack
dtparam=audio=off
## RuneAudio I2S-Settings
dtoverlay=hifiberry-digi-pro
# Uncomment to enable the lirc-rpi module
# Params: gpio_out_pin GPIO pin for output (default "17")
# gpio_in_pin GPIO pin for input (default "18")
# gpio_in_pull Pull up/down/off on the input pin
# (default "down")
# sense Override the IR receive auto-detection logic:
# "1" = force active high
# "0" = force active low
# "-1" = use auto-detection
# (default "-1")
# softcarrier Turn the software carrier "on" or "off"
# (default "on")
# invert "on" = invert the output pin (default "off")
# debug "on" = enable additional debug messages
# (default "off")
#dtoverlay=lirc-rpi
#dtparam=gpio_out_pin=17
#dtparam=gpio_in_pin=18
#dtparam=gpio_in_pull=down
# LCD settings
# 180 degrees
#lcd_rotate=2
# Normal
lcd_rotate=0
#dtoverlay=rpi-backlight
#dtoverlay=rpi-ft5406
disable_splash=1
# Uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# Uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# Uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# Uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# Uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# Uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# Uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
# Uncomment to set monitor mode to DMT
#hdmi_group=2
# Uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# setting the max usb current to 1200mA
max_usb_current=1
# memory options
gpu_mem=64
# Overclocking options
force_turbo=1
RAM: 922.56MiB 229.86MiB 692.71MiB 17.89MiB
Swap: 0.00B 0.00B 0.00B
Bootup: Mon Feb 22 15:40:09 2016 Load average: 0.72 0.16 0.05 5/175 791
user : 00:00:12.04 16.6% page in : 140243
nice : 00:00:03.44 4.7% page out: 848
system: 00:00:10.41 14.3% page act: 8877
IOwait: 00:00:07.75 10.7% page dea: 0
hw irq: 00:00:00.00 0.0% page flt: 126195
sw irq: 00:00:00.32 0.4% swap in : 0
idle : 00:00:38.77 53.3% swap out: 0
uptime: 00:00:19.14 context : 38382
irq 16: 0 irq 50: 0
irq 17: 7780 irq 51: 0
irq 23: 22 irq 62: 7607
irq 24: 2 irq 79: 0
irq 39: 1 irq 80: 0
irq 46: 0 irq 83: 21
irq 48: 3336 irq 86: 100
mmcblk0 3310r mmcblk0p2 3205r
mmcblk0p1 63r
eth0 TX 2.57KiB RX 602.00B lo TX 149.59KiB RX 149.59KiB
systemd-+-at-spi-bus-laun-+-dbus-daemon
| |-{dconf worker}
| |-{gdbus}
| |-{gmain}
| `-{pool}
|-at-spi2-registr-+-{gdbus}
| `-{gmain}
|-avahi-daemon---avahi-daemon
|-cmd_async---sh---sudo---xinit-+-Xorg-+-{llvmpipe-0}
| | |-{llvmpipe-1}
| | |-{llvmpipe-2}
| | `-{llvmpipe-3}
| `-sh-+-matchbox-window
| `-midori-+-{llvmpipe-0}
| |-{llvmpipe-1}
| |-{llvmpipe-2}
| `-{llvmpipe-3}
|-2*[dbus-daemon]
|-dbus-launch
|-devmon---udevil
|-dhcpcd
|-dnsmasq
|-haveged
|-ifplugd
|-mpd-+-{decoder}
| |-{io}
| |-{output:snd_rpi_}
| `-{player}
|-nginx---nginx
|-nmbd
|-ntpd---{ntpd}
|-php-fpm---3*[php-fpm]
|-rune_PL_wrk
|-rune_SY_wrk
|-sh---sleep
|-shairport---{shairport}
|-sshd
|-systemd-journal
|-systemd-udevd
|-upmpdcli
`-xbindkeys
Advanced Linux Sound Architecture Driver Version k4.4.39-ARCH+.
0 [sndrpihifiberry]: snd_rpi_hifiber - snd_rpi_hifiberry_digi
PLAYBACK devices: (aplay -l)
card 0: sndrpihifiberry [snd_rpi_hifiberry_digi], device 0: HiFiBerry Digi+ Pro HiFi wm8804-spdif-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
PCM devices: (aplay -L)
null
default:CARD=sndrpihifiberry
snd_rpi_hifiberry_digi,
Default Audio Device
sysdefault:CARD=sndrpihifiberry
card 0:
Simple mixer control 'Tx Source',0
card 0:
numid=1,iface=MIXER,name='Tx Source'
Output 1 (snd_rpi_hifiberry_digi) is enabled
MPD statistics: (mpc stats)
Artists: 0
Albums: 0
Songs: 0
Play Time: 0 days, 0:00:00
Uptime: 0 days, 0:00:06
DB Updated: Sat Feb 25 23:14:18 2017
DB Play Time: 0 days, 0:00:00
###### mpd version ######
Music Player Daemon 0.19.19-dsd
Copyright (C) 2003-2007 Warren Dukes
Copyright (C) 2008-2014 Max Kellermann
This is free software; see the source for copying conditions. There is NO
warranty; not even MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Database plugins:
simple proxy upnp
Storage plugins:
local smbclient nfs
Neighbor plugins:
smbclient upnp
Decoders plugins:
[mad] mp3 mp2
[vorbis] ogg oga
[oggflac] ogg oga
[flac] flac
[sndfile] wav aiff aif au snd paf iff svx sf voc w64 pvf xi htk caf sd2
[audiofile] wav au aiff aif
[dsdiff] dff
[dsf] dsf
[faad] aac
[ffmpeg] 16sv 3g2 3gp 4xm 8svx aa3 aac ac3 afc aif aifc aiff al alaw amr anim apc ape asf atrac au aud avi avm2 avs bap bfi c93 cak cin cmv cpk daud dct divx dts dv dvd dxa eac3 film flac flc fli fll flx flv g726 gsm gxf iss m1v m2v m2t m2ts m4a m4b m4v mad mj2 mjpeg mjpg mka mkv mlp mm mmf mov mp+ mp1 mp2 mp3 mp4 mpc mpeg mpg mpga mpp mpu mve mvi mxf nc nsv nut nuv oga ogm ogv ogx oma ogg omg opus psp pva qcp qt r3d ra ram rl2 rm rmvb roq rpl rvc shn smk snd sol son spx str swf tak tgi tgq tgv thp ts tsp tta xa xvid uv uv2 vb vid vob voc vp6 vmd wav webm wma wmv wsaud wsvga wv wve
[pcm]
Output plugins:
null fifo pipe alsa jack httpd
Encoder plugins:
null vorbis wave flac
Input plugins:
file alsa curl ffmpeg smbclient nfs mms
Playlist plugins:
extm3u m3u pls xspf asx rss soundcloud cue embcue
Protocols:
file:// http:// https:// mms:// mmsh:// mmst:// mmsu:// gopher:// rtp:// rtsp:// rtmp:// rtmpt:// rtmps:// smb:// nfs:// alsa://
zeroconf_name "runeaudio"
auto_update "no"
audio_buffer_size "2048"
buffer_before_play "10%"
mixer_type "software"
replaygain "off"
name "snd_rpi_hifiberry_digi"
hardware platform: RaspberryPi2
current orionprofile: ACX
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 3500075
/proc/sys/kernel/sched_rr_timeslice_ms: 10
total 8.0K
drwxr-xr-x 2 root root 4.0K Feb 25 2017 .
drwxr-xr-x 6 root root 4.0K Dec 15 2016 ..
lrwxrwxrwx 1 root root 44 Jan 29 2017 amixer-webui.service -> /usr/lib/systemd/system/amixer-webui.service
lrwxrwxrwx 1 root root 47 Oct 19 2016 netctl-ifplugd@eth0.service -> /usr/lib/systemd/system/netctl-ifplugd@.service
lrwxrwxrwx 1 root root 36 Feb 15 2015 ntpd.service -> /usr/lib/systemd/system/ntpd.service
devtmpfs /dev devtmpfs rw,relatime,size=468036k,nr_inodes=117009,mode=755 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=27,pgrp=1,timeout=0,minproto=5,maxproto=5,direct 0 0
tmpfs /tmp tmpfs rw 0 0
/dev/root 1.9G 1.7G 98M 95% /
devtmpfs 458M 0 458M 0% /dev
tmpfs 462M 0 462M 0% /dev/shm
tmpfs 462M 6.1M 456M 2% /run
tmpfs 462M 0 462M 0% /sys/fs/cgroup
tmpfs 462M 4.0K 462M 1% /tmp
logs 5.0M 20K 5.0M 1% /var/log
rune-logs 5.0M 24K 5.0M 1% /var/log/runeaudio
/dev/mmcblk0p1 100M 19M 82M 19% /boot
###### Loaded kernel modules ######
Module Size Used by
iptable_filter 1708 1
xt_conntrack 2972 1
ipt_MASQUERADE 1235 1
nf_nat_masquerade_ipv4 2915 1 ipt_MASQUERADE
iptable_nat 1943 1
nf_conntrack_ipv4 13702 2
nf_defrag_ipv4 1677 1 nf_conntrack_ipv4
nf_nat_ipv4 5699 1 iptable_nat
nf_nat 15862 2 nf_nat_ipv4,nf_nat_masquerade_ipv4
nf_conntrack 101212 5 nf_nat,nf_nat_ipv4,xt_conntrack,nf_nat_masquerade_ipv4,nf_conntrack_ipv4
cfg80211 498228 0
snd_soc_wm8804_i2c 1897 1
snd_soc_wm8804 8799 1 snd_soc_wm8804_i2c
regmap_i2c 3560 1 snd_soc_wm8804_i2c
snd_soc_bcm2835_i2s 6278 2
snd_soc_hifiberry_digi 4367 0
snd_soc_core 153224 3 snd_soc_wm8804,snd_soc_bcm2835_i2s,snd_soc_hifiberry_digi
snd_pcm_dmaengine 5503 1 snd_soc_core
snd_pcm 88980 3 snd_soc_wm8804,snd_soc_core,snd_pcm_dmaengine
snd_timer 22172 1 snd_pcm
snd 63333 3 snd_soc_core,snd_timer,snd_pcm
bcm2835_gpiomem 3638 0
i2c_bcm2708 5382 0
bcm2835_wdt 3756 0
bcm2835_rng 2167 0
rng_core 8183 1 bcm2835_rng
uio_pdrv_genirq 3539 0
uio 9114 1 uio_pdrv_genirq
sch_fq_codel 8174 2
ip_tables 12147 2 iptable_filter,iptable_nat
x_tables 18169 4 ip_tables,ipt_MASQUERADE,xt_conntrack,iptable_filter
ipv6 372060 0
tcp 0 0 0.0.0.0:6600 0.0.0.0:* LISTEN 466/mpd
tcp 0 0 0.0.0.0:5002 0.0.0.0:* LISTEN 480/shairport
tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 305/redis-server 12
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 332/nginx: master p
tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 332/nginx: master p
tcp 0 0 0.0.0.0:82 0.0.0.0:* LISTEN 332/nginx: master p
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 709/dnsmasq
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 286/sshd
udp 0 0 127.0.0.1:53 0.0.0.0:* 709/dnsmasq
udp 0 0 0.0.0.0:67 0.0.0.0:* 709/dnsmasq
udp 0 0 0.0.0.0:68 0.0.0.0:* 753/dhcpcd
udp 0 0 192.168.178.17:123 0.0.0.0:* 311/ntpd
udp 0 0 127.0.0.1:123 0.0.0.0:* 311/ntpd
udp 0 0 0.0.0.0:123 0.0.0.0:* 311/ntpd
udp 0 0 0.0.0.0:32903 0.0.0.0:* 280/avahi-daemon: r
udp 0 0 192.168.178.255:137 0.0.0.0:* -
udp 0 0 192.168.178.17:137 0.0.0.0:* -
udp 0 0 0.0.0.0:137 0.0.0.0:* 395/nmbd
udp 0 0 192.168.178.255:138 0.0.0.0:* -
udp 0 0 192.168.178.17:138 0.0.0.0:* -
udp 0 0 0.0.0.0:138 0.0.0.0:* 395/nmbd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 280/avahi-daemon: r
unix 2 [ ACC ] STREAM LISTENING 12991 558/Xorg @/tmp/.X11-unix/X0
unix 2 [ ACC ] STREAM LISTENING 10036 466/mpd /run/mpd.sock
unix 2 [ ACC ] STREAM LISTENING 11320 305/redis-server 12 /tmp/redis.sock
unix 2 [ ACC ] STREAM LISTENING 16389 789/dbus-daemon @/tmp/dbus-dPsXrtp5xE
unix 2 [ ACC ] STREAM LISTENING 16537 - /var/run/samba/nmbd/unexpected
unix 2 [ ACC ] STREAM LISTENING 9628 1/init /run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 9631 1/init /var/run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 9633 1/init /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 13992 532/php-fpm: master /var/run/php-display.sock
unix 2 [ ACC ] STREAM LISTENING 13995 532/php-fpm: master /var/run/php-db.sock
unix 2 [ ACC ] STREAM LISTENING 14322 775/dbus-daemon @/tmp/dbus-2JlKMr4IvK
unix 2 [ ACC ] STREAM LISTENING 13998 532/php-fpm: master /var/run/php-command.sock
unix 2 [ ACC ] STREAM LISTENING 12992 558/Xorg /tmp/.X11-unix/X0
unix 2 [ ACC ] STREAM LISTENING 1496 1/init /run/systemd/private
unix 2 [ ACC ] SEQPACKET LISTENING 1504 1/init /run/udev/control
unix 2 [ ACC ] SEQPACKET LISTENING 1520 1/init /run/systemd/coredump
unix 2 [ ACC ] STREAM LISTENING 1522 1/init /run/systemd/journal/stdout
###### Network established sockets (netstat -np) ######
Active Internet connections (w/o servers)
tcp 0 0 127.0.0.1:45520 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:45844 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:46100 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47168 127.0.0.1:6600 ESTABLISHED 470/upmpdcli
tcp 0 0 127.0.0.1:6600 127.0.0.1:47168 ESTABLISHED 466/mpd
Active UNIX domain sockets (w/o servers)
unix 2 [ ] DGRAM 11685 395/nmbd /var/lib/samba/private/msg.sock/395
unix 3 [ ] DGRAM 1494 1/init /run/systemd/notify
unix 8 [ ] DGRAM 1508 1/init /run/systemd/journal/dev-log
unix 4 [ ] DGRAM 1524 1/init /run/systemd/journal/socket
unix 3 [ ] STREAM CONNECTED 13976 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 11473 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 14529 558/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 10437 332/nginx: master p
unix 3 [ ] STREAM CONNECTED 11315 311/ntpd
unix 3 [ ] STREAM CONNECTED 10655 305/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 15460 269/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15518 770/php
unix 3 [ ] STREAM CONNECTED 2004 542/php
unix 3 [ ] STREAM CONNECTED 10375 305/redis-server 12
unix 3 [ ] STREAM CONNECTED 10223 558/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 13963 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 9681 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 12966 549/php
unix 3 [ ] STREAM CONNECTED 11905 480/shairport
unix 2 [ ] DGRAM 15467 709/dnsmasq
unix 2 [ ] DGRAM 10394 280/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 12997 558/Xorg
unix 3 [ ] STREAM CONNECTED 13991 532/php-fpm: master
unix 3 [ ] STREAM CONNECTED 12068 532/php-fpm: master
unix 3 [ ] STREAM CONNECTED 10396 280/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 14533 305/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 9811 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 12098 305/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 10436 332/nginx: master p
unix 3 [ ] STREAM CONNECTED 11885 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 9663 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 15459 709/dnsmasq
unix 3 [ ] STREAM CONNECTED 10401 280/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 13246 774/dbus-launch
unix 3 [ ] STREAM CONNECTED 11969 489/bash
unix 3 [ ] STREAM CONNECTED 13240 774/dbus-launch
unix 3 [ ] STREAM CONNECTED 11429 332/nginx: master p
unix 3 [ ] STREAM CONNECTED 12762 470/upmpdcli
unix 3 [ ] STREAM CONNECTED 10397 316/avahi-daemon: c
unix 3 [ ] STREAM CONNECTED 13062 588/matchbox-window
unix 3 [ ] STREAM CONNECTED 13961 269/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13132 590/midori
unix 3 [ ] STREAM CONNECTED 11277 269/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 10257 291/haveged
unix 3 [ ] STREAM CONNECTED 12119 269/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 10537 351/php
unix 3 [ ] STREAM CONNECTED 13990 532/php-fpm: master
unix 2 [ ] DGRAM 1986 311/ntpd
unix 3 [ ] STREAM CONNECTED 15442 558/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 10623 361/php
unix 3 [ ] STREAM CONNECTED 11428 332/nginx: master p
unix 3 [ ] STREAM CONNECTED 14323 558/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 11316 311/ntpd
unix 3 [ ] STREAM CONNECTED 15520 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13966 269/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13251 778/at-spi-bus-laun
unix 3 [ ] STREAM CONNECTED 10122 542/php
unix 2 [ ] DGRAM 10044 466/mpd
unix 2 [ ] DGRAM 10136 554/sudo
unix 3 [ ] STREAM CONNECTED 14017 305/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 10041 466/mpd
unix 3 [ ] STREAM CONNECTED 9637 1/init
unix 3 [ ] STREAM CONNECTED 8975 269/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15521 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13252 778/at-spi-bus-laun
unix 2 [ ] STREAM CONNECTED 10134 554/sudo
unix 3 [ ] DGRAM 9457 223/systemd-udevd
unix 3 [ ] DGRAM 9458 223/systemd-udevd
unix 3 [ ] STREAM CONNECTED 14626 351/php
unix 3 [ ] STREAM CONNECTED 16396 792/at-spi2-registr
unix 2 [ ] DGRAM 13726 753/dhcpcd
unix 3 [ ] STREAM CONNECTED 15536 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 9128 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 15551 558/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 9181 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 14545 778/at-spi-bus-laun
unix 3 [ ] STREAM CONNECTED 15537 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 14088 557/xinit
unix 3 [ ] STREAM CONNECTED 15528 775/dbus-daemon @/tmp/dbus-2JlKMr4IvK
unix 3 [ ] STREAM CONNECTED 16408 775/dbus-daemon @/tmp/dbus-2JlKMr4IvK
unix 3 [ ] STREAM CONNECTED 16397 792/at-spi2-registr
unix 3 [ ] STREAM CONNECTED 14531 775/dbus-daemon
unix 3 [ ] STREAM CONNECTED 10139 466/mpd /run/mpd.sock
unix 3 [ ] STREAM CONNECTED 7967 280/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 16404 792/at-spi2-registr
unix 3 [ ] STREAM CONNECTED 8974 269/dbus-daemon
unix 3 [ ] STREAM CONNECTED 12209 558/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15586 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16405 792/at-spi2-registr
unix 3 [ ] STREAM CONNECTED 1919 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16392 789/dbus-daemon @/tmp/dbus-dPsXrtp5xE
unix 3 [ ] STREAM CONNECTED 7919 274/ifplugd
unix 3 [ ] STREAM CONNECTED 14565 792/at-spi2-registr
unix 3 [ ] STREAM CONNECTED 14564 789/dbus-daemon @/tmp/dbus-dPsXrtp5xE
unix 3 [ ] STREAM CONNECTED 8061 286/sshd
unix 3 [ ] STREAM CONNECTED 13951 480/shairport
unix 3 [ ] STREAM CONNECTED 8973 269/dbus-daemon
unix 3 [ ] STREAM CONNECTED 12181 558/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 14532 775/dbus-daemon
unix 3 [ ] STREAM CONNECTED 14595 590/midori
unix 3 [ ] STREAM CONNECTED 14072 361/php
unix 3 [ ] STREAM CONNECTED 14563 590/midori
unix 2 [ ] DGRAM 7456 168/systemd-journal
unix 3 [ ] STREAM CONNECTED 8602 223/systemd-udevd
unix 3 [ ] STREAM CONNECTED 14326 590/midori
unix 3 [ ] STREAM CONNECTED 12998 305/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 14596 775/dbus-daemon @/tmp/dbus-2JlKMr4IvK
unix 3 [ ] STREAM CONNECTED 7661 1/init /run/systemd/journal/stdout
unix 2 [ ] DGRAM 14188 1/init
unix 3 [ ] STREAM CONNECTED 16529 305/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 14070 361/php
unix 3 [ ] STREAM CONNECTED 13247 775/dbus-daemon @/tmp/dbus-2JlKMr4IvK
unix 3 [ ] STREAM CONNECTED 1923 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16503 812/python
unix 3 [ ] STREAM CONNECTED 12860 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16390 789/dbus-daemon
unix 3 [ ] STREAM CONNECTED 16391 789/dbus-daemon
unix 3 [ ] STREAM CONNECTED 14157 629/xbindkeys
unix 3 [ ] STREAM CONNECTED 9070 276/sh
unix 3 [ ] STREAM CONNECTED 1910 269/dbus-daemon
unix 3 [ ] STREAM CONNECTED 7824 1/init /run/systemd/journal/stdout
unix 2 [ ] DGRAM 1665 223/systemd-udevd
###### Network interfaces (ip addr) ######
1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: eth0: mtu 1500 qdisc fq_codel state UP group default qlen 4000
link/ether b8:27:eb:5f:78:21 brd ff:ff:ff:ff:ff:ff
inet 192.168.178.17/24 brd 192.168.178.255 scope global eth0
###### Network interfaces (ifconfig) ######
eth0: flags=4163 mtu 1500
inet 192.168.178.17 netmask 255.255.255.0 broadcast 192.168.178.255
ether b8:27:eb:5f:78:21 txqueuelen 4000 (Ethernet)
RX packets 10 bytes 1365 (1.3 KiB)
RX errors 0 dropped 5 overruns 0 frame 0
TX packets 26 bytes 5565 (5.4 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73 mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1 (Local Loopback)
RX packets 3596 bytes 168596 (164.6 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 3596 bytes 168596 (164.6 KiB)
###### Network netctl profiles (netctl list) ######
eth0
eth0 netctl status
● netctl@eth0.service - Networking for netctl profile eth0
Loaded: loaded (/usr/lib/systemd/system/netctl@.service; static; vendor preset: disabled)
Active: inactive (dead)
Docs: man:netctl.profile(5)
eth0 netctl profile
Description='eth0 connection'
Interface=eth0
ForceConnect=yes
SkipNoCarrier=yes
Connection=ethernet
IP=dhcp
###### Network wifi status (iwconfig) ######
lo no wireless extensions.
eth0 no wireless extensions.
###### List all USB devices (lsusb) ######
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
###### Kernel status (dmesg) ######
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.39-ARCH+ (frank@franks-ubuntu) (gcc version 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Linaro GCC 2013.11) ) #5 SMP Sat Feb 11 15:43:36 CET 2017
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 80ba3e80, node_mem_map b9fa6000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9460->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @b9f62000 s22656 r8192 d22400 u53248
[ 0.000000] pcpu-alloc: s22656 r8192 d22400 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa01041 bcm2709.serial=0x65f7821 smsc95xx.macaddr=B8:27:EB:5F:78:21 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rw rootwait rootfstype=ext4 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 elevator=noop ipv6.disable=1 logo.nologo quiet loglevel=3 rd.systemd.show_status=false rd.udev.log-priority=3
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 936072K/966656K available (8027K kernel code, 578K rwdata, 2900K rodata, 440K init, 797K bss, 22392K reserved, 8192K cma-reserved)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80ab3f68 (10928 kB)
.init : 0x80ab4000 - 0x80b22000 ( 440 kB)
.data : 0x80b22000 - 0x80bb2bd8 ( 579 kB)
.bss : 0x80bb5000 - 0x80c7c428 ( 798 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000020] Switching to timer-based delay loop, resolution 52ns
[ 0.000248] Console: colour dummy device 80x30
[ 0.000383] console [tty0] enabled
[ 0.000414] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000429] pid_max: default: 32768 minimum: 301
[ 0.000686] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000700] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001594] Disabling cpuset control group subsystem
[ 0.001627] Initializing cgroup subsys io
[ 0.001650] Initializing cgroup subsys memory
[ 0.001692] Initializing cgroup subsys devices
[ 0.001709] Initializing cgroup subsys freezer
[ 0.001726] Initializing cgroup subsys net_cls
[ 0.001739] Initializing cgroup subsys perf_event
[ 0.001753] Initializing cgroup subsys net_prio
[ 0.001779] Initializing cgroup subsys pids
[ 0.001834] CPU: Testing write buffer coherency: ok
[ 0.002371] CPU0: update cpu_capacity 1024
[ 0.002383] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.002391] [bcm2709_smp_prepare_cpus] enter
[ 0.002494] Setting up static identity map for 0x8240 - 0x8274
[ 0.004266] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.004588] [bcm2709_secondary_init] enter cpu:1
[ 0.004627] CPU1: update cpu_capacity 1024
[ 0.004632] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.005042] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.005276] [bcm2709_secondary_init] enter cpu:2
[ 0.005295] CPU2: update cpu_capacity 1024
[ 0.005300] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.005655] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.005876] [bcm2709_secondary_init] enter cpu:3
[ 0.005893] CPU3: update cpu_capacity 1024
[ 0.005898] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.005954] Brought up 4 CPUs
[ 0.005973] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.005979] CPU: All CPU(s) started in HYP mode.
[ 0.005984] CPU: Virtualization extensions available.
[ 0.006670] devtmpfs: initialized
[ 0.015224] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.015557] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.016120] xor: measuring software checksum speed
[ 0.109997] arm4regs : 1248.400 MB/sec
[ 0.210060] 8regs : 730.800 MB/sec
[ 0.310119] 32regs : 631.600 MB/sec
[ 0.410176] neon : 1214.000 MB/sec
[ 0.410185] xor: using function: arm4regs (1248.400 MB/sec)
[ 0.410306] pinctrl core: initialized pinctrl subsystem
[ 0.410864] NET: Registered protocol family 16
[ 0.415709] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.421144] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.421158] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.421292] Serial: AMBA PL011 UART driver
[ 0.421503] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.421920] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.650726] raid6: int32x1 gen() 134 MB/s
[ 0.820667] raid6: int32x1 xor() 108 MB/s
[ 0.990743] raid6: int32x2 gen() 175 MB/s
[ 1.160868] raid6: int32x2 xor() 115 MB/s
[ 1.330892] raid6: int32x4 gen() 179 MB/s
[ 1.500992] raid6: int32x4 xor() 116 MB/s
[ 1.671196] raid6: int32x8 gen() 168 MB/s
[ 1.841255] raid6: int32x8 xor() 108 MB/s
[ 2.011413] raid6: neonx1 gen() 441 MB/s
[ 2.181519] raid6: neonx1 xor() 321 MB/s
[ 2.351578] raid6: neonx2 gen() 578 MB/s
[ 2.521694] raid6: neonx2 xor() 416 MB/s
[ 2.691828] raid6: neonx4 gen() 721 MB/s
[ 2.861916] raid6: neonx4 xor() 480 MB/s
[ 3.032111] raid6: neonx8 gen() 476 MB/s
[ 3.202174] raid6: neonx8 xor() 342 MB/s
[ 3.202182] raid6: using algorithm neonx4 gen() 721 MB/s
[ 3.202188] raid6: .... xor() 480 MB/s, rmw enabled
[ 3.202194] raid6: using intx1 recovery algorithm
[ 3.203586] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 3.204064] SCSI subsystem initialized
[ 3.204324] usbcore: registered new interface driver usbfs
[ 3.204396] usbcore: registered new interface driver hub
[ 3.204518] usbcore: registered new device driver usb
[ 3.207003] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-12-09 15:11
[ 3.234275] clocksource: Switched to clocksource arch_sys_counter
[ 3.279338] FS-Cache: Loaded
[ 3.279595] CacheFiles: Loaded
[ 3.289311] NET: Registered protocol family 2
[ 3.290100] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 3.290205] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.290342] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.290442] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 3.290493] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 3.290741] NET: Registered protocol family 1
[ 3.291077] RPC: Registered named UNIX socket transport module.
[ 3.291088] RPC: Registered udp transport module.
[ 3.291094] RPC: Registered tcp transport module.
[ 3.291100] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.292162] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 3.294607] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 3.304841] VFS: Disk quotas dquot_6.6.0
[ 3.305069] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 3.306992] FS-Cache: Netfs 'nfs' registered for caching
[ 3.307691] NFS: Registering the id_resolver key type
[ 3.307756] Key type id_resolver registered
[ 3.307764] Key type id_legacy registered
[ 3.307790] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 3.308451] JFS: nTxBlock = 7377, nTxLock = 59016
[ 3.315716] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 3.322215] async_tx: api initialized (async)
[ 3.322479] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 3.322615] io scheduler noop registered (default)
[ 3.322632] io scheduler deadline registered
[ 3.322691] io scheduler cfq registered
[ 3.324591] BCM2708FB: allocated DMA memory fac00000
[ 3.324626] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 3.332042] Console: switching to colour frame buffer device 82x26
[ 3.336770] vc-cma: Videocore CMA driver
[ 3.336781] vc-cma: vc_cma_base = 0x00000000
[ 3.336788] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 3.336794] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 3.336953] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 3.350347] brd: module loaded
[ 3.357644] loop: module loaded
[ 3.358448] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ 3.359928] Loading iSCSI transport class v2.0-870.
[ 3.360585] usbcore: registered new interface driver ax88179_178a
[ 3.360665] usbcore: registered new interface driver smsc95xx
[ 3.360782] usbcore: registered new interface driver cdc_ncm
[ 3.360799] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 3.561035] Core Release: 2.80a
[ 3.561049] Setting default values for core params
[ 3.561085] Finished setting default values for core params
[ 3.761351] Using Buffer DMA mode
[ 3.761361] Periodic Transfer Interrupt Enhancement - disabled
[ 3.761367] Multiprocessor Interrupt Enhancement - disabled
[ 3.761374] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.761388] Dedicated Tx FIFOs mode
[ 3.761686] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 3.761714] FIQ FSM acceleration enabled for :
Periodic Split Transactions
[ 3.761742] dwc_otg: Microframe scheduler enabled
[ 3.761791] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x805d4318
[ 3.761801] WARN::hcd_init_fiq:414: FIQ ASM at 0x805d4660 length 36
[ 3.761812] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbbc7c000
[ 3.761862] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.761907] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.761943] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 3.761987] Init: Port Power? op_state=1
[ 3.761993] Init: Power Port (0)
[ 3.765259] md: linear personality registered for level -1
[ 3.765276] md: raid0 personality registered for level 0
[ 3.765290] md: raid1 personality registered for level 1
[ 3.765303] md: raid10 personality registered for level 10
[ 3.765542] md: raid6 personality registered for level 6
[ 3.765551] md: raid5 personality registered for level 5
[ 3.765557] md: raid4 personality registered for level 4
[ 3.765573] md: multipath personality registered for level -4
[ 3.765587] md: faulty personality registered for level -5
[ 3.765844] device-mapper: uevent: version 1.0.3
[ 3.766256] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.766768] device-mapper: multipath: version 1.10.0 loaded
[ 3.766787] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 3.766801] device-mapper: multipath queue-length: version 0.1.0 loaded
[ 3.766814] device-mapper: multipath service-time: version 0.2.0 loaded
[ 3.766844] device-mapper: raid: Loading target version 1.7.0
[ 3.767014] bcm2835-cpufreq: min=900000 max=900000
[ 3.767323] sdhci: Secure Digital Host Controller Interface driver
[ 3.767330] sdhci: Copyright(c) Pierre Ossman
[ 3.767597] sdhost: log_buf @ bac13000 (fac13000)
[ 3.824306] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.824499] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.824966] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.825149] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.825499] usbcore: registered new interface driver usbhid
[ 3.825507] usbhid: USB HID core driver
[ 3.825984] Initializing XFRM netlink socket
[ 3.826014] NET: Registered protocol family 17
[ 3.826148] Key type dns_resolver registered
[ 3.826735] Registering SWP/SWPB emulation handler
[ 3.827457] registered taskstats version 1
[ 3.830255] Btrfs loaded
[ 3.831421] Key type encrypted registered
[ 3.831517] vc-sm: Videocore shared memory driver
[ 3.831529] [vc_sm_connected_init]: start
[ 3.844808] [vc_sm_connected_init]: end - returning 0
[ 3.845006] of_cfs_init
[ 3.845096] of_cfs_init: OK
[ 3.845799] md: Waiting for all devices to be available before autodetect
[ 3.845810] md: If you don't use raid, use raid=noautodetect
[ 3.846795] md: Autodetecting RAID arrays.
[ 3.846807] md: Scanned 0 and added 0 devices.
[ 3.846813] md: autorun ...
[ 3.846818] md: ... autorun DONE.
[ 3.846994] Waiting for root device /dev/mmcblk0p2...
[ 3.925294] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.927865] mmc0: new high speed SDHC card at address aaaa
[ 3.928412] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ 3.930692] mmcblk0: p1 p2
[ 3.954377] Indeed it is in host mode hprt0 = 00021501
[ 3.969546] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.969594] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.977410] devtmpfs: mounted
[ 3.977899] Freeing unused kernel memory: 440K (80ab4000 - 80b22000)
[ 4.134330] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 4.134468] Indeed it is in host mode hprt0 = 00001101
[ 4.271031] systemd[1]: System time before build time, advancing clock.
[ 4.334575] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 4.334593] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.335279] hub 1-1:1.0: USB hub found
[ 4.335360] hub 1-1:1.0: 5 ports detected
[ 4.361842] IPv6: Loaded, but administratively disabled, reboot required to enable
[ 4.373853] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.378704] random: systemd: uninitialized urandom read (16 bytes read, 41 bits of entropy available)
[ 4.389500] random: systemd: uninitialized urandom read (16 bytes read, 43 bits of entropy available)
[ 4.392579] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 4.393118] systemd[1]: Detected architecture arm.
[ 4.394145] systemd[1]: Set hostname to .
[ 4.496895] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 57 bits of entropy available)
[ 4.497367] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 57 bits of entropy available)
[ 4.505453] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 58 bits of entropy available)
[ 4.581499] random: systemd: uninitialized urandom read (16 bytes read, 63 bits of entropy available)
[ 4.581800] random: systemd: uninitialized urandom read (16 bytes read, 63 bits of entropy available)
[ 4.582361] random: systemd: uninitialized urandom read (16 bytes read, 63 bits of entropy available)
[ 4.583281] random: systemd: uninitialized urandom read (16 bytes read, 63 bits of entropy available)
[ 4.604048] random: systemd: uninitialized urandom read (16 bytes read, 63 bits of entropy available)
[ 4.614333] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.714593] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 4.714613] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.717336] smsc95xx v1.0.4
[ 4.776985] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:5f:78:21
[ 4.891605] systemd[1]: Reached target Encrypted Volumes.
[ 4.891988] systemd[1]: Reached target Login Prompts.
[ 4.892259] systemd[1]: Listening on udev Control Socket.
[ 4.892418] systemd[1]: Listening on udev Kernel Socket.
[ 4.892610] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.892696] systemd[1]: Reached target System Time Synchronized.
[ 4.911617] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.912430] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.916770] systemd[1]: Listening on Process Core Dump Socket.
[ 4.917084] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.917181] systemd[1]: Reached target Remote File Systems.
[ 4.917441] systemd[1]: Listening on Journal Socket.
[ 4.919433] systemd[1]: Created slice System Slice.
[ 4.945023] systemd[1]: Starting Setup Virtual Console...
[ 4.960483] systemd[1]: Mounting Temporary Directory...
[ 4.970968] systemd[1]: Starting Load Kernel Modules...
[ 4.974702] systemd[1]: Starting Journal Service...
[ 4.979042] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 5.005301] systemd[1]: Created slice system-netctl\x2difplugd.slice.
[ 5.008686] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.068619] systemd[1]: Starting RuneAudio shutdown script...
[ 5.068822] systemd[1]: Reached target Slices.
[ 5.072122] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.076316] systemd[1]: Mounting Debug File System...
[ 5.076530] systemd[1]: Reached target Paths.
[ 5.077164] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 5.077625] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.077846] systemd[1]: Reached target Swap.
[ 5.091785] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.092157] systemd[1]: Mounted Temporary Directory.
[ 5.100232] systemd[1]: Mounted Debug File System.
[ 5.103209] systemd[1]: Started Load Kernel Modules.
[ 5.104787] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 5.106161] systemd[1]: Started Remount Root and Kernel File Systems.
[ 5.107438] systemd[1]: Started RuneAudio shutdown script.
[ 5.183230] systemd[1]: Started Journal Service.
[ 6.267138] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 6.268021] bcm2835-rng 3f104000.rng: hwrng registered
[ 6.317122] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 83) (baudrate 100000)
[ 6.325081] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 6.456530] snd-hifiberry-digi soc:sound: ASoC: CPU DAI (null) not registered
[ 6.456562] snd-hifiberry-digi soc:sound: snd_soc_register_card() failed: -517
[ 6.459885] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered
[ 6.459908] snd-hifiberry-digi soc:sound: snd_soc_register_card() failed: -517
[ 6.546326] wm8804 1-003b: revision E
[ 6.557957] snd-hifiberry-digi soc:sound: wm8804-spdif <-> 3f203000.i2s mapping ok
[ 7.526471] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 9.114581] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 10.988860] cfg80211: World regulatory domain updated:
[ 10.988889] cfg80211: DFS Master region: unset
[ 10.988897] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 10.988909] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 10.988918] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 10.988928] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 10.988939] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 10.988951] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 10.988961] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 10.988970] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 10.988980] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 13.697327] random: nonblocking pool is initialized
[ 18.619879] nf_conntrack version 0.5.0 (14761 buckets, 59044 max)
###### PHP backend ######
php version: 5.5.19
debug level: 0
