Ok, haven't given up yet. I reinstalled the latest beta version (0.4 Beta) on a fresh mUsd card. Again, it's a raspypi 3B, with a hifiberry Dac+ Pro. It installed ok, set it up with a wired ethernet connection so that wifi was connected, brought the unit upstairs to my studio, hooked it into my stereo, where it is now only connected via wifi - no direct ethernet. I've plugged in a usb flash drive with several albums on it, and configured a NAS with the Music folder on my mac as per another recent thread (and spent the hour or more it took lo set up the library). Everything connects fine, the UI loads on my wifi connected Macbook Pro (running the latest OS - Sierra OS X 10.12.3). I get the following behavior no matter which browser I try - I have safari, firefox waterfox and chrome installed. This bad behavior is the same stuff I was getting with the v0.3-beta (23/03/2016) version I had installed previously.
However, I'm getting the same bad behavior - once i start a track playing the system immediately locks up, locking me out form any further interaction. The track will finish playing, and the clock on the left of the UI will keep on running even though the track has ended, but nothing added to the playlist will play - in fact has't even been added to the playlist as the unit has already locked up. The only way to get back to any kind of control is to physically unplug and replug the power - the reboot/shutdown commands in the menu don't work.
Here's some log stuff - had to delete a bunch of it because it was too large, hope the right stuff is still here
Linux version 4.4.39-ARCH+ (frank@franks-ubuntu) (gcc version 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Linaro GCC 2013.11) ) #5 SMP Sat Feb 11 15:43:36 CET 2017
system time: Mon Mar 20 10:01:16 CDT 2017
system load: 0.08 0.06 0.04 1/183 1822
HW platform: RaspberryPi2 (08)
playerID: 08b26fff2ac4ddac6fee7fbbc1890504ae
###### Boot configuration ######
# Uncomment some or all of these to enable the optional hardware interfaces
# Params:
# i2c_arm Set to "on" to enable the ARM's i2c interface
# (default "off")
# i2c_vc Set to "on" to enable the i2c interface
# usually reserved for the VideoCore processor
# (default "off")
# i2c_arm_baudrate Set the baudrate of the ARM's i2c interface
# (default "100000")
# i2c_vc_baudrate Set the baudrate of the VideoCore i2c interface
# i2c_baudrate An alias for i2c_arm_baudrate
# i2s Set to "on" to enable the i2s interface
# (default "off")
# spi Set to "on" to enable the spi interfaces
# (default "off")
# act_led_trigger Choose which activity the LED tracks.
# Use "heartbeat" for a nice load indicator.
# (default "mmc")
# act_led_activelow Set to "on" to invert the sense of the LED
# (default "off")
# act_led_gpio Set which GPIO pin to use for the activity LED
# (in case you want to connect it to an external
# device)
# (default "16" on a non-Plus board, "47" on a
# Plus or Pi 2)
# N.B. It is recommended to only enable those interfaces that are needed.
# Leaving all interfaces enabled can lead to unwanted behaviour (i2c_vc
# interfering with Pi Camera, I2S and SPI hogging GPIO pins, etc.)
# Note also that i2c, i2c_arm and i2c_vc are aliases for the physical
# interfaces i2c0 and i2c1. Use of the numeric variants is still possible
# but deprecated because the ARM/VC assignments differ between board
# revisions. The same board-specific mapping applies to i2c_baudrate,
# and the other i2c baudrate parameters.
#dtparam=i2c_arm=on
#dtparam=i2c_vc=on
#dtparam=i2s=on
#dtparam=spi=on
#dtparam=act_led_trigger=mmc
#dtdebug=on
#dtparam=uart1=off
#dtoverlay=pi3-disable-bt-overlay
#dtoverlay=pi3-miniuart-bt-overlay
## RuneAudio HDMI & 3,5mm jack
dtparam=audio=on
## RuneAudio I2S-Settings
dtoverlay=hifiberry-dacplus
# Uncomment to enable the lirc-rpi module
# Params: gpio_out_pin GPIO pin for output (default "17")
# gpio_in_pin GPIO pin for input (default "18")
# gpio_in_pull Pull up/down/off on the input pin
# (default "down")
# sense Override the IR receive auto-detection logic:
# "1" = force active high
# "0" = force active low
# "-1" = use auto-detection
# (default "-1")
# softcarrier Turn the software carrier "on" or "off"
# (default "on")
# invert "on" = invert the output pin (default "off")
# debug "on" = enable additional debug messages
# (default "off")
#dtoverlay=lirc-rpi
#dtparam=gpio_out_pin=17
#dtparam=gpio_in_pin=18
#dtparam=gpio_in_pull=down
# LCD settings
# 180 degrees
#lcd_rotate=2
# Normal
lcd_rotate=0
#dtoverlay=rpi-backlight
#dtoverlay=rpi-ft5406
disable_splash=1
# Uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# Uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# Uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# Uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# Uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# Uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# Uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
# Uncomment to set monitor mode to DMT
#hdmi_group=2
# Uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# setting the max usb current to 1200mA
max_usb_current=1
# memory options
gpu_mem=64
# Overclocking options
force_turbo=1
RAM: 922.56MiB 339.50MiB 583.05MiB 28.13MiB
Swap: 0.00B 0.00B 0.00B
Bootup: Mon Mar 20 09:38:47 2017 Load average: 0.08 0.06 0.04 1/185 1824
user : 00:00:20.27 0.4% page in : 193119
nice : 00:01:11.84 1.3% page out: 3208
system: 00:00:34.71 0.6% page act: 12361
IOwait: 00:00:13.08 0.2% page dea: 0
hw irq: 00:00:00.00 0.0% page flt: 310601
sw irq: 00:00:00.49 0.0% swap in : 0
idle : 01:27:26.07 97.4% swap out: 0
uptime: 00:22:28.56 context : 494999
irq 16: 0 irq 51: 0
irq 17: 191317 irq 54: 0
irq 23: 23 irq 62: 381021
irq 24: 2 irq 79: 0
irq 39: 1 irq 80: 0
irq 46: 0 irq 83: 128
irq 48: 4725 irq 86: 312
irq 50: 0 irq 92: 28413
mmcblk0 4483r 2 mmcblk0p2 4378r
mmcblk0p1 63r sda 540r 1w
eth0 TX 0.00B RX 0.00B wlan0 TX 135.86KiB RX 358.73KiB
lo TX 1.18MiB RX 1.18MiB
systemd-+-at-spi-bus-laun-+-dbus-daemon
| |-{dconf worker}
| |-{gdbus}
| `-{gmain}
|-at-spi2-registr-+-{gdbus}
| `-{gmain}
|-avahi-daemon---avahi-daemon
|-cmd_async---sh---sudo---xinit-+-Xorg-+-{llvmpipe-0}
| | |-{llvmpipe-1}
| | |-{llvmpipe-2}
| | `-{llvmpipe-3}
| `-sh-+-matchbox-window
| `-midori-+-{dconf worker}
| |-{gdbus}
| |-{gmain}
| |-{llvmpipe-0}
| |-{llvmpipe-1}
| |-{llvmpipe-2}
| |-{llvmpipe-3}
| |-2*[{midori}]
| `-{pool}
|-2*[dbus-daemon]
|-dbus-launch
|-devmon---udevil
|-dhcpcd
|-haveged
|-ifplugd
|-mpd-+-{decoder}
| |-{io}
| |-{output:snd_rpi_}
| `-{player}
|-nginx---nginx
|-nmbd
|-ntpd---{ntpd}
|-php-fpm---3*[php-fpm]
|-python
|-rune_PL_wrk
|-rune_SY_wrk---sh---debug_collector---sh---pstree
|-sh---sleep
|-shairport---{shairport}
|-sshd
|-systemd-journal
|-systemd-udevd
|-wpa_actiond
|-wpa_supplicant
`-xbindkeys
Advanced Linux Sound Architecture Driver Version k4.4.39-ARCH+.
0 [ALSA ]: bcm2835 - bcm2835 ALSA
bcm2835 ALSA
1 [sndrpihifiberry]: snd_rpi_hifiber - snd_rpi_hifiberry_dacplus
PLAYBACK devices: (aplay -l)
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 1: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0 []
Subdevices: 1/1
PCM devices: (aplay -L)
null
default:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
sysdefault:CARD=ALSA
default:CARD=sndrpihifiberry
snd_rpi_hifiberry_dacplus,
sysdefault:CARD=sndrpihifiberry
card 0:
Simple mixer control 'PCM',0
card 1:
Simple mixer control 'DSP Program',0
Simple mixer control 'Analogue',0
Simple mixer control 'Analogue Playback Boost',0
Simple mixer control 'Auto Mute',0
Simple mixer control 'Auto Mute Mono',0
Simple mixer control 'Auto Mute Time Left',0
Simple mixer control 'Auto Mute Time Right',0
Simple mixer control 'Clock Missing Period',0
Simple mixer control 'Deemphasis',0
Simple mixer control 'Digital',0
Simple mixer control 'Max Overclock DAC',0
Simple mixer control 'Max Overclock DSP',0
Simple mixer control 'Max Overclock PLL',0
Simple mixer control 'Volume Ramp Down Emergency Rate',0
Simple mixer control 'Volume Ramp Down Emergency Step',0
Simple mixer control 'Volume Ramp Down Rate',0
Simple mixer control 'Volume Ramp Down Step',0
Simple mixer control 'Volume Ramp Up Rate',0
Simple mixer control 'Volume Ramp Up Step',0
card 0:
numid=3,iface=MIXER,name='PCM Playback Route'
numid=1,iface=MIXER,name='PCM Playback Volume'
numid=5,iface=PCM,name='IEC958 Playback Con Mask'
numid=4,iface=PCM,name='IEC958 Playback Default'
card 1:
numid=6,iface=MIXER,name='DSP Program'
numid=3,iface=MIXER,name='Analogue Playback Boost Volume'
numid=2,iface=MIXER,name='Analogue Playback Volume'
numid=10,iface=MIXER,name='Auto Mute Mono Switch'
numid=11,iface=MIXER,name='Auto Mute Switch'
numid=8,iface=MIXER,name='Auto Mute Time Left'
numid=9,iface=MIXER,name='Auto Mute Time Right'
numid=7,iface=MIXER,name='Clock Missing Period'
numid=5,iface=MIXER,name='Deemphasis Switch'
numid=4,iface=MIXER,name='Digital Playback Switch'
numid=1,iface=MIXER,name='Digital Playback Volume'
numid=20,iface=MIXER,name='Max Overclock DAC'
numid=19,iface=MIXER,name='Max Overclock DSP'
numid=18,iface=MIXER,name='Max Overclock PLL'
numid=16,iface=MIXER,name='Volume Ramp Down Emergency Rate'
numid=17,iface=MIXER,name='Volume Ramp Down Emergency Step'
numid=12,iface=MIXER,name='Volume Ramp Down Rate'
numid=13,iface=MIXER,name='Volume Ramp Down Step'
numid=14,iface=MIXER,name='Volume Ramp Up Rate'
numid=15,iface=MIXER,name='Volume Ramp Up Step'
Output 1 (snd_rpi_hifiberry_dacplus) is enabled
Output 2 (bcm2835 ALSA_1) is disabled
Output 3 (bcm2835 ALSA_2) is disabled
MPD statistics: (mpc stats)
Artists: 6
Albums: 10
Songs: 157
Play Time: 0 days, 0:00:00
Uptime: 0 days, 0:22:15
DB Updated: Mon Mar 20 09:20:01 2017
DB Play Time: 0 days, 20:07:36
###### mpd version ######
Music Player Daemon 0.19.19-dsd
Copyright (C) 2003-2007 Warren Dukes
Copyright (C) 2008-2014 Max Kellermann
This is free software; see the source for copying conditions. There is NO
warranty; not even MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Database plugins:
simple proxy upnp
Storage plugins:
local smbclient nfs
Neighbor plugins:
smbclient upnp
Decoders plugins:
[mad] mp3 mp2
[vorbis] ogg oga
[oggflac] ogg oga
[flac] flac
[sndfile] wav aiff aif au snd paf iff svx sf voc w64 pvf xi htk caf sd2
[audiofile] wav au aiff aif
[dsdiff] dff
[dsf] dsf
[faad] aac
[ffmpeg] 16sv 3g2 3gp 4xm 8svx aa3 aac ac3 afc aif aifc aiff al alaw amr anim apc ape asf atrac au aud avi avm2 avs bap bfi c93 cak cin cmv cpk daud dct divx dts dv dvd dxa eac3 film flac flc fli fll flx flv g726 gsm gxf iss m1v m2v m2t m2ts m4a m4b m4v mad mj2 mjpeg mjpg mka mkv mlp mm mmf mov mp+ mp1 mp2 mp3 mp4 mpc mpeg mpg mpga mpp mpu mve mvi mxf nc nsv nut nuv oga ogm ogv ogx oma ogg omg opus psp pva qcp qt r3d ra ram rl2 rm rmvb roq rpl rvc shn smk snd sol son spx str swf tak tgi tgq tgv thp ts tsp tta xa xvid uv uv2 vb vid vob voc vp6 vmd wav webm wma wmv wsaud wsvga wv wve
[pcm]
Output plugins:
null fifo pipe alsa jack httpd
Encoder plugins:
null vorbis wave flac
Input plugins:
file alsa curl ffmpeg smbclient nfs mms
Playlist plugins:
extm3u m3u pls xspf asx rss soundcloud cue embcue
Protocols:
file:// http:// https:// mms:// mmsh:// mmst:// mmsu:// gopher:// rtp:// rtsp:// rtmp:// rtmpt:// rtmps:// smb:// nfs:// alsa://
log_level "default"
zeroconf_name "runeaudio"
auto_update "no"
audio_buffer_size "4096"
buffer_before_play "20%"
mixer_type "disabled"
replaygain "off"
name "snd_rpi_hifiberry_dacplus"
device "hw:1,0"
name "bcm2835 ALSA_1"
name "bcm2835 ALSA_2"
hardware platform: RaspberryPi2
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 4500000
/proc/sys/kernel/sched_rr_timeslice_ms: 10
total 8.0K
drwxr-xr-x 2 root root 4.0K Mar 20 00:32 .
drwxr-xr-x 6 root root 4.0K Dec 15 13:47 ..
lrwxrwxrwx 1 root root 44 Jan 29 06:51 amixer-webui.service -> /usr/lib/systemd/system/amixer-webui.service
lrwxrwxrwx 1 root root 44 Feb 14 2015 avahi-daemon.service -> /usr/lib/systemd/system/avahi-daemon.service
lrwxrwxrwx 1 root root 44 Mar 20 00:32 netctl-auto@wlan0.service -> /usr/lib/systemd/system/netctl-auto@.service
lrwxrwxrwx 1 root root 47 Oct 19 11:38 netctl-ifplugd@eth0.service -> /usr/lib/systemd/system/netctl-ifplugd@.service
lrwxrwxrwx 1 root root 36 Feb 14 2015 ntpd.service -> /usr/lib/systemd/system/ntpd.service
devtmpfs /dev devtmpfs rw,relatime,size=468032k,nr_inodes=117008,mode=755 0 0
cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=31,pgrp=1,timeout=0,minproto=5,maxproto=5,direct 0 0
tmpfs /tmp tmpfs rw 0 0
/dev/sda1 /mnt/MPD/USB/GGG vfat rw,nosuid,nodev,noexec,noatime,uid=1000,gid=92,fmask=0022,dmask=0022,codepage=437,iocharset=utf8,shortname=mixed,errors=remount-ro 0 0
//192.168.1.84/Music /mnt/MPD/NAS/Steves\040Computer cifs ro,relatime,vers=1.0,sec=ntlmssp,cache=none,username=stephendrake,domain=MACBOOK-PRO,uid=1000,forceuid,gid=92,forcegid,addr=192.168.1.84,file_mode=0755,dir_mode=0755,nounix,mapposix,rsize=16384,wsize=17408,actimeo=1 0 0
/dev/root 1.9G 1.7G 100M 95% /
devtmpfs 458M 0 458M 0% /dev
tmpfs 462M 0 462M 0% /dev/shm
tmpfs 462M 12M 450M 3% /run
tmpfs 462M 0 462M 0% /sys/fs/cgroup
tmpfs 462M 4.0K 462M 1% /tmp
logs 5.0M 20K 5.0M 1% /var/log
rune-logs 5.0M 48K 5.0M 1% /var/log/runeaudio
/dev/mmcblk0p1 100M 19M 81M 19% /boot
/dev/sda1 15G 4.8G 9.8G 33% /mnt/MPD/USB/GGG
//192.168.1.84/Music 848G 685G 163G 81% /mnt/MPD/NAS/Steves Computer
###### Loaded kernel modules ######
Module Size Used by
arc4 1936 0
md4 3599 0
nls_utf8 1419 2
cifs 392255 2
brcmfmac 184455 0
brcmutil 8379 1 brcmfmac
cfg80211 498228 1 brcmfmac
snd_soc_pcm512x_i2c 2609 1
snd_soc_hifiberry_dacplus 4587 0
snd_soc_pcm512x 18826 1 snd_soc_pcm512x_i2c
snd_soc_bcm2835_i2s 6278 2
snd_soc_hifiberry_dac 2887 0
snd_soc_core 153224 4 snd_soc_pcm512x,snd_soc_bcm2835_i2s,snd_soc_hifiberry_dac,snd_soc_hifiberry_dacplus
snd_bcm2835 21181 0
regmap_i2c 3560 1 snd_soc_pcm512x_i2c
snd_pcm_dmaengine 5503 1 snd_soc_core
snd_pcm 88980 6 snd_bcm2835,snd_soc_pcm512x,snd_soc_core,snd_soc_hifiberry_dac,snd_pcm_dmaengine,snd_soc_hifiberry_dacplus
snd_timer 22172 1 snd_pcm
snd 63333 4 snd_bcm2835,snd_soc_core,snd_timer,snd_pcm
bcm2835_rng 2167 0
i2c_bcm2708 5382 0
rng_core 8183 1 bcm2835_rng
bcm2835_gpiomem 3638 0
bcm2835_wdt 3756 0
clk_hifiberry_dacpro 2557 1
uio_pdrv_genirq 3539 0
uio 9114 1 uio_pdrv_genirq
sch_fq_codel 8174 3
ip_tables 12147 0
x_tables 18169 1 ip_tables
ipv6 372060 0
tcp 0 0 0.0.0.0:6600 0.0.0.0:* LISTEN 492/mpd
tcp 0 0 0.0.0.0:5002 0.0.0.0:* LISTEN 502/shairport
tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 356/redis-server 12
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 306/python
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 371/nginx: master p
tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 371/nginx: master p
tcp 0 0 0.0.0.0:82 0.0.0.0:* LISTEN 371/nginx: master p
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 342/sshd
udp 0 0 0.0.0.0:45591 0.0.0.0:* 304/avahi-daemon: r
udp 0 0 0.0.0.0:68 0.0.0.0:* 642/dhcpcd
udp 0 0 192.168.1.149:123 0.0.0.0:* 360/ntpd
udp 0 0 127.0.0.1:123 0.0.0.0:* 360/ntpd
udp 0 0 0.0.0.0:123 0.0.0.0:* 360/ntpd
udp 0 0 192.168.1.255:137 0.0.0.0:* 446/nmbd
udp 0 0 192.168.1.149:137 0.0.0.0:* 446/nmbd
udp 0 0 0.0.0.0:137 0.0.0.0:* 446/nmbd
udp 0 0 192.168.1.255:138 0.0.0.0:* 446/nmbd
udp 0 0 192.168.1.149:138 0.0.0.0:* 446/nmbd
udp 0 0 0.0.0.0:138 0.0.0.0:* 446/nmbd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 304/avahi-daemon: r
unix 2 [ ACC ] STREAM LISTENING 13822 553/php-fpm: master /var/run/php-command.sock
unix 2 [ ACC ] STREAM LISTENING 12035 601/Xorg /tmp/.X11-unix/X0
unix 2 [ ACC ] STREAM LISTENING 12034 601/Xorg @/tmp/.X11-unix/X0
unix 2 [ ACC ] STREAM LISTENING 12354 356/redis-server 12 /tmp/redis.sock
unix 2 [ ACC ] STREAM LISTENING 15333 958/dbus-daemon @/tmp/dbus-K74f1Zzlwv
unix 2 [ ACC ] STREAM LISTENING 1698 1/init /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 1701 1/init /run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 1704 1/init /var/run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 14002 446/nmbd /var/run/samba/nmbd/unexpected
unix 2 [ ACC ] STREAM LISTENING 12765 492/mpd /run/mpd.sock
unix 2 [ ACC ] STREAM LISTENING 8417 1/init /run/systemd/private
unix 2 [ ACC ] STREAM LISTENING 13256 965/dbus-daemon @/tmp/dbus-IjPNHxzATX
unix 2 [ ACC ] SEQPACKET LISTENING 8424 1/init /run/systemd/coredump
unix 2 [ ACC ] SEQPACKET LISTENING 8427 1/init /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 13816 553/php-fpm: master /var/run/php-display.sock
unix 2 [ ACC ] STREAM LISTENING 13819 553/php-fpm: master /var/run/php-db.sock
unix 2 [ ACC ] STREAM LISTENING 8446 1/init /run/systemd/journal/stdout
###### Network established sockets (netstat -np) ######
Active Internet connections (w/o servers)
tcp 0 0 127.0.0.1:38596 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:38660 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:38602 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:38612 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:6379 127.0.0.1:38744 ESTABLISHED 356/redis-server 12
tcp 0 0 127.0.0.1:38674 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:38542 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:38730 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:38606 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:38684 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:39738 127.0.0.1:6600 TIME_WAIT -
(some stuff deleted here because I had too many characters)
###### Kernel status (dmesg) ######
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.39-ARCH+ (frank@franks-ubuntu) (gcc version 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Linaro GCC 2013.11) ) #5 SMP Sat Feb 11 15:43:36 CET 2017
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 80ba3e80, node_mem_map b9fa6000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9460->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @b9f61000 s22656 r8192 d22400 u53248
[ 0.000000] pcpu-alloc: s22656 r8192 d22400 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0x50ae8a1d smsc95xx.macaddr=B8:27:EB:AE:8A:1D bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rw rootwait rootfstype=ext4 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 elevator=noop ipv6.disable=1 logo.nologo quiet loglevel=3 rd.systemd.show_status=false rd.udev.log-priority=3
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 936068K/966656K available (8027K kernel code, 578K rwdata, 2900K rodata, 440K init, 797K bss, 22396K reserved, 8192K cma-reserved)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80ab3f68 (10928 kB)
.init : 0x80ab4000 - 0x80b22000 ( 440 kB)
.data : 0x80b22000 - 0x80bb2bd8 ( 579 kB)
.bss : 0x80bb5000 - 0x80c7c428 ( 798 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000014] Switching to timer-based delay loop, resolution 52ns
[ 0.000150] Console: colour dummy device 80x30
[ 0.000238] console [tty0] enabled
[ 0.000255] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000264] pid_max: default: 32768 minimum: 301
[ 0.000416] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000422] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000912] Disabling cpuset control group subsystem
[ 0.000931] Initializing cgroup subsys io
[ 0.000945] Initializing cgroup subsys memory
[ 0.000968] Initializing cgroup subsys devices
[ 0.000976] Initializing cgroup subsys freezer
[ 0.000986] Initializing cgroup subsys net_cls
[ 0.000994] Initializing cgroup subsys perf_event
[ 0.001001] Initializing cgroup subsys net_prio
[ 0.001015] Initializing cgroup subsys pids
[ 0.001037] CPU: Testing write buffer coherency: ok
[ 0.001330] CPU0: update cpu_capacity 1024
[ 0.001335] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001341] [bcm2709_smp_prepare_cpus] enter
[ 0.001413] Setting up static identity map for 0x8240 - 0x8274
[ 0.002284] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.002497] [bcm2709_secondary_init] enter cpu:1
[ 0.002522] CPU1: update cpu_capacity 1024
[ 0.002525] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.002730] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.002867] [bcm2709_secondary_init] enter cpu:2
[ 0.002877] CPU2: update cpu_capacity 1024
[ 0.002880] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.003056] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.003182] [bcm2709_secondary_init] enter cpu:3
[ 0.003192] CPU3: update cpu_capacity 1024
[ 0.003195] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.003224] Brought up 4 CPUs
[ 0.003235] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.003239] CPU: All CPU(s) started in HYP mode.
[ 0.003242] CPU: Virtualization extensions available.
[ 0.003598] devtmpfs: initialized
[ 0.008921] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.009095] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.009383] xor: measuring software checksum speed
[ 0.099967] arm4regs : 2046.800 MB/sec
[ 0.199998] 8regs : 1198.800 MB/sec
[ 0.300033] 32regs : 1032.400 MB/sec
[ 0.400064] neon : 2092.400 MB/sec
[ 0.400069] xor: using function: neon (2092.400 MB/sec)
[ 0.400137] pinctrl core: initialized pinctrl subsystem
[ 0.400425] NET: Registered protocol family 16
[ 0.403611] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.407074] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.407079] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.407154] Serial: AMBA PL011 UART driver
[ 0.407222] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.407302] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.620274] raid6: int32x1 gen() 182 MB/s
[ 0.790322] raid6: int32x1 xor() 168 MB/s
[ 0.960425] raid6: int32x2 gen() 279 MB/s
[ 1.130470] raid6: int32x2 xor() 214 MB/s
[ 1.300584] raid6: int32x4 gen() 301 MB/s
[ 1.470722] raid6: int32x4 xor() 225 MB/s
[ 1.640776] raid6: int32x8 gen() 303 MB/s
[ 1.810847] raid6: int32x8 xor() 206 MB/s
[ 1.980910] raid6: neonx1 gen() 751 MB/s
[ 2.151017] raid6: neonx1 xor() 724 MB/s
[ 2.321104] raid6: neonx2 gen() 1081 MB/s
[ 2.491180] raid6: neonx2 xor() 956 MB/s
[ 2.661246] raid6: neonx4 gen() 1463 MB/s
[ 2.831331] raid6: neonx4 xor() 1105 MB/s
[ 3.001410] raid6: neonx8 gen() 1019 MB/s
[ 3.171495] raid6: neonx8 xor() 840 MB/s
[ 3.171499] raid6: using algorithm neonx4 gen() 1463 MB/s
[ 3.171503] raid6: .... xor() 1105 MB/s, rmw enabled
[ 3.171507] raid6: using intx1 recovery algorithm
[ 3.172290] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 3.172562] SCSI subsystem initialized
[ 3.172710] usbcore: registered new interface driver usbfs
[ 3.172746] usbcore: registered new interface driver hub
[ 3.172809] usbcore: registered new device driver usb
[ 3.181519] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-12-09 15:11
[ 3.208077] clocksource: Switched to clocksource arch_sys_counter
[ 3.236093] FS-Cache: Loaded
[ 3.236236] CacheFiles: Loaded
[ 3.241718] NET: Registered protocol family 2
[ 3.242143] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 3.242200] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.242295] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.242351] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 3.242374] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 3.242489] NET: Registered protocol family 1
[ 3.242655] RPC: Registered named UNIX socket transport module.
[ 3.242659] RPC: Registered udp transport module.
[ 3.242663] RPC: Registered tcp transport module.
[ 3.242667] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.243347] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 3.244644] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 3.250979] VFS: Disk quotas dquot_6.6.0
[ 3.251113] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 3.252333] FS-Cache: Netfs 'nfs' registered for caching
[ 3.252719] NFS: Registering the id_resolver key type
[ 3.252750] Key type id_resolver registered
[ 3.252755] Key type id_legacy registered
[ 3.252770] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 3.253168] JFS: nTxBlock = 7377, nTxLock = 59016
[ 3.257710] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 3.261578] async_tx: api initialized (async)
[ 3.261726] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 3.261792] io scheduler noop registered (default)
[ 3.261801] io scheduler deadline registered
[ 3.261827] io scheduler cfq registered
[ 3.263069] BCM2708FB: allocated DMA memory fac10000
[ 3.263083] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 3.268338] Console: switching to colour frame buffer device 82x26
[ 3.271273] vc-cma: Videocore CMA driver
[ 3.271278] vc-cma: vc_cma_base = 0x00000000
[ 3.271282] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 3.271286] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 3.271372] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 3.278297] brd: module loaded
[ 3.282431] loop: module loaded
[ 3.282925] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ 3.283907] Loading iSCSI transport class v2.0-870.
[ 3.284270] usbcore: registered new interface driver ax88179_178a
[ 3.284317] usbcore: registered new interface driver smsc95xx
[ 3.284379] usbcore: registered new interface driver cdc_ncm
[ 3.284389] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 3.484525] Core Release: 2.80a
[ 3.484531] Setting default values for core params
[ 3.484550] Finished setting default values for core params
[ 3.684716] Using Buffer DMA mode
[ 3.684721] Periodic Transfer Interrupt Enhancement - disabled
[ 3.684724] Multiprocessor Interrupt Enhancement - disabled
[ 3.684728] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.684752] Dedicated Tx FIFOs mode
[ 3.684936] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac04000 dma = 0xfac04000 len=9024
[ 3.684951] FIQ FSM acceleration enabled for :
Periodic Split Transactions
[ 3.684960] dwc_otg: Microframe scheduler enabled
[ 3.684981] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x805d4318
[ 3.684987] WARN::hcd_init_fiq:414: FIQ ASM at 0x805d4660 length 36
[ 3.684993] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbbc7c000
[ 3.685023] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.685041] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.685060] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 3.685095] Init: Port Power? op_state=1
[ 3.685099] Init: Power Port (0)
[ 3.685199] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.685206] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.685212] usb usb1: Product: DWC OTG Controller
[ 3.685217] usb usb1: Manufacturer: Linux 4.4.39-ARCH+ dwc_otg_hcd
[ 3.685222] usb usb1: SerialNumber: 3f980000.usb
[ 3.685594] hub 1-0:1.0: USB hub found
[ 3.685613] hub 1-0:1.0: 1 port detected
[ 3.685913] dwc_otg: FIQ enabled
[ 3.685917] dwc_otg: NAK holdoff enabled
[ 3.685921] dwc_otg: FIQ split-transaction FSM enabled
[ 3.685938] Module dwc_common_port init
[ 3.686052] usbcore: registered new interface driver usb-storage
[ 3.686086] usbcore: registered new interface driver ums-alauda
[ 3.686115] usbcore: registered new interface driver ums-cypress
[ 3.686144] usbcore: registered new interface driver ums-datafab
[ 3.686173] usbcore: registered new interface driver ums_eneub6250
[ 3.686202] usbcore: registered new interface driver ums-freecom
[ 3.686235] usbcore: registered new interface driver ums-isd200
[ 3.686267] usbcore: registered new interface driver ums-jumpshot
[ 3.686297] usbcore: registered new interface driver ums-karma
[ 3.686327] usbcore: registered new interface driver ums-onetouch
[ 3.686368] usbcore: registered new interface driver ums-realtek
[ 3.686398] usbcore: registered new interface driver ums-sddr09
[ 3.686428] usbcore: registered new interface driver ums-sddr55
[ 3.686457] usbcore: registered new interface driver ums-usbat
[ 3.686585] mousedev: PS/2 mouse device common for all mice
[ 3.686944] md: linear personality registered for level -1
[ 3.686953] md: raid0 personality registered for level 0
[ 3.686961] md: raid1 personality registered for level 1
[ 3.686968] md: raid10 personality registered for level 10
[ 3.687082] md: raid6 personality registered for level 6
[ 3.687087] md: raid5 personality registered for level 5
[ 3.687091] md: raid4 personality registered for level 4
[ 3.687100] md: multipath personality registered for level -4
[ 3.687108] md: faulty personality registered for level -5
[ 3.687276] device-mapper: uevent: version 1.0.3
[ 3.687497] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.687774] device-mapper: multipath: version 1.10.0 loaded
[ 3.687785] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 3.687793] device-mapper: multipath queue-length: version 0.1.0 loaded
[ 3.687801] device-mapper: multipath service-time: version 0.2.0 loaded
[ 3.687820] device-mapper: raid: Loading target version 1.7.0
[ 3.687918] bcm2835-cpufreq: min=1200000 max=1200000
[ 3.688152] sdhci: Secure Digital Host Controller Interface driver
[ 3.688156] sdhci: Copyright(c) Pierre Ossman
[ 3.688327] sdhost: log_buf @ bac07000 (fac07000)
[ 3.748092] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.750134] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 3.750140] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 3.788137] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.788344] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.788420] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.788621] usbcore: registered new interface driver usbhid
[ 3.788625] usbhid: USB HID core driver
[ 3.788895] Initializing XFRM netlink socket
[ 3.788912] NET: Registered protocol family 17
[ 3.788987] Key type dns_resolver registered
[ 3.789386] Registering SWP/SWPB emulation handler
[ 3.789759] registered taskstats version 1
[ 3.791406] Btrfs loaded
[ 3.791975] Key type encrypted registered
[ 3.792022] vc-sm: Videocore shared memory driver
[ 3.792028] [vc_sm_connected_init]: start
[ 3.792301] [vc_sm_connected_init]: end - returning 0
[ 3.793399] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 3.793573] of_cfs_init
[ 3.793616] of_cfs_init: OK
[ 3.793983] md: Waiting for all devices to be available before autodetect
[ 3.793988] md: If you don't use raid, use raid=noautodetect
[ 3.794507] md: Autodetecting RAID arrays.
[ 3.794512] md: Scanned 0 and added 0 devices.
[ 3.794515] md: autorun ...
[ 3.794518] md: ... autorun DONE.
[ 3.794593] Waiting for root device /dev/mmcblk0p2...
[ 3.847453] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.850706] mmc0: new high speed SDHC card at address aaaa
[ 3.850982] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
[ 3.852238] mmcblk0: p1 p2
[ 3.869148] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.870636] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.872124] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.874796] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.878136] Indeed it is in host mode hprt0 = 00021501
[ 3.960485] mmc1: new high speed SDIO card at address 0001
[ 4.058095] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 4.058173] Indeed it is in host mode hprt0 = 00001101
[ 4.258220] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 4.258227] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.258632] hub 1-1:1.0: USB hub found
[ 4.258675] hub 1-1:1.0: 5 ports detected
[ 4.340224] EXT4-fs (mmcblk0p2): recovery complete
[ 4.344988] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.345016] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 4.345845] devtmpfs: mounted
[ 4.346171] Freeing unused kernel memory: 440K (80ab4000 - 80b22000)
[ 4.538102] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.638230] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 4.638243] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.640699] smsc95xx v1.0.4
[ 4.663306] systemd[1]: System time before build time, advancing clock.
[ 4.699646] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:ae:8a:1d
[ 4.759302] IPv6: Loaded, but administratively disabled, reboot required to enable
[ 4.768329] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.772232] random: systemd: uninitialized urandom read (16 bytes read, 76 bits of entropy available)
[ 4.782745] random: systemd: uninitialized urandom read (16 bytes read, 76 bits of entropy available)
[ 4.784364] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 4.784651] systemd[1]: Detected architecture arm.
[ 4.785559] systemd[1]: Set hostname to .
[ 4.871704] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 77 bits of entropy available)
[ 4.873590] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 77 bits of entropy available)
[ 4.873712] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 77 bits of entropy available)
[ 4.962108] random: systemd: uninitialized urandom read (16 bytes read, 78 bits of entropy available)
[ 4.962274] random: systemd: uninitialized urandom read (16 bytes read, 78 bits of entropy available)
[ 4.962563] random: systemd: uninitialized urandom read (16 bytes read, 78 bits of entropy available)
[ 4.963096] random: systemd: uninitialized urandom read (16 bytes read, 78 bits of entropy available)
[ 4.982334] random: systemd: uninitialized urandom read (16 bytes read, 78 bits of entropy available)
[ 5.278380] systemd[1]: Listening on Process Core Dump Socket.
[ 5.278520] systemd[1]: Reached target Remote File Systems.
[ 5.278566] systemd[1]: Reached target System Time Synchronized.
[ 5.278686] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.278813] systemd[1]: Listening on udev Control Socket.
[ 5.278918] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 5.279016] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.279139] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 5.279192] systemd[1]: Reached target Paths.
[ 5.279234] systemd[1]: Reached target Swap.
[ 5.279277] systemd[1]: Reached target Login Prompts.
[ 5.279377] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.279745] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.279844] systemd[1]: Listening on udev Kernel Socket.
[ 5.279891] systemd[1]: Reached target Encrypted Volumes.
[ 5.280008] systemd[1]: Listening on Journal Socket.
[ 5.298680] systemd[1]: Created slice System Slice.
[ 5.358260] systemd[1]: Mounting Temporary Directory...
[ 5.359918] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.361841] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.363720] systemd[1]: Starting Journal Service...
[ 5.428486] systemd[1]: Starting RuneAudio shutdown script...
[ 5.430134] systemd[1]: Mounting Debug File System...
[ 5.459722] systemd[1]: Starting Load Kernel Modules...
[ 5.460340] systemd[1]: Created slice system-netctl\x2difplugd.slice.
[ 5.460524] usb 1-1.5: new high-speed USB device number 4 using dwc_otg
[ 5.473126] systemd[1]: Created slice system-netctl\x2dauto.slice.
[ 5.474843] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 5.475016] systemd[1]: Reached target Slices.
[ 5.477341] systemd[1]: Starting Setup Virtual Console...
[ 5.484738] systemd[1]: Started Remount Root and Kernel File Systems.
[ 5.485729] systemd[1]: Started RuneAudio shutdown script.
[ 5.486725] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 5.487787] systemd[1]: Started Load Kernel Modules.
[ 5.505071] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.505272] systemd[1]: Mounted Debug File System.
[ 5.505355] systemd[1]: Mounted Temporary Directory.
[ 5.549356] systemd[1]: Started Journal Service.
[ 5.558962] usb 1-1.5: New USB device found, idVendor=0951, idProduct=1666
[ 5.558976] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.558982] usb 1-1.5: Product: DataTraveler 3.0
[ 5.558988] usb 1-1.5: Manufacturer: Kingston
[ 5.558994] usb 1-1.5: SerialNumber: 60A44C3FAC2DAF70A0001274
[ 5.559530] usb-storage 1-1.5:1.0: USB Mass Storage device detected
[ 5.559877] scsi host0: usb-storage 1-1.5:1.0
[ 6.195499] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 6.211944] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 6.228595] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 83) (baudrate 100000)
[ 6.241026] bcm2835-rng 3f104000.rng: hwrng registered
[ 6.408781] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered
[ 6.408794] snd-rpi-hifiberry-dacplus soc:sound: snd_soc_register_card() failed: -517
[ 6.485335] snd-rpi-hifiberry-dacplus soc:sound: pcm512x-hifi <-> 3f203000.i2s mapping ok
[ 6.558903] scsi 0:0:0:0: Direct-Access KINGSTON DataTraveler 3.0 1.01 PQ: 0 ANSI: 6
[ 6.559900] sd 0:0:0:0: [sda] 30375936 512-byte logical blocks: (15.6 GB/14.5 GiB)
[ 6.561675] sd 0:0:0:0: [sda] Write Protect is off
[ 6.561694] sd 0:0:0:0: [sda] Mode Sense: 2b 00 10 08
[ 6.561879] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, supports DPO and FUA
[ 6.563675] sda: sda1
[ 6.564736] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 6.574055] usbcore: registered new interface driver brcmfmac
[ 6.583037] random: nonblocking pool is initialized
[ 6.641467] cfg80211: World regulatory domain updated:
[ 6.641484] cfg80211: DFS Master region: unset
[ 6.641488] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 6.641496] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.641502] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.641508] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.641515] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.641522] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 6.641528] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 6.641533] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.641539] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 6.671048] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
[ 6.689760] cfg80211: Updating information on frequency 2412 MHz with regulatory rule:
[ 6.689773] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.689779] cfg80211: Updating information on frequency 2417 MHz with regulatory rule:
[ 6.689785] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.689790] cfg80211: Updating information on frequency 2422 MHz with regulatory rule:
[ 6.689795] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.689800] cfg80211: Updating information on frequency 2427 MHz with regulatory rule:
[ 6.689805] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.689809] cfg80211: Updating information on frequency 2432 MHz with regulatory rule:
[ 6.689814] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.689819] cfg80211: Updating information on frequency 2437 MHz with regulatory rule:
[ 6.689824] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.689829] cfg80211: Updating information on frequency 2442 MHz with regulatory rule:
[ 6.689834] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.689839] cfg80211: Updating information on frequency 2447 MHz with regulatory rule:
[ 6.689844] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.689848] cfg80211: Updating information on frequency 2452 MHz with regulatory rule:
[ 6.689853] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.689858] cfg80211: Updating information on frequency 2457 MHz with regulatory rule:
[ 6.689863] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.689868] cfg80211: Updating information on frequency 2462 MHz with regulatory rule:
[ 6.689873] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.689878] cfg80211: Updating information on frequency 2467 MHz with regulatory rule:
[ 6.689883] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.689887] cfg80211: Updating information on frequency 2472 MHz with regulatory rule:
[ 6.689892] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.689898] cfg80211: Updating information on frequency 2484 MHz with regulatory rule:
[ 6.689902] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
[ 6.690030] cfg80211: Ignoring regulatory request set by core since the driver uses its own custom regulatory domain
[ 6.690037] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 6.782042] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 7.489860] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 7.894651] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 7.894671] brcmfmac: brcmf_add_if: ignore IF event
[ 7.899201] brcmfmac: power management disabled
[ 8.033863] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 8.033879] brcmfmac: brcmf_add_if: ignore IF event
[ 13.789085] brcmfmac: power management disabled
[ 14.079433] FS-Cache: Netfs 'cifs' registered for caching
[ 14.079809] Key type cifs.spnego registered
[ 14.079863] Key type cifs.idmap registered
[ 14.093933] CIFS VFS: Error connecting to socket. Aborting operation.
[ 14.094109] CIFS VFS: cifs_mount failed w/return code = -101
[ 15.710042] FAT-fs (sda1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 15.713313] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 66.728586] cfg80211: Verifying active interfaces after reg change
###### PHP backend ######
php version: 5.5.19
debug level: 0
Debug data collected in 1.249 seconds.
